77RS has to go - just got it too…
Discussion in 'Airheads' started by Trpldog, Sep 1, 2021.
  1. Trpldog
    Trpldog Been here awhile
    May 29, 2011
    230
    Rancho Cucamonga
    I can dig it. Been a sport bike guy since 1974. Moved to higher bared naked bikes around 2000 - multiple Speed Triples, Buell XB’s, a ZRX1200 etc. the old gray mare ain’t what what she used to be - ha ha.
    ccmickelson likes this.
  2. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    3,146
    Fanta Se
    Damn, that’s a beautiful bike.
    Kiwiabbo likes this.
  3. reinhardhardegen
    reinhardhardegen Been here awhile
    Feb 19, 2015
    133
    Arizona
    I don't see the problem. I think I'd have this in a prenup if I was married.
  4. Trpldog
    May 29, 2011
    230
    Rancho Cucamonga
    Ha ha - excellent!
  5. Derek_S
    Derek_S Been here awhile
    Nov 13, 2015
    623
    Charlotte, NC
    I need to know more about the black one. The shortened seat assembly is something I have long thought about but never seen done. Looks fantastic, there.
  6. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,580
    Taihape New Zealand
    Message me with any questions.....happy to answer
  7. Trpldog
    May 29, 2011
    230
    Rancho Cucamonga
    Update on selling the RS. I’ve taken the ads down. I’ve been riding the RS more and more, and I am in the process of doing all I can do to acclimate and conform myself to the RS. The shifting issues I was having at the start of ownership has become pretty much a non issue now that I’ve come to learn the shifting technique and I’m really growing quite attached to this quirky critter as time goes on. I really want to make this relationship work, because I really like the looks of the RS. While I’m currently looking for a pair of K75S bars, I have ordered a RS seat cover and will have a local auto upholstery guy cut the foam and build a stock seat for me. The PO had installed a very low seat that desperately needs changing. I’ve noticed that when I sit up higher, the wind noise starts to diminish. I’m hoping that between getting the higher stock seat and installing different bars, and possibly a modification or changing of the windscreen, the roar will be lessened and the riding position more comfortable for me. If I can get the riding comfort close as possible as to how good the RS looks, I will be one happy camper. Thanks.
  8. Derek_S
    Nov 13, 2015
    623
    Charlotte, NC
    Congrats, I hope it works out. I have also read about people cutting the little re-curve lip off the top of the windscreen with good results, plus it still looks pretty 'stock'. Yours looks very, very tidy except for the hideous seat. If it has the original heavy flywheel the shifting takes a good bit of getting used to. It took me 18 months to almost master mine, and I still stumble on the downshifts occasionally. I also recently installed new Pilot Activ tires and upped the pressure to 34f/38r and she now handles much better than before.
  9. Trpldog
    May 29, 2011
    230
    Rancho Cucamonga
    I’d like to cut the top lip off also, but not sure the best (safest) way to do it. I’m thinking of cutting it slowly and gently while it’s still on the bike by hand following a line of blue painters tape. Any suggestions as to a proven way of cutting?
  10. Derek_S
    Nov 13, 2015
    623
    Charlotte, NC
    I don't have a suggestion, but I'm sure someone will. If I were taking an uneducated whack at it I'd be tempted to use a fine tooth jigsaw and cut very slowly. I'd probably cover the whole thing in a contact paper or something to protect the lexan, and tape the edge as you mentioned. The stock RS has this welted rubber edge that will cover minor imperfections, so at least you have that (if you are going for the stock look).
    [[​IMG]
  11. Derek_S
    Nov 13, 2015
    623
    Charlotte, NC
    A lot of modern windshileds have a U shape, or horseshoe, with the edges peaking higher than the center. It won't look stock at all but I have been super curious what a shape like that would do on the bike. If I had the means it would be fun to vacuum form some cheap plastic replicas and just experiment with them, cutting them differently just to see how they affect the air.
  12. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,744
    Pocono Mountains, PA
    What happened to your side panels? If you lost the R one, Solo Lobo has a set in the FM.
    Glad to hear you are giving it the time and effort it really deserves. Even if you do pass it on eventually, the decision to do so will be more solidly grounded.
  13. Trpldog
    May 29, 2011
    230
    Rancho Cucamonga
    I have the side covers, but they need a fresh coat of paint. Now I have incentive to finish them up.
    Jim K in PA likes this.
  14. OldCrustyStuff
    OldCrustyStuff Adventurer
    Jul 19, 2021
    69
    Normal, IL
    Fwiw - I messed with cutting mine and had some luck with painters tape and a dremel cut off wheel - finished by sanding.
    That being said I didn’t absolutely like my result so ordered a std height from Clearview and had THEM cut it down 2” - seems to be working very nicely in addition to k75S bars
    Good luck!
  15. Trpldog
    May 29, 2011
    230
    Rancho Cucamonga
    Got it. Worse case, I will pick up another windscreen. Looking for K75S bars.
  16. korinthias
    korinthias slightly behind the curve…
    Apr 29, 2019
    360
    Devon, UK
    Motorworks UK have the K75S bars in their ‘Used Parts’ shop – not particularly cheap for a used part, but I understand their shipping to US is reasonable and quick:
  17. Derek_S
    Nov 13, 2015
    623
    Charlotte, NC
    OldCrustyStuff likes this.
  18. AlfromNH
    AlfromNH Been here awhile Supporter
    Jul 21, 2013
    733
    NH, USA
  19. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    3,050
    Arkansas Ozarks
    If not mentioned, you might also try a standard style seat--it may offer some difference in the seating position that helps your comfort level.
  20. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,173
    I cut my windsheild with a jigsaw and a coasre metal cutting blade. Couple strips of blue tape on the plastic and on the entire sole of the jigsaw. Helps to be good with the jigsaw and go with a low blade speed.
    The stock windsheilds are very UV sensitive. At 5000' I get cracks in about 2 years no matter what I smear on them.
