640 ADV Forks
Discussion in 'Thumpers' started by The Misinformant, Nov 4, 2007.
  1. The Misinformant
    The Misinformant What road?
    Jun 22, 2004
    350
    Adelaide, Australia
    Has anyone changed the springs themselves on the 4860WP forks? Is there any special tools required and is it a reasonable easy job?
    Have found a set of .46 WP springs out of a 06 640 to replace my .44 WP springs in my 03 640 ADV - which we think are a direct swap.
  2. Laromonster
    Laromonster Lean, mean pacifist machine
    Jun 28, 2004
    2,041
    Behind you
    Arent the 03 forks 43mm and the 06 48 mm ?
  3. The Misinformant
    Jun 22, 2004
    350
    Adelaide, Australia
    My owners manual says 4860, so I assume they are 48's. Let me look in the shed.
  4. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,127
    GodSowncountry Australia
    The '03 model got the hi-flow head and the rally 48mm forks, from memory.
  5. The Misinformant
    Jun 22, 2004
    350
    Adelaide, Australia
    Yep books say 48mm. Can't measure them tonight as it not here. Bloody squids!
  6. Para504
    Para504 Spam, Spam, bacon & Spam!
    Sep 5, 2005
    568
    Cow Hampsha, USA
    My '02 has 48mm (measured them to be sure) as well. The literature is notoriously wrong!
  7. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,002
    Beaverton, OR
    It's pretty easy, there was one special tool that I needed. In order to separate the top cap from the bottoming bumper, I needed to grind down a wrench so that it was thin enought to slip onto the flats on the bumper's nut. I think it was a 15mm wrench.
  8. Zerodog
    Zerodog Long timer
    Jun 9, 2006
    1,233
    SLC, UT
    Yes the 03 has 48mm forks. They are pretty much the same fork as the MX bikes. They just have a slightly shorter stroke on the cartridge. That is why they take the shorter springs. The 510mm springs will also work if you remove all the preload spacers except the thinest one. They are also the same interally as the 07 640. The .46 will most likely still be too light. But it will still be an improvement.
    #8
