#4 - R90S Powered /2 Conversion Period Hot-Rod
Discussion in 'Airheads' started by Solo Lobo, Jun 17, 2020.
  1. black knight
    black knight Long timer Supporter
    Dec 2, 2009
    1,028
    BMW Classic Motorcycles :: Mark Huggett GmbH
    16 11 4 080 165
    Gas Tank Tool Box Threaded Lock – SCREW $10.52…
    16 11 4 080 172 SQUARE WRENCH $14.08
    Tool box key
  2. black knight
    Dec 2, 2009
    1,028
    install the flat front fender strap - - - - outside
  3. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    12,395
    Shoreline, WA
    Got a few of those...
    Thought about that and the fender clearly hadn't ever been installed like that before. Everything fits now
  4. black knight
    Dec 2, 2009
    1,028
    good
  5. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    Title: Well, there's your problem... (idiot)
    Ever since the first firing, I have been chasing good even running on this engine. First the EI rotor was sipping effecting the timing, then the coil cooked, and finally with points and a new coil installed the bike was running better than ever, but the weird mid-throttle popping and running and weird idle setting disparity remained.
    Figured I would just throw some new parts at the problem.
    There's the new coil and ignition spares
    Bough new brass (forgetting I had already replaced the needles and needle jets). When I dipped the left carb I failed to take out the idle screw o-ring, that the Berryman's swelled up to 5X it's normal size. I used a generic wrong sized o-ring before and the one you see there is to rectify that issue
    The only disparity on the left side was that the OEm jet size is 60 and I had a 55 in there
    Wrong and right o-rings
    Buttoned up the right side and hopped over to the left. This where I realized something was missing as I had more parts to put in than I had taken out, lol
    Up to the attic to find the bag of Dellorto parts
    Yep, there it is
    Found the right o-ring in the carb parts box, with the other spare Dellorto bits. I had installed the wrong, generic o-ring thinking I wouldn't find this one
    That will probably work a bit better
    Now it's time to tune the carbs...
    Mr. Vintage, globalt38 and BJMoose like this.
  6. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Because carburetors have little to no pressure, the problems can be very slight and cause a world of running problems.
  7. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    Day one of being an official empty-nester brought much garage time... the playlist today was Sisters of Mercy followed by The Clash.
    The initial plan was to tackle this stuff, with a few other things that also had to have the tank off to complete. Those who don't own a /2 may not know that the tank cross-over line makes removing the tank a bit of a chore.
    The company who sold me the conversion exhaust system was almost offended when I asked about exhaust clamps, reposing "our systems do NOT require such clamps!"
    O yeah?
    Step one, remove the tank and air box and starter cover... the eagle-eyed amongst you may notice the Guzzi wheels which look (by complete change) to possibly have been traded for my next project...
    My breather has been honking, which was really bothering me so I bought the Northwoods tool, and also pulled the new stile breather out of the old R100RS block I have in the attic.
    I also found that the rear right side screw I had holding the R90S engine badge on was too long, and was fouling the breather tube, so that had to be shortened...
    With that done, I also had to make the missing left side airbox holding tab... really should have used steel and the thick aluminum I used is OK, but will be replaced
    With the breather, airbox holder thing and the exhaust clamps done I spent a bunch of time chatting with the guy who came to buy the wheels, and it turned out we share many.many friends in the local motorcycling community. In discussing one of our comment friends bikes that I really like, he said "what if I trade you enough parts to build one of those for the wheels?"
    I'll leave it at that, with the only note that the project pile isn't a BMW... more on that later if this does come together.
    Next up is finding the source of this leak
    It could be the oil pan gaskets, yes two of them since I am running a Briel oil cooler, or maybe ever the rear main seal (yes, that one is new).
    I plan on cleaning everything and then finding the source. I have two new pan gaskets on order from the local dealer as the two in there now are from Motobins and I am not 100% convinced they were OEM.
    On a related, unrelated note here is my growing collection of Unimat "toy" lathe/mill parts
  8. nmalozzi
    nmalozzi airheaded
    May 4, 2013
    3,316
    Arvada, CO
    It's amazing the things one notices when they suddenly have a similar bike in the garage. I'm clearly missing that gasket for my tank's storage compartment. I did find it odd there was nothing rubber in there. Adding that to the list, lol.
  9. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    I think that gasket is labeled for singles… I added it for color contrast.
    not a perfect fit
  10. black knight
    Dec 2, 2009
    1,028
    AS FAR AS I could throw those fucking cloth covered fuel lines .....
    wouldn't be FAR ENOUGH. new formulated gas EATS THRU that shiity german shi.
    i had an engine fire on my 356. 30 seconds, put out w/ my fire extinguisher cost $4400.oo 25yrs ago.
    I know they look cute.........
    those lines are fuckin' shit.
    now you know
    zzzak likes this.
  11. black knight
    Dec 2, 2009
    1,028
    Anybody ever drill / tap / install a grease fitting @ th rear foot pivot ?
    693C3803-2975-43A3-9583-30AB859A06FC_1_105_c.jpeg 1C3641F0-ECB4-403B-9E61-96582DEAA37D_1_105_c.jpeg A4B5AA40-9AED-486B-8D6B-C2DD0E5A3F5A_1_105_c.jpeg F09E9C39-2722-40A9-BFBA-EBCB64685FC3_1_105_c.jpeg
  12. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    I’ve been using this fuel line for about 20 years now with no issues.
    korinthias likes this.
  13. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,086
    Silver Spring, Md
    On the old boxer Beetles with this same fuel line the line runs above the distributer so when it leaks it also has spark. A good vehicle fire needs both fuel and spark.
  14. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    9,152
    Looks like Snowbum was here.
    bpeckm, beemeruss, nmalozzi and 2 others like this.
  15. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    The foot brake doesn't need a grease zerk if you keep up with maintenance. When ever I get bored or have a little time, I go around the bike with a pump oil can, a drop on anything that moves. Yup, even a drop in the ignition hole ( a mostly overlooked point of lubrication).
  16. black knight
    Dec 2, 2009
    1,028
    i was thinking out loud :choppa
    I think you're right pokie, Just keep a yearly watch out / annual maintenance schedule.
  17. black knight
    Dec 2, 2009
    1,028
    WoW solo,
    very nice work, you're a proud owner of such a looooong series of challenges, joys, mistakes, problem solving, Loads of long hours & hard workmanship && progress to the beautiful results. You make us all proud of what you have done to have such a beauty. . . . . . cool new tool,
    you could use the talcum powder method. clean it all very well. go ride for 5-10 minutes
    then dust it w/ talcum to see where the oil source comes from.
    2nd, I guess I never knew that Sport Tanks had a rubber edge.
    or
    is that a product from 'Tap Plastics' called edging which comes in black, gold and silver.
    https://www.tapplastics.com/product...iKl2lw7CO8sMZXuRqMNK3jPFV24kDk6BoCNJoQAvD_BwE
    Jim K in PA likes this.
  18. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    Forgot to mention that I also modified and re-installed the rubber starter cover air intake. it didn't fit and the intake noise was pretty loud without it
    I'm just back from a 15 mile lunchtime ride and the reduction of intake noise is nice, as is the lack of the gobbling from the old-style breather. This does bring some right side valve train noise to the forefront.
    Next up, change the oil since I am at ~200+ miles, inspect the filter for news (good or bad). I'll also drop the Briel spacer and oil pan to address the leaks by trying out some Gaskasynch.
  19. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Are the leaks from the oil pan or the push rod tube seals? I have seen a number of oil pan gaskets replaced, then discovered it was actually the push rod tube seals leaking.
  20. Solo Lobo
    Mar 16, 2004
    12,395
    Shoreline, WA
    Thanks Pokie,
    The PRT's are all dry.. but when I was cleaning the oil pan I did notice that it is looking like at least some of the leak is clearly coming from the oil filter cover....
    I went head and cleaned all the surfaces and think I am going to move ahead with the current plan of resealing the oil pan and briel spacer, as well as doing a filter change and all new crush washers.
    That will give me a new baseline for checking future leaks.
    It could also be that one of the cooling tubes (or thereabouts) is weeping/leaking a bit
