390 Adventure owners thread
Discussion in 'Thumpers' started by inroads, Jun 11, 2020.
  1. Downhill Rider
    Downhill Rider Been here awhile
    Feb 21, 2019
    151
    N. WI / S. AZ
    Indeed I did. They had one left in a crate that they assembled for me on Wednesday.
    Being my first ever foray into KTM, I had never heard of them before, but apparently they are the fourth largest KTM Dealer in the Country. From my initial interaction, they seem like good folks to work with.
    There’s no shortage of deep sand to be found in Northern Wisconsin!
  2. TwilightZone
    TwilightZone Long timer Supporter
    Dec 2, 2008
    10,962
    Behind the Redwood Curtain
    No cush hub on rear.
    21" and 18" wheels. May not be enough clearance on the 390.
    Appears that the front wheel rim is bent.
    Brakes... I dunno if they will fit.
    MotoSly likes this.
  3. MotoSly
    MotoSly Been here awhile
    Oct 11, 2019
    153
    East Flanders, Belgium
    Ok thnx! Not going to take the risk!
  4. snowhawk jockey
    snowhawk jockey Slack Jaw Gaper
    Jul 5, 2005
    1,561
    The other Center of the Universe: Bend, Oregon
    Motosly, if you could fit up the wheels and verify that axles and spacers aligned the brake rotors and sprocket, there would be less concern about the gamble. Without that basic fitment, not worth the gamble, bent rim or not.
    Slipper clutch would work more, without a cushion drive rear hub, but that is a smaller issue than fitment.
    MotoSly likes this.
  5. HLR4
    HLR4 Been here awhile
    Sep 1, 2020
    118
    PH
    this is also the extent of my knowledge on the matter. what if i swap out the caliper bracket for the 790 ones? will it fit the 390A fork?
    MotoSly likes this.
  6. Unhingedlizard
    Unhingedlizard Long timer
    Feb 28, 2012
    1,520
    Wellington
    The non R version has the same 43mm fork. Could be a goer.
    Wonder whats the gain after going to all this effort though?
    MotoSly likes this.
  7. HLR4
    Sep 1, 2020
    118
    PH
    i reckon brake bite will be better? im looking for stronger brakes akin to much bigger road bikes, for on-road use.
  8. Unhingedlizard
    Feb 28, 2012
    1,520
    Wellington
    Fair enough. Just wonder if its not gonna yield much gain due to the 790 having a twin brake set up.
    There's an idea. If the 790 has the same 43mm forks the whole front end might slot into the 390s triple clamp.....
    MotoSly likes this.
  9. 0405canvet
    0405canvet Long timer
    Apr 14, 2012
    1,738
    brisbanish
    Hey, has anyone replaced their rear shock? Or know of any alternative shocks that would work??
  10. BigCanoe
    BigCanoe Long timer
    May 1, 2005
    1,347
    Located in Moncure, NC
    I am getting close to my first oil change. Should I buy the KTM Duke 390 oil change kit that comes with filters, o-rings, and oil? Or can I just buy oil (what weight, quantity and brand?) and reuse those parts?
  11. TwilightZone
    Dec 2, 2008
    10,962
    You can re-use the filter screens (but of course, not the paper oil filter.)
    Blow out the screens with WD40 and if you've got it an air compressor.
    Screens will work lots of times before the o-rings wear out.
    $3.99
    https://www.rockymountainatvmc.com/parts/hiflo-premium-oil-filter-p?v=17314
    Might need some crush washers too.
    Otherwise... Just buy the filter/kit... with no oil. $21
    https://www.rockymountainatvmc.com/parts/ktm-oil-filter-service-kit-p
    And then this... $57. Will last for about 3 oil changes.
    https://www.amazon.com/Motorex-Powe...=1&keywords=motorex+oil&qid=1626707268&sr=8-1
    torang and LC.Kevo like this.
  12. LC.Kevo
    LC.Kevo Adventurer
    Oct 12, 2020
    95
    Lake Country, BC
    I just changed mine last week, ended up purchasing the K&N oil filter instead from my local Lordco parts store; P/N: KN-155, just FYI.
    Any good quality 15W50 full synthetic will do the trick (I use Amsoil metric); and you can just clean and re-use the screens as Twilight mentioned.
    MotoSly likes this.
  13. BigCanoe
    BigCanoe Long timer
    May 1, 2005
    1,347
    Thanks guys, very helpful!
  14. FloppyArmadillo
    FloppyArmadillo Adventurer
    Jun 30, 2021
    17
    British Columbia
    Anyone able to take pictures of their clutch cable routing while using rox risers? I re routed it behind the forks, but with routing it over the stock handguards, at full lock to the right the cables too short and pulls the clutch in. Makes me think I need a longer cable but others seem successful with the stock cable, maybe I'm routing something incorrectly.
  15. LC.Kevo
    LC.Kevo Adventurer
    Oct 12, 2020
    95
    Lake Country, BC
    I routed mine the same way, and ended up moving the clutch mounting clamp inboard about 1/2" to avoid this problem. The cable rubs on the hand guard clamp screw however so I'm just replacing with a longer cable now.
    MotoSly and FloppyArmadillo like this.
  16. FloppyArmadillo
    Jun 30, 2021
    17
    British Columbia
    Cheers, I think I'll look into a new cable. Wonder if replacing the handgaurds with true barkbusters would give a little more slack.
  17. LC.Kevo
    LC.Kevo Adventurer
    Oct 12, 2020
    95
    Lake Country, BC
    Good question; I've got BB Storm's on order, should have them in a week or two. Will most likely wait until fall to install them however.
  18. dwighop
    dwighop Been here awhile
    Sep 25, 2013
    164
    Inverness FL
    I was not so lucky. Still has the hum at 4500 rpm
  19. TwilightZone
    Dec 2, 2008
    10,962
    New cable was cheap. In fact, the cheapest mod I've made to the bike.
    FloppyArmadillo likes this.
  20. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    5,044
    Nelson, New Zealand
    Same series forks but the upper outers are different diameter. The 790 ones match the 790R. The 390 ones are narrower.
    There’s a lot going on there. It’s likely the 790 axle holder will fit on the 390 lower tubes (they just screw in) or use the whole lower tube with holder, but the axle is different. Can you just change the bearings? Sleeve the axle? Is the brake disc the correct diameter for the 790 caliper?
    Would it be easier to fit a larger disc and space out the OEM caliper? Find a better caliper with the same mounts? Change to better pads? Better same-size disc?
    MotoSly and Unhingedlizard like this.
