640 LC4 Adventure 'bleeding' oil on head gasket?
Discussion in 'Thumpers' started by QMan, May 29, 2006.
  1. Laromonster
    Laromonster Lean, mean pacifist machine
    Jun 28, 2004
    2,162
    Behind you
    I did the deed this winter, no need to yank the engine.
    Here is how i did it http://www.advrider.com/forums/showthread.php?t=419834&highlight=idle+hands
    #21
  2. bbolstad
    bbolstad Adventurer
    Jun 23, 2009
    40
    Norway
    My bad, I was referring to the header flange bolt hole. I suspect the oil is leaking out there, was there is only remains of burned oil on that side. I was wondering if there is a was to fix this without taking the head of, but I do not know if there is a sealant that will work without cleaning the threads on the head?
    If not, I guess it can wait until winter and I'll remove the head to try to fix it.
    #22
