I think I'm right in saying this but please check . You could possible just swap over the gear selector switch . As far as I know the is only one wire that is needed to go to the dashboard /idiot lights
Excellent pointers, thanks for this!! Would you know by any change if the bolt for the rear oil feed to the oilcooler is long enough to have oil going through it? The 690RFR bolt fits, but I don't know if oil will flow through it or not when used on the 690E engine. How would I test? Just blow through?
Parts fishe is the best bet. Isn't the different bolt installed to divert the oil flow to the cooler ?
If your putiing a oil cooler on a 690e/r engine useing rfr cooler/ lines etc etc it will require part no 7623804800 lock piece (no 18 in engine cases section of parts book)
Excellent! Just what I needed! Number 18; http://www.ktmonlineparts.com.au/partFinder/fiche/13937/M.1043611
Thats it,you will need also 58038032100 seal ring 0770021140 o ring one of each,sounds like a good little project.
Going to be away for a few days but will order my last remaining parts before then, I think I have nearly all items to finish, except for a new front fairing and single sided exhauxt that is...
^^^^^ Yes I'm sure many of us would appreciate an update with pictures on your oil cooler install ! Having just completed my KIT690 and living and riding in Arizona, adding an oil cooler is at the top of my to do list. So I'm interested in all the intricacies of your project . mrwwwhite the creator of the KIT690 is working on a combo radiator/oil cooler kit to fit his KIT690. Not quite the same as your install but the connections and plumbing should be the same. Max
I might have posted a few here; http://allroadmaniacs.nl/forum/index.php?topic=21507.0 Back online this weekend. Will post a few more then.
KTM 690 Enduro – Rally Custom from Rafael Gorski http://derestricted.com/motorcycles/ktm-690-enduro-rally-custom
Waiting for the parts took ages as some plastic was funnily enough out of stock.. Updating the 690cc engine to accept an oilcooler feed was easy;
Does anyone know part number for 6 washers (cupped) for the rfr front gaurd?,got number for bolts 59001092050 but parts book doesnt show the washers.
