705 rotation arrows
Discussion in 'The Garage' started by SKILLETDAWG, Sep 12, 2019.
  1. SKILLETDAWG
    SKILLETDAWG Adventurer
    Dec 21, 2008
    12
    NC
    Bought a set of Shinko 705s. The front 90/90-21 is the tire I am confused with. The tire has rotation arrows pointing at each other with the words Front and Rear below the arrows. (See pic) According to Rocky Mtn this tire is NOT the universal tire, but front only. They said to mount tire with Front arrow pointing to the front and Rear arrow towards rear of bike, (yep, I know). If mounted that way, you would be running over the top of the V groove tread pattern rolling towards the bottom point of the V. I know the contact patch is not that large, but it still seems like that is the opposite direction it should be rotating. Backwards to the way the rear tire is mounted. Which way have you 705 owners been mounting your tires? Thanks for explanations or help. 161F557F-DC18-4298-99EE-5B2408E6C058.jpeg
  2. vtduc
    vtduc Been here awhile
    Dec 25, 2006
    392
    Mount it the way the arrow states for the front. The grooves on the front always point opposite to the way they point on the rear, has to do with braking forces on the front versus drive forces on the rear. If you look at different tires on other bikes, they always follow the same pattern. Some folks will de-mount and reverse direction of a dual sport tire after it's half worn, to reverse the effects of "cupping" on the tread, but that's a different subject. Seems counter intuitive when looking at the front tread, but its all about the braking forces versus the drive forces as previously stated.
    LuciferMutt, Beezer and Bigger Al like this.
  3. Bigredwelder
    Bigredwelder Been here awhile
    Dec 31, 2016
    165
    Goodyear, AZ
    vtduc nailed it the way he described it. Just think about the forces they see. Since a picture is worth a thousand words, and I have 705's here you go. These are mounted the correct way.
    vtduc and dtysdalx2 like this.
  4. SKILLETDAWG
    Dec 21, 2008
    12
    NC
    Thanks vtduc and Bigredwelder, that’s the way they are going on. A friend just got a set and his are mounted just as you have said.
