2wd
Discussion in 'Hacks' started by Lone Rider, Dec 21, 2007.
  1. Lone Rider
    Lone Rider Registered User
    Jan 29, 2002
    25,130
    out and about
    Is Ural the only choice for 2WD?
  2. JohnBG
    JohnBG Slow Moving Three Wheeler
    Nov 29, 2005
    266
    Deltona, FL
    Pretty much, yes.
    There is a similar model called Denper made in the Ukraine that has 2WD, but the factory is closed and they are not making new bikes anymore. Hasn't for a few years.
    You could always take an old Ural or Dnepr and pop in a early 80's BMW R airhead engine. It does require some modidfcation to the Ural/Dnepr transmission.
  3. DustyJacket
    DustyJacket Been here awhile
    Aug 27, 2007
    290
    Missouri
    No, there are some custom shops putting out 2WD.
  4. JohnBG
    Nov 29, 2005
    266
    Deltona, FL
    Sorry. I thought he was referring to rigs that were already manufactured with 2WD, stock from the factory. My bad.
    I supose anything is possible in a custom shop.
  5. ReCycled
    ReCycled Been here awhile
    Oct 8, 2005
    602
    Vally Forge, PA
  6. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    29,549
    Über Alles,California
    I woke up this morning thinking of a way to build my own 2wd rig that can go faster than 55 MPH and here is this thread. :loco
  7. zenben
    zenben all roads are one
    Feb 27, 2007
    599
    Portland Oregon
    The R75 derivitave design of the Ural dates to the late 1930's.
    Hardly modern, but probably durable. Without a limited slip, there is no use for it unless used on very loose surfaces.
    I'll admit to never driving one, (soon to be remedied), but with 70 years of technological development to harvest, there surely must be a better way. :ear
  8. AceRph
    AceRph Be like Tom
    Jan 12, 2003
    24,870
    Kingdom of Gav
    MOBEC Duo Drive
    MOBEC Super Drive
    This system has a reverse. The rear wheel is attached to and suspended from the sidecar frame.
    Their website says a lot of other stuff. I can't read German.
    http://www.mobec.de
    #8
  9. gyroforce
    gyroforce on the run
    Oct 31, 2006
    136
    the old world
    #9
  10. larryboy
    Jan 9, 2005
    29,549
    Wow. :huh That is some nice stuff!! Seems overly complicated, but nicely done.
    I think I'd go with a left side hack for a BMW and go with a small gear reduction electric motor for reverse if I was building my own.
    #10
  11. KCDakar
    KCDakar What are we waiting for?
    Nov 11, 2006
    3,421
    South of Kansas City a spell
    Why Left side?:ear
    #11
  12. Lone Rider
    Jan 29, 2002
    25,130
    out and about
    I think their setup cost is about 6 KLRs, no sht.
    Wouldn't take long to burn up an elec motor in some knarly stuff, but I don't know sht about that.
    Left side?
    #12
  13. Frank Warner
    Frank Warner Traveller
    Mar 14, 2002
    6,593
    Sydney, Australia
    Think you'd want a temperature sensor on the motor .. going back to the motor controller.. Even then the electric motor needs to be speed limited ... (you can get electric clutches .. so that can dissconect the eletric motor .. still leaves you with a reverse that way.)
    Anyone know about using hydraulic motors ? I know the seals blow if the wheel stalls (stops) ... any other design considerations?
    Left side is required in Australia for one. On the Isle of Man they get away with a right chair despite them driving on the left...
    Other 2WD chairs .. go back to WW2 and bm made one .. possibly some others (Jawa?) too .. but my memory lets me down at the moment.
    #13
  14. AceRph
    AceRph Be like Tom
    Jan 12, 2003
    24,870
    Kingdom of Gav
    #14
  15. Lone Rider
    Jan 29, 2002
    25,130
    out and about
    The temp sensor switched/controlled Warn winches used on our Mil vehicles blows rotten goat balls. You really, really don't want this kinda setup.
    Hydraulics might be applicable for long-use winch operation, but not for practical vehicle drive. There's already a powerful gas motor on the rig. It just needs a reverse gear.
    #15
  16. larryboy
    Jan 9, 2005
    29,549
    Easy to couple with the hub rather than some fancy thru the hub deal. It'd be easy to put a stub shaft behind the wheel and have the wheel hold it on and have a spud to hook the hack shaft to.
    #16
  17. larryboy
    Jan 9, 2005
    29,549
    Jeez, only $10? :deal
    Something like a gear reduction high torque starte motor would be the ticket. Kick the bike into neutral and thumb the motor..2wd reverse with plenty of power..the nice thing about a hack is that there is room for a deep cycle. I've got a bazillion miles on a hack rig and have really only needed reverse a few times. Look at BeemerChef, riding all over without reverse.
    Left side would couple easy with a BMW single sided swing arm.
    #17
  18. Lone Rider
    Jan 29, 2002
    25,130
    out and about
    I'll leave the lefty engineering to you. I ain't got a clue.
    It depends on where you go. I'd install a winch on mine anyway. These are heavy fckers, especially with all the crap I'd carry with me. For me, there's no reason to have one and just run the streets. A roadable, highwayable 3-wheel ATV kinda thing that can carry a bunch of useless stuff I want to carry.
    I won't venture into this black hole without some form of 2wd because I know what would happen. Also, I'd love using my '02 GS (needs new motor)as the driver, good power, air cooled, torquey, easy to maintain...and some other stuff. Needs lower rear gearing from an 80.
    Yeah, an Optima yeller top or 2 onboard, good cooler setup, built in sleeves/tubes for the tarp poles, some kinda solar charging sht that jkam suggested...and some other stuff.
    Way cool personal expedition vehicle, but...but....gotta be reliable.....
    #18
  19. Mr Smith
    Mr Smith Been here awhile
    Dec 17, 2004
    370
    Nice engineering
    #19
  20. zenben
    Feb 27, 2007
    599
    Portland Oregon
    But still no limited slip.
    A transfer case is old technology too. I'm thinking viscious couplings...
    2WD on demand, on the fly, and through a LSD/reduction gearbox.
    #20
