690 Rally Replica questions...
Discussion in 'Thumpers' started by F650Dakar_Norway, Jan 17, 2010.
  1. RedBallRun
    RedBallRun Been here awhile
    Jun 24, 2011
    271
    North Yorkshire, UK
  2. DakarMarc
    DakarMarc Marc
    Oct 27, 2006
    91
    Wien, Österreich
    Brilliant... Not where I would have thought to look for it!
  3. DakarMarc
    DakarMarc Marc
    Oct 27, 2006
    91
    Wien, Österreich
    Here is another question for you RR folks.
    Does the RR have a keyed ignition lock? Or just the toggle switch on the dash? With the key only being used as a steering lock.
    Saw in one of Lyndon's videos him repairing the wiring on the keyed lock cylinder...
  4. johnno950
    johnno950 Long timer
    Jul 17, 2010
    2,191
    No keyed ignition switch on rfr,just toggle switch oem.
  5. tehdutchie
    tehdutchie Long timer
    Jun 15, 2009
    2,244
    Amsterdam or on Twitter @antal
    Anyone have a close up where the fuel pump mounts? I'm kinda lost mounting mine and cannot find a good picture..
  6. nomad guy
    nomad guy A legal alien
    Oct 5, 2008
    953
    Boulder, co
    Fabnut likes this.
  7. tehdutchie
    Jun 15, 2009
    2,244
    Thx! Time to start wiggling the all lines through now :clap:jack
  8. Stollenritter
    Stollenritter n00b
    Sep 21, 2015
    3
    Germany
    Hi everybody,
    I like to change the stock orange of my 690RFR.
    Is there anybody who may gime me some information about the paints, primers, etc. to be used and how?
    I contacted a paint shop close by but they do not know how to do it...
    Thank you!
  9. johnno950
    Jul 17, 2010
    2,191
    My friend had his painted,from memory did get bubbles/lifting of paint from vapours .
    Seen a few 660/90 rfrs that did the same after short time.
    Brilliant job/result everywhere else
    RedBallRun, Fabnut, nivag and 3 others like this.
  10. VDG
    VDG Long timer
    Mar 8, 2006
    1,506
    Brazil
    :clap:clap:clap
    RedBallRun and Mr Head like this.
  11. OM
    OM Owners Manual
    Nov 7, 2010
    216
    Right by the Andes
    Would not be a problem to set up an ignition switch, relayed directly from the toggle. You only have to fabricate a mount for the new ignition.
  12. DakarMarc
    DakarMarc Marc
    Oct 27, 2006
    91
    Wien, Österreich
    Yes, that is what I am planning. I just didn't know if it was already like that on the RFR
  13. johnno950
    Jul 17, 2010
    2,191
    Finally got engine assembled,went together well and hopefully get a good run out it.
    More detailed photo of the countershaft that snapped
    Few other gears/selector fork/detent arm that on closer inspection were replaced
    Engine back in and super excited about getting out for a ride on this bike....
    Bit disapointed with that shaft failing,bike has got easy kms on it and it looks like it was half rooted from day dot ex factory.
    F650Dakar_Norway and tehdutchie like this.
  14. johnno950
    Jul 17, 2010
    2,191
    Got a shot out of the bike,sounds sweet.(nice deep thump/intake suck)
    Do a quick run on it over the next day or so then up her!
    I fitted a factory pro shift arm on rebuild and just on running the bike up on pre ride have already noticed it seems too select gears/find neutral better,it will be interesting too see how it goes under load etc when riding the bike,but at this stage it seems like a good bit of kit.Always been a very heavy gearbox on this bike !
    Dick0 likes this.
  15. RedBallRun
    Jun 24, 2011
    271
    North Yorkshire, UK
    Why is 10 minute jobs turn into...............
    Fitted flexible mini-LED flashers on rear and ZETA Racing Handguards with integrated LED flashers on front. Swapped the Flasher unit out for a no load LED unit and flashers work but do not blink. What am I missing? Do I need to fit a resistor in parallel across the flasher's pins?
  16. tehdutchie
    Jun 15, 2009
    2,244
    Am still looking for time to finish my bike, hope to spend some time on finishing her up over Christmas. ... slow going..
  17. RedBallRun
    Jun 24, 2011
    271
    North Yorkshire, UK
    Tank painting - I came across this product: http://www.paintflex.com/pf_PEPP_Paint.htm
    I dropped them an e-mail yesterday and had this reply:
    "We are the only Paint in the world, as far as we know, which adheres permanently to the polyethylene plastic surface.
    Paintflex (Solvent base) is vapour permeable and resistant to the Expansion-Contraction and Vibration of the PE Plastic.
    It will not peel off and will not bubble over the time , only a little bit weak ofScratching as it is H2 pencil hardness soft paint.
    You should put Protective Lacquer finishing to protect against scratching (H6 pencil hardness).
    The Lacquer finishing should be vapour permeable also.
    The application is by spray /Roller/Brush .
    We do not have the stocking agent yet in UK ,We sell direct from Japan."
    Sounds really interesting HOWEVER it costs US$198 for 1kg ex-factory and then has to get to Europe. Ouch - especially for an experiment.
    KEELAYMONSTER likes this.
  18. tehdutchie
    Jun 15, 2009
    2,244
    Lyndon offered paintjobs in the past, 800stg for the 3 tanks if memory serves me well
  19. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    3,842
    Gippsland
    If there is a blinker lamp on the dash with a T5 globe in it still this can cause LED's issues.
    Remove globe or fit a diode on each pin.
    BOL
  20. johnno950
    Jul 17, 2010
    2,191
    Got out and did a few 1000 kms on the 690 over xmas new year,all sweet bike going great.
    I did a oil/filter change at 250kms before xmas on rebuilt engine and was normal rebuild debri.Did a 1000km ride after xmas and everything was spotless/
    had a look at cam rocker assemblys,did another 1200kms on it tuesday-wensday and shes a good thing!!!
    VDG and RedBallRun like this.
