4RT - Mitani side stand
Discussion in 'Trials' started by unospeeder, Jan 15, 2020.
  1. unospeeder
    unospeeder Adventurer
    Nov 5, 2019
    58
    Colorado
    Input from those who have the Mitani side stand installed on a 4RT. What have you done to keep the stand from contacting/hitting/rubbing on the axle nut? I see a couple options all of which have their pros/cons:
    1. Place a bumper between the stand and the bottom of the swing arm
    2. Place a bumper between the stand and the contact point with the axle nut
    3. Flip the axle so the nut is on the drive side
    I am sure the instructions tell me the preferred approach, appears to be flipping the axle, but why not leverage the vast amount of knowledge the user of this forum hold :beer
    grizCP likes this.
  2. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,087
    Boise aria
    The axle on my 07 was already flipped when I got it so didn’t notice anything strange when I put my Mitani on the bike. Not sure that really helps though.
    Though, If if it had been reversed I would have just flipped it. On that note I think the only other consideration in my mind might be to put a bit of a rubber stop on the leg of the stand with some zip ties and a bit of some VHB tape maybe.
    unospeeder likes this.
  3. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,467
    ABQ NM & Wichita Mountains OK
    I think this is entirely clear: Says it All.JPG
    10K, DyrWolf, jonnyc21 and 1 other person like this.
  4. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    7,522
    Portales, New Mexico
    I personally.....have done nothing. Never really bothered me. :dunno
    jonnyc21 and unospeeder like this.
  5. unospeeder
    Nov 5, 2019
    58
    Colorado
    Doesn't bother me in the least but it does concern me with regards to the wear on the stand over time as it hits the axle nut with a fair degree of force. I pulled equity out of my house to afford the stand so it has to last awhile :D
    noyolk, DyrWolf and grizCP like this.
  6. unospeeder
    Nov 5, 2019
    58
    Colorado
    Any option other than flipping the axle forces the foot of the stand out further from the swing arm which is something I would like to avoid
    jonnyc21 likes this.
  7. Brewtus
    Jul 30, 2008
    7,522
    Mine has ridden on top of the axle nut for what, 6 years now? "Printed" both the nut and stand, but no appreciable wear over hundreds (if not a few thou) of hours of use.
    YMMV.
    unospeeder and jonnyc21 like this.
  8. NMTrailboss
    NMTrailboss Team Dead End
    Mar 1, 2008
    9,083
    Albuquerque, NM
    Fixt...
    :D
    :hide
    #8
  9. Brewtus
    Jul 30, 2008
    7,522
    Keep it up, smartass. Keep it up. :bluduh
    :wave
    #9
    BEEF706, jonnyc21 and Norman Foley like this.
  10. unospeeder
    Nov 5, 2019
    58
    Colorado
    The kind of info I am looking for. Thanks!
    #10
  11. Champe
    Champe Been here awhile
    Feb 8, 2015
    786
    Belmont, NH
    This stand is really good. Maybe the best in the trials world. So I have been seeing some issues with the early TRS kickstand and notice that the mounting system is very similar. I have not measured the bolt spacing but I believe it is just a little off. I wonder if anyone here has tried the Mitani on anything other than a 4RT.
    #11
  12. SportSawyer
    SportSawyer 4RT Herder
    Feb 27, 2012
    281
    Northern Utah
    Not sure about adapting a 4RT sidestand to a TRS. But ...
    Mitani sources the 4RT sidestands from Trial Works Kosaka, https://www.twk.jp/670.html and TWK also makes similar sidestands for many other bikes. Mitani sells them too, but not for a TRS.
    Mitani does sell a very similar sidestand for the TRS sourced from Abe Seikou, http://www.abe-seikou.jp/, see https://mitani-kobe.shop-pro.jp/?pid=135385051
    Could try to run one of those down. Banyeres is the EU Mitani distributor, but doesn't list the TRS sidestand now. If there's much demand, maybe a US supplier would be interested in getting stock.
    Otherwise just try it. Maybe hanging your stock (or TWK) 4RT side stand with one bolt to check fit.
    #12
    Champe likes this.
  13. SportSawyer
    Feb 27, 2012
    281
    Northern Utah
    Helpful note for those who already use Mitani sidestands.
    A few years ago I needed to replace the spring on my Mitani 4RT sidestand. Looked into it and found it's Honda P.N. 50535-KN5-670, which fits a zillion different Honda models and is inexpensive.
    #13
    Champe and jonnyc21 like this.
  14. Ditch
    Ditch Long timer
    Sep 9, 2004
    1,760
    abq,nm
    You must have a bad one, send it to me and order a new one please.:D
    #14
    Huzband likes this.
