390 Adventure owners thread
Discussion in 'Thumpers' started by inroads, Jun 11, 2020.
  1. snowhawk jockey
    snowhawk jockey Slack Jaw Gaper
    Jul 5, 2005
    1,561
    The other Center of the Universe: Bend, Oregon
    Good tip!
    "The look" is never good... at least she could be justified when the bike wouldn't start on the stand.
    bikemoto likes this.
  2. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    5,044
    Nelson, New Zealand
    I never doubt her description of the symptoms. Sometimes I disagree with the diagnosis. Usually it comes down to experience.
    LC.Kevo likes this.
  3. mminob
    mminob MotoHolic
    Mar 24, 2011
    1,092
    Ocean Beach,California
    I was told that a fuel pump is cooled by the fuel around it and when you always run down to low levels the pump can run hot and fail sometimes ?
    Maybe a pump can handle the heat and no problems but keeping the pump happy may prolong it's life ? Just a myth ?
    Also the kickstand sensor can be related to no start if failed...
  4. snowhawk jockey
    Jul 5, 2005
    1,561
    Fuel pump cooling is no joke. The early 990s and 690s had a few riders experience fuel pump issues and failures from plugging filters and running dry.
  5. Albie
    Albie Kool Aid poisoner
    Mar 31, 2004
    16,184
    NWA
    Actually, I'm pretty sure on the 690's that a lot of the failures that were attributed to overheating were nothin but guessing/supposition. I actually cut my fuel pump apart on my 690 when it failed. The problem was the vibrations caused the wiring to the brushes to move around enough that they eventually sheared. Also, a lot of owners thought there was a bunch of crud getting in their tanks and causing the pumps to clog. The black silt they were seeing is from the carbon off the pump brushes and commutator which were carbon.
    snowhawk jockey likes this.
  6. Unhingedlizard
    Unhingedlizard Long timer
    Feb 28, 2012
    1,520
    Wellington
    The 950 pump was a failure point as well, though it was external. Actually used points that wore down and failed. Common repair was to replace the whole internal control unit with an inmate designed circuit board. The bonus with the old carbed girl was if your fuel level was above the carbs it would self feed.
  7. 0405canvet
    0405canvet Long timer
    Apr 14, 2012
    1,738
    brisbanish
    Would it be possible to put an external fuel pump on and have it survive??
  8. Albie
    Mar 31, 2004
    16,184
    NWA
    If you're looking for reliability, then a brushless pump would be worth looking into more than an external. The external will still suffer from the vibrations, and the brush wiring will still be. failure point.
  9. Downhill Rider
    Downhill Rider Been here awhile
    Feb 21, 2019
    151
    N. WI / S. AZ
    So, I ordered a set of Rox 1 3/4” Risers after their Website instructed that only some minor cable routing would be required. Upon receipt, it’s clear that removing cable ties and stays isn’t nearly sufficient. Has anyone installed these risers, and if so, can you provide insight into how you made it work?
    It looks to me like both the clutch and brake lines need to be moved...
  10. wncstrada
    wncstrada Been here awhile
    Nov 12, 2005
    210
    Western NC
    On my bike, brake line was OK. Clutch cable can be routed behind the triple clamps or there's a longer clutch cable available from MotionPro. Lots of discussion about this in the thread. Good Luck!
    Downhill Rider likes this.
  11. MotoSly
    MotoSly Been here awhile
    Oct 11, 2019
    153
    East Flanders, Belgium
    So i was about to buy a slip on exhaust.. just to make it more "alive".
    The shop that sold it said it wouldn't fit ny 390adv... Cause the slip on was for a duke 390... But isn't that the same???
  12. OldTomRides
    OldTomRides Still on two wheels Supporter
    Sep 4, 2009
    148
    Spokane, WA
    Yesterday I finally got around to replacing the endcap with the Best Dual Sport Bikes endcap that a couple of other here have done. I really like it! I made a video of my experience (see link below), which I found a pretty "fiddly" process due to the cheap manufacture of the exhaust. But I got it done.
    My one question for those of you that have done it or anyone else with an idea: what could I use to act as a heat-resistant seal? The original endcap had a rubber seal that was coated on I assume to prevent water from running into it. I have no idea what to replace it with, or if I need to even bother with it. I'd appreciate anyone's thoughts here.
    Link to my YouTube video
    You can hear the before and after at the end of the video.
    Please note: I am absolutely not a mechanical expert. So any cringing you do when watching - I apologize. The drilling the pop-rivets was way easier after the first one (which is the only one I recorded). But the bottom line: it worked.
    LC.Kevo likes this.
  13. A1VW2NV
    A1VW2NV Adventurer
    May 30, 2020
    55
    Vancouver Washington
    Wurth makes a great exhaust sealing paste.
    oldgrizz and OldTomRides like this.
  14. A1VW2NV
    A1VW2NV Adventurer
    May 30, 2020
    55
    The motor is the same, but the entire exhaust is different! You'll need something 390adv specific.
  15. FloppyArmadillo
    FloppyArmadillo Adventurer
    Jun 30, 2021
    17
    British Columbia
    Read the past 3-4 pages, there's been some talk specifically to rox risers. I've got them installed with stock equipment, clutch cable is too short even with re-routing I found, will be ordering a new motion pro one. Only other thing I found was needing to cut a cable tie on the brake line.
  16. bikemoto
    Oct 24, 2004
    5,044
    Nelson, New Zealand
    High-temperature RTV should do the job. Same stuff used on two-stoke exhaust systems.
    OldTomRides likes this.
  17. TwilightZone
    TwilightZone Long timer Supporter
    Dec 2, 2008
    10,962
    Behind the Redwood Curtain
    >"The original endcap had a rubber seal that was coated on I assume to prevent water from running into it."
    Why would you want to do that ? End-cap exhaust opening goes straight into the muffler !
    I think that BDS will release an end cap extension with a turned down tip on it in awhile.
  18. breeno
    breeno Been here awhile Supporter
    Mar 26, 2014
    171
    Heath, TX
    78er and MotoSly like this.
  19. MiddleAgedMissile
    MiddleAgedMissile Long timer
    May 30, 2007
    1,376
    Eureka Springs, Arkansas
    The only good fix is a new clutch cable. I installed the Rox Risers and quickly found that rerouting helped but did not solve the problem of clutch slippage at full handlebar lock. I did not replace the brake line and so far it appears to be ok with some minor pulling and pulling to gain a little slack.
  20. Downhill Rider
    Feb 21, 2019
    151
    N. WI / S. AZ
    Thanks for the replies, fellas!
    A new Clutch Cable is in the works.
    There’s no way I can stand up while riding with the current handlebar arrangement.
