690R carburetor conversion mod.
Discussion in 'Thumpers' started by Visigothic, Feb 27, 2011.
  1. Ignas
    Ignas Adventurer
    Jul 21, 2011
    30
    Lithuania
    Check your woodruff key orientation on flywheel before welding pickup tab. There are at least 2 different flywheels for efi bikes that i found on ebay and RFR is also different.
    So ignitech ignition is the way to go for less hassle
  2. Michał 123
    Michał 123 Adventurer
    Apr 29, 2021
    42
    Polska
    I have both wheels so it's not a problem I will set the ignition point with a strobe lamp
  3. Michał 123
    Apr 29, 2021
    42
    Polska
    View attachment 3091211 mój przyjacielu fleup, czy byłbyś na tyle miły, aby dać ci ten wymiar wirnika rfr od nacięcia klina do tej małej dziurki?
  4. Michał 123
    Apr 29, 2021
    42
    Polska
  5. Michał 123
    Apr 29, 2021
    42
    Polska
    what is the ignition advance angle in the KTM 690 rfr?
  6. Michał 123
    Apr 29, 2021
    42
    Polska
    my turner only needs this dimension from the wedge to the dot and I will show you the first made Magneto EFI converted to rfr received_896391300946509.jpeg
    outbacktm likes this.
  7. Ignas
    Ignas Adventurer
    Jul 21, 2011
    30
    Lithuania
    I think you need to know exact crankshaft degree that flywheel tab is in the middle of pickup coil on rfr engine.
    Then find real tdc and zero your degree wheel on flywheel. After that, rotate to rfr specified angle and weld the pickup tab.
  8. Michał 123
    Apr 29, 2021
    42
    Polska
    this is what my Magneto looks like after welding, now it went to the turner, unfortunately I do not have the size from the wedge to the center of the belt and I will set the rest on the engine
  9. Michał 123
    Apr 29, 2021
    42
    Polska
  10. FLEUP
    FLEUP Adventurer
    Jun 7, 2021
    27
    France
  11. Michał 123
    Apr 29, 2021
    42
    Polska
    thank you very much fleup i am very thankful to you
  12. Michał 123
    Apr 29, 2021
    42
    Polska
    my Magneto is finished, could someone tell me why there is no spark on the candle?
  13. Ignas
    Ignas Adventurer
    Jul 21, 2011
    30
    Lithuania
    Either gap between pickup coil and flywheel or wiring
  14. Michał 123
    Apr 29, 2021
    42
    Polska
    I have 2 flywheels, one is converted and the other is original on the original wheel, the spark is all the time it looks like flash welding and on the converted one, unfortunately, there is no spark, I need to have a magnet cover with coils on? is Magneto and impulstor enough?
  15. Ignas
    Ignas Adventurer
    Jul 21, 2011
    30
    Lithuania
    If you only change magneto and there is no spark, then just check the gap at pickup coil.
    I think somebody wrote in this thread, that gap needs to be reduced to 0.7 or 0.8 if i am not mistaken.
    How much did magneto machining job cost you?
  16. Michał 123
    Apr 29, 2021
    42
    Polska
    the gap between the pulser and the point on the magnet is max 0.2 for me and nothing resulted, the entire cost of rotor processing cost me PLN 100, which is about 25 USD
  17. Ignas
    Ignas Adventurer
    Jul 21, 2011
    30
    Lithuania
    You should be able to get a spark just by swiping with a screwdriver over pickup coil
  18. Michał 123
    Apr 29, 2021
    42
    Polska
    I think so too, I move the screwdriver and nothing happens there is no sparkit is on the original magnet, and there is none on the converted one and when I move it with a screwdriver, it is also gone
  19. Michał 123
    Apr 29, 2021
    42
    Polska
  20. jesusgatos
    jesusgatos fishing with dynamite Supporter
    Nov 17, 2006
    3,061
    santa cruz mtns, ca
    Nice work on that flywheel, hope you get it sorted out soon.
