'76 Moto Guzzi V1000 Convert refresh/reawakening after 28 years...!
Discussion in 'Old's Cool' started by radguzzi, Oct 27, 2019.
  1. radguzzi
    radguzzi The Journey is the Reward
    Feb 18, 2005
    6,828
    North East USA...
    Greetings all, new Convert convert here. I am actually a long time Moto Guzzi owner, rider, wrench (aren't we all...?) and first time Convert owner.
    This particular old boot, a '76 Moto Guzzi V1000 Convert sat dormant since 1991 indicated by the last registration. Actually seems to have been stored properly as bolting comes apart easily and the engine is not stuck... lol :lol3 Good start huh...?
    So '76 V1000 Convert barn find status:
    Great news, compression checks out well on both cylinders, nice blue spark from the Dyna III, lights work...
    The compression check was a little weird, the throttle cables are stuck so I could not open the throttles but I think it is a good reading. We can move forward now. Carbs come off and into the ultrasonic tub. Fluid changes, parts order for brake rebuilds, carb kits, hoses and cables going out.
    Getting excited...!
    EvilClown, ishmac, mb8 and 2 others like this.
  2. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    So the statement about the Convert having been stored properly may have been just a bit premature...
    I had mentioned that the throttle cables are stuck which made the compression check not as proper as it should have been.
    Popped the tops off the carbs and the slides are stuck along with the choke plungers... Ooops.
    They are soaking in Aerokroil. New fuel lines and dual spigot banjos to eliminate the weird cross over under the carbs will go back it.
    Looks innocent enough huh..?
    Stuck, soaking, thinking about what they have done... lol
    EvilClown and OV10 like this.
  3. lobsta
    lobsta Been here awhile
    Dec 1, 2009
    278
    Enter it in Owls Head show next summa.
    ps ,mileage?
    radguzzi likes this.
  4. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Yup, should be ready be then...! :lol3
    18K miles, I am fairly optimistic about the general condition of the engine and drive train. Not seeing any signs of having been molested, butchered or "customized" by previous owners, wiring is in good order, pretty cool really.
    This could be a good candidate for the EME EnDuralast III Charging system upgrade to support better lighting and heated gear.
    Cheers,
    rad__
    EvilClown and numbat like this.
  5. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Well I was able to coax the carb slides to move with the help of this stuff... Man, gummed up. It has been sitting since before the days of ethanol fuel so it is merely lacquered instead of what ever happens nowadays.
    So opened the carbs to clean them up and check the specs against Guzziology... Ha. Not yet. Nice huh...?
    This residue wipes off easily so an ultrasonic bath should clean things up nicely.
    This brilliantly designed "Balance" piping will go away, replaced by dual spigot banjos on the carbs and a single cross over to each bowl.
    EvilClown, mb8 and Cogswell like this.
  6. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    The first carb cleaning session in the ultrasonic. I use a mild mixture of Purple Power and water at about 50 Celsius. (122-ish Fahrenheit.)
    Most impressed with the bowl and carb body results, I will run the small parts separately 'cause the solution needs changing, kinda filthy.
    Before...
    After...
  7. SuperRat
    SuperRat No Longer Lurking
    Jul 10, 2011
    112
    Turn off the paved road
    No chrome bore cylinders I hope!!!!!
  8. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    No sir, iron...
    #8
  9. huub
    huub Been here awhile
    May 11, 2012
    519
    great find, looks like a time capsule.
    i'm not too sure i woul keep the windjammer, but this is how most of them were in the days.
    #9
  10. usedtobefast
    usedtobefast Been here awhile
    Nov 12, 2007
    288
    SF Bay Area
    So how did you find it?
    #10
  11. EvilClown
    EvilClown Standing by to standby for a possible disregard Super Moderator
    Sep 3, 2006
    19,992
    In the shadow of the Uncanoonucs...
    Following along...taking notes...:D
    :lurk
    #11
  12. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Yeah, it will stay, the mounts are a pain to swap out and the headlight would need to be rewired. Not a big ta-do but I'll just leave it on. Until I hate it... :lol3
    A friend had it advertised and I hashed it over for the longest time and finally jumped in... He had bought the V1000 from someone near him and then health issues stopped him for proceeding.
    #12
  13. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Seriously EC...? I should be following you with that gorgeous Convert of yours... so I guess I am really. I'll take notes too. :-)
    #13
  14. Cycle Goon
    Cycle Goon Been here awhile
    Sep 16, 2016
    856
    I ****DESPISE****** Windjammer fairings but I actually don't mind it on your bike??? Maybe because the color of the bike and fairing are pretty close? Or, maybe I hate them so much as my dad had a 77 Goldwing with a white one and I currently have a 74 GT750 that's blue with a white fairing-barf!!!!
    If this bike comes out as nice as the Commando you gave a refresh to, it will be something really special.
    #14
  15. EvilClown
    Sep 3, 2006
    19,992
    Perhaps you should put the tools down...right now...and go get your eyes examined.:lol3
    #15
    mb8 likes this.
  16. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Yup, period fairing, ya either love 'em or hate 'em. It really must stay, I like weather protection, we live in the North East, that should explain it all.
    And thanks for the comments however, this is going to be a mechanical refresh only, Not going to be a cosmetic restoration, the patina is perfect (for me), no frame off here. :nono
    Pretty excited that there are no leaks or weeps from the ATF hose fittings which can be troublesome on these. It does have the early ('75-'76) flywheel that hopefully holds together, its a crap shoot. If the engine performs well then perhaps I will consider a tear down to replace it.
    Not that one ya bonehead...! We know you passed on that boat anchor... You're not right ya know that...? Wouldn't have it any other way.
    #16
  17. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    So while we are on the intake side of things...
    The stock air filter and housing are in place, miraculously no rodents or traces there of. I am actually a fan of stock airboxes, still air to be introduced to the intake, reasonably free of dirt and moisture however, I really do not like the design of the mid 70's airbox. Ridiculous to get at to change the filter element.
    Thinking seriously about swapping for the dual mount K & N filter. It sort of replicates the structure of the stock intake box, attaches to both carbs. But, and this is a big but... rejetting may be required to suit the different filter. Plus, and this is the big one, the crankcase breather system will need to be addressed.
    Easy enough by installing the LeMans breather box and pipe the valve cover vents to it...
    I'll figure it out but again, still on the fence. In a preliminary inspection of the carb innards, I find that the Main Jets are 125 vs 130 called for stock, according to Guzziology.
    After all bits are cleaned I will check the specs to see what else may have been swapped. Always an adventure when following others with no documentation, part of the fun.
    More later,
    rad
    #17
    mb8 likes this.
  18. EvilClown
    Sep 3, 2006
    19,992
    :nah
    Woulda sent it your way if I had.
    :lurk
    #18
  19. radguzzi
    Feb 18, 2005
    6,828
    North East USA...
    Really... my mistake, :fpalm I thought you passed on that when the red one showed up.
    So I didn't mean to poop on that one but Wow..! Gonna be a project for sure... or just make it a sleeper and keep the patina. :1drink
    Let's see a photo of the red one.
    #19
  20. jay pc
    jay pc Been here awhile
    Jun 28, 2019
    427
    Ardenne
    From one fan to another, for Pete's sake don't go ditching that airbox, you know it manages engine breathing better than
    anything else on these bikes, and the air filter change is a non-issue, as something else will surely go wrong and force you
    to crab the frame long before it needs changing (they look like new after 50.000 km)!
    I'm running a '79/ 300.000 km T3, and following this with interest, as Converts have always intrigued me.
    I hope you'll eventually report on what it's like to ride it...
    #20
