1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
2nd Gen. Ducati Multistrada (2013 and newer)
Discussion in 'Moto Bellissima: All Other Dualsports' started by Salvo, Sep 22, 2012.
  1. Doug Piranha
    Doug Piranha Been here awhile Supporter
    Jan 8, 2010
    241
    Central Illinois
    Ok, I see more where you're coming from now. I would say no to that. I have a 2013 Multi and love the bike, but it would definitely protest accelerating out of a corner in 3rd at 2500 rpm. I hope this helps.
  2. Drop_Center
    Drop_Center Long timer
    Sep 3, 2007
    4,601
    Rocky Mountains
    Dammit! I should have been more clear. Here are the bikes that I know will plow through a slow corner in 3rd. Bandit 1250, FJR1300, Tiger 1050 but I don't want any of those! ME WANT MULTI! At least I'll know what to expect if I do get one.
    Plus, I live in Denver where you need 190 horsepower to powerwheelie in 1st! When I rode my 14 down to California I had no issues, so take altitude into effect too.
  3. brianpc
    brianpc Long timer Supporter
    Feb 20, 2013
    1,694
    CA
    I think you'll find the behavior of a desmodromic twin to be "kind of" similar to your ZX14's i4 behavior, in that regard. You *can* go that low and stay in 3rd and it will lug out of a corner with the torque, but why would you want to? Bang it down to 2nd and rev the piss out of it. It's not a "midrange twin", the thing screams to it's 11k redline and you'll love it all the way.
  4. Lion BR
    Lion BR I'd rather be riding
    Oct 18, 2005
    5,168
    Oregon
    The 2013-14 Multistrada will actually be fine on most sweeping curves on 3rd gear, it has plenty of power there but you need to be at speed. On tighter curves or at slower speeds, yes, you need to go down to second gear. I would say that's part of the fun of riding.
    Shizoku likes this.
  5. Drop_Center
    Sep 3, 2007
    4,601
    Rocky Mountains
    Trigger pullage this Tuesday. Stay tuned.
    oalvarez likes this.
  6. Krazyjohnny
    Krazyjohnny Been here awhile Supporter
    Mar 25, 2011
    490
    McKinney, TX
    If you are picking up a left-over 13' or 14' make sure they have installed the latest fuel sender in the tank. It should be revision D.
    SloppyFloyd and BobcatSig like this.
  7. ScotchPat
    ScotchPat n00b
    Feb 12, 2015
    3
    Picking my '13 up next Friday....then a ~2200 mile ride home.
  8. Idontlikemud
    Idontlikemud Adventurer
    Mar 18, 2015
    11
    San Diego
    You really want to be above 3,000rpms at all times with this bike. I almost never let the revs drop below that and I'm usually above 3500rpms. Most 90 degree right turns I'm dropping down into 1st gear. On the freeway at 80mph I'm turning almost 6krpms and I have a 41 tooth rear sprocket on my Multi.
  9. Drop_Center
    Sep 3, 2007
    4,601
    Rocky Mountains
    I thought about it a lot and considering how much I love my ZX14 for touring the best Ducati I could think of owning was a Hyperstrada 1100. Got one last week and it's fucking wicked.
    Edit- Hypermotard 1100
    Tim_Tom likes this.
  10. Buzzworm
    Buzzworm Adventurer
    Oct 4, 2012
    23
    Houston
    Dealership will be replacing the fuel sensor (this will be the 3rd one) on my '13MTS when the part comes in. It is currently back ordered. This is the latest part number 59210211D. Mine failed 2 weeks out of warranty. Ducati agreed to cover the repair since it was a "revised" part. Hopefully whoever they outsourced the manufacturing of the part to gets it right this time or they are using a different supplier.
  11. Krazyjohnny
    Mar 25, 2011
    490
    McKinney, TX
    Buzzword,
    Mine is working better than it ever did before.
  12. Krazyjohnny
    Mar 25, 2011
    490
    McKinney, TX
    Another little tip would be to install speedbleeders at the levers. They are the top of the hydraulic circuit for the front brakes and clutch. Then bleed them. Also on the ABS unit under the seat you can do the same for the rear brake circuit. You will be amazed at how much air is in the ABS unit. This alone has done away with the "limp pedal" on the rear brake caliper. I used the stock Ducati bleed valve setup for the clutch slave. Next is to replace the rear pads for HH pads to improve feel.
    I figured this out working on my trucks brakes where it says to bleed the ABS unit on it too. Then I confirmed it via a site from across the pond as being very successful. It is not in the Ducati service manual.
  13. MotoMutley
    MotoMutley Adventurer
    Jul 17, 2014
    42
    Agreed on the ABS bleed. I replace the stock banjo bolts with a pair of banjo bleeders, and at the first bleed a crap-load of air came from both of them. I regularly bleed that circuit along with the front and rear brakes. Braking action and feel has been much improved for a negligible cost.
  14. Krazyjohnny
    Mar 25, 2011
    490
    McKinney, TX
    Just added the EBC HH pads to the rear. Great feel and performance.
    Sent from my iPad using Tapatalk
  15. O Trader
    O Trader Adventurer
    Dec 2, 2009
    63
    Down the beach
    What do these "speed bleeder" things look like. My 13 has now go issues with the rear that goes all the way to the mechanical stop on the first push. You have to pump it 3 times to get it to firm up.
  16. krotchity
    krotchity Aussies Rule!!!
    Feb 12, 2008
    31
    Shenandoah Valley, Verona, VA
    KrazyJohnny, Where do I find those Speedbleeders, and how difficult are they to install? My front brake is awesome but the rear brake has been bled by the Duc techs and needs it again superbad. Sounds like you got a Fix for what ails it
  17. DaytonaBen
    DaytonaBen Adventurer
    May 30, 2013
    36
    Bel Air
    With the new wire rim wheels coming out on the new 2016 Enduro bike has anyone found a source for wire rim wheels for the 2013 S? Would it be possible to put a 19" on the front or would you have to change the forks/brakes too?
  18. TBR
    TBR One Life ~ Live It...
    Jan 31, 2013
    2,339
    Cruisin' China since '89..
    KINEO has wire wheels but not sure about larger front wheel sizes = http://www.bikehps.com/acatalog/Kineo-Wire-Spoked-Wheels-Ducati-1200-Multistrada-2009-onwards.html
    In the end ~ only a matter of $$$$'s if you really want them wheels badly..... nuff said'.....
  19. DaytonaBen
    May 30, 2013
    36
    Bel Air
    Thanks, I will start saving my pennies. Shame to scratch them all up in the gravel. I think my used KLR cost about the same. :) MudDuc3.jpg
    sierrastone likes this.
  20. MotoMutley
    Jul 17, 2014
    42
    [​IMG][​IMG]
