#4 - R90S Powered /2 Conversion Period Hot-Rod
Discussion in 'Airheads' started by Solo Lobo, Jun 17, 2020.
  1. black knight
    black knight Long timer Supporter
    Dec 2, 2009
    1,028
    WHAT diode did you use and which direction was it placed ?
    link the link you learned from for the rest of us .
  2. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    12,396
    Shoreline, WA
    I added the diode number to the earlier post, but they are 1N4001's that I got off of Amazon in a large assortment for something like $10. The ones I bought had to have the grey ring on the side closest to the bulb socket.
    I did check the orientation by holding the diodes in place using alligator clips and testing the flashers to make sure it would work.
    https://advrider.com/f/threads/5-turn-signal-indicator-light-and-leds.1521264/
    black knight likes this.
  3. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    9,169
    When I encounter a leak like the one you've posted, I coat the flywheel bolts with Hylomar, and make a THIN ring of Hylomar where center hole contacts the crank. Be very sparing there; metal to metal contact is (mostly) what keeps the flywheel in place. I'd also put some in the fly wheel where it fits over the indexing pins.
    Solo Lobo likes this.
  4. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,358
    Fort Collins, CO
    Often I find that a rear main leak isn't a rear main leak at all. Rather, it will be an oil pump o-ring leak. Putting sealant on the flywheel mount is a good idea as oil can and will find a way through.
  5. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    Just worked a deal for the speedo on the left...
    Pezz_gs, nmalozzi and Jim K in PA like this.
  6. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,176
    I sealed the tubes through my Briel with PC7 on the inside just for insurance. Snowbum of course rave about how they blow up and throw oil on the rear tire. I've used the thing on two bikes so far with no issues. But it's a PITA to install and doesn't help cooling. I tested it with the holes opn and plugged and my instruments showed no change. The extra oil has no value, just adds weight. Running the oil lower in the case may have some value, but I prefer more ground clearance. I use it.
  7. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    There’s been Briel on my R65LS for something like 100k miles now.
    mostly I think they look period and interesting
  8. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    Parts arrive, now I just need to find the time.
    The 3.5" rear tire looks out of scale from the rear end... should have started with the 4" tire I guess
  9. bmwrench
    Nov 10, 2006
    9,169
    Yeah, I'd probably send that back.
    Beils likes this.
  10. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    Beils and Jim K in PA like this.
  11. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,760
    Pocono Mountains, PA
    Yes. It's an R90S.
  12. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    Well, if there is a company that takes back tires with 220 miles one them… LOL
    Jim K in PA likes this.
  13. Jim K in PA
    Mar 15, 2011
    5,760
    :D Have you seen the returns area at your local Harbor Freight? :hmmmmm
  14. nmalozzi
    nmalozzi airheaded
    May 4, 2013
    3,336
    Arvada, CO
    or REI
  15. Pokie
    Apr 4, 2013
    8,358
    Fort Collins, CO
    If it's a /2 frame and wheels, 3.50 x 18 is the correct size. You can fit a 4.00 but that's not what the wheels were designed for. That said, a 4.00 x 18 on the rear looks just about right. A /2 frame was designed to take a 3.50 x 18 on the rear and a 3.25 x 18 on the front.
    Beils likes this.
  16. Beils
    Beils Been here awhile
    Feb 18, 2007
    264
    Chalk it up to Tuition! Paid for knowledge…
  17. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    One of my least favorite motorcycle tasks is changing tires, but for some reason I continue to do it myself. My excuse this time is that I bought the Mark Parnes balancer about a year ago and I was thinking I learned a few things that would help when I mounted the /2 tires.
    As I noted before, originally I went with a 3.5" front and back, but the 3.5x18 rear looked really small compared to the 3.5x19 out front.
    So, the removal and installation were smoother this time, but getting the bead seated was an absolute PITA that took me almost two hours and many, may attempts
    The rear fender isn't fully mounted so looks a bit askew here
    Here's the replacement speedometer. I am going to check multiple speeds on the current one (as it reads low) to see if I can determine what ratio it goes to as either is isn't a 1:2 as labeled or my final drive while labeled to match with a 1:2 contains different internals than it is marked. I'll probably send the new (old) one down to wirespokes this winter for a service
    Pezz_gs and brittrunyon like this.
  18. Solo Lobo
    Mar 16, 2004
    12,396
    Shoreline, WA
    Installed the Dyna booster at lunch today.... also realized that the speedo cable wasn't fully seated in the transmission. I wonder if that could have caused the speedo error I was seeing? Bet it could, need to test.
    globalt38 and Pezz_gs like this.
  19. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    3,067
    Arkansas Ozarks
    Curious how the new rear tire looks, pop up a pic next time.
  20. bmwrench
    Nov 10, 2006
    9,169
    That really is nice paint.
    Solo Lobo and bpeckm like this.
