1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
690 Rally Replica questions...
Discussion in 'Thumpers' started by F650Dakar_Norway, Jan 17, 2010.
  1. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    I don't think Akrapovic sells the 690 RFR mufflers any more, so you will have a hard time getting parts for them because there is no diagram and parts list that I am aware of.
    Your best bet is Lyndon, he was/is (?) making equally high quality replicas mufflers in titanium, mine have about 80.000 kms on them and sound absolutely lovely, deep and rumbly while not annoyingly barking and loud. Put a smile on my face every time I start the bike.
    640 Armageddon and johnno950 like this.
  2. johnno950
    johnno950 Long timer
    Jul 17, 2010
    2,074
    Thanks for the info.
  3. Pyndon
    Pyndon Long timer
    Feb 4, 2006
    2,848
    Somewhere on two wheels!!
    johnno950 and F650Dakar_Norway like this.
  4. cardio
    cardio n00b
    Nov 13, 2018
    6
    paris
    Hello,
    I am thinking of putting a 2017 701 in my RFR. I don't understand how you proceed with the plugs/coil. Did you use the single coil of the RFR that you wired to the two plugs of the 701? Thank you
  5. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    Yes, that's the easy way to do it. Just connect your coil to the main center plug and leave the other one, the rest of the head is the same as the old single plug. At least that was the case with a 2015 engine in my 2008 690 RFR.
  6. cardio
    cardio n00b
    Nov 13, 2018
    6
    paris
    Thank you Lukas,
    is it more difficult to keep the stator from the 701 and make the double plus work? That would be more elegant ^^
    in any case, what ignition map should I run?
    Guillaume
  7. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    I don't understand your question, the stator is the same for all years as far as I know.
    If you mean the coil, I don't know anybody that has made a dual plug system work on the carbureted 690 RFR. It will get complicated as the dual plugs don't/shouldn't fire at the same time, so you would need a different ECU to control the spark. And simply running the ECU from the Enduro/SMC is unlikely to work with a carb if you leave the rest of the EFI system off.
  8. cardio
    cardio n00b
    Nov 13, 2018
    6
    paris
    OK it is pretty clear then.
    Single plug, coil from the RFR, stock ignition map from the RFR.
    Many thanks
  9. outbacktm
    outbacktm Bullrun Bison Supporter
    Nov 22, 2013
    1,103
    Bullrun, Or
    Stock flywheel as well with correct pickup gap .7mm?
  10. cardio
    cardio n00b
    Nov 13, 2018
    6
    paris
    What about keeping the ecu of the 701, then put the FI and the dual plug? What fuel pump should i fit?
    Guillaume
  11. johnno950
    Jul 17, 2010
    2,074
    Did you end up installing a 701 dual balance engine in the 690rfr?
    outbacktm likes this.
  12. johnno950
    Jul 17, 2010
    2,074
    Been a bit quite the the rfr thread!
    All going well got a ride comming up in the desert and excited .Best bike I ever owned
  13. Seth S
    Seth S Deleted
    Jul 19, 2004
    5,963
    Deleted
    Not much time to post while sniping zombies from the watch tower.
    KEELAYMONSTER, johnno950 and bigboyxl like this.
  14. johnno950
    Jul 17, 2010
    2,074
    Finally got out for a decent ride on the rfr here in oz,had a ball
  15. johnno950
    Jul 17, 2010
    2,074
    Did a bit of post ride work on bike,regreased the normal bits.
    Checked valve lash and happy with cam lobs etc.
    Removed the plastic collector box and plugged
    Cyc with 16mm Welsh plug.
    Want too source a twin plug coil to get the lower
    Following spark plug zapping
    Very happy with the husky 701sm engine
    nice and smooth,miss the 3 closer ratios on 4/5/6
    Gears on original rfr engine though
  16. jesusgatos
    jesusgatos fishing with dynamite
    Nov 17, 2006
    2,803
    santa cruz mtns, ca
    Interested in hearing more about how you're tackling the dual plug thing
    outbacktm and Steinarsv like this.
  17. jesusgatos
    Nov 17, 2006
    2,803
    santa cruz mtns, ca
    Converting a dual-spark 701 to carb using RFR parts and was wondering if anyone has part number for preferred spark plug handy. Has that changed over time?
  18. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    Just use the normal spark plug that is in the center of the head, and the same as the old single spark plug. LKAR8AI-9 or 75039093000 from KTM.
  19. jesusgatos
    Nov 17, 2006
    2,803
    santa cruz mtns, ca
    Curious to hear thoughts on oil coolers for these bikes? Gonna start designing a new nav tower for my Aurora kit, wondering if that's something should provide for or not.
