790/890 Adventure / R / Rally owners, show yours!
Discussion in 'Parallel World (790/890)' started by a.c.e., Apr 17, 2019.
  1. kaptinkaos
    kaptinkaos Just some nOOb
    Mar 9, 2008
    1,209
    Red Deer, AB
    Have a look up behind the rad where the thermostat is. I *think* it was the hose clamp into the thermostat, but may have been the front bolt on the thermostat itself. It did require some disassembly, but I did not drain coolant or pull the rad. Get a small 1/4" ratchet with a 8mm bit or a ratcheting 8mm spanner and you should be able to tighten them. While in there, give every hose clamp (6mm) a couple turns to sung them up. Heat cycles make rubber softer and when they build these bikes they don't have time to heat cycle and re-tighten everything.
    OneAUout and David_Moen like this.
  2. kaptinkaos
    Mar 9, 2008
    1,209
    Red Deer, AB
  3. David_Moen
    David_Moen Long timer Supporter
    Apr 23, 2006
    2,172
    Salmon Arm, B.C. Canada Eh!
    Thanks, I haven't had the tank off myself yet, but it's raining today, so a bit of a garage sesh might be in order. The problem with taking it to the dealership for this is that by the time I get there, everything has warmed up and is dry so they really don't know where to look.
    kaptinkaos likes this.
  4. kaptinkaos
    Mar 9, 2008
    1,209
    Red Deer, AB
    Tank off is pretty simple. Close both petcocks, remove both breather hoses from top, take off fuel crossoverline (have a can or jug for the spillage), pop off fuel line from the top left side (watch for that little green keeper so it doesn't fall out), remove fuel sender connection and fuel pump connection from the bottom of each side, then just the four bolts that hold the tank to frame. They are 2 piece rubber grommets on them so usually the bottom/inside halves I find after pulling the tank.
    While you have it off, check the vent lines going in to the carbon filter/smog box on bottom right side. Both of my vent lines going in were pinched right shut and not routed properly. Musta been a friday build. The tank wasn't venting at all so it would literally pop when I opened the gas tank to fill it.
    Edit* - The other problem with dealers is they usually fark something up or cause another issue. Some are good, most I avoid just out of not wanting to have to deal with aftermath of someone else's poor mechanic skills, lol!
    OneAUout likes this.
  5. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,782
    Star Tannery, VA
    That's gross dude. Is that from mileage or a destroyed clutch? On the bright side, your shifting will probably be a whole lot smoother with fresh oil.
  6. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,810
    Jacksonville, FL
    Lol...
    I go through clutches like underwear or cannolis.
    Currently doing a motor medic motor flush.
  7. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,810
    Jacksonville, FL
    Picked up a back up just in case though...
    cjracer, Cowtowner and David_Moen like this.
  8. windblown101
    May 17, 2010
    8,782
    Star Tannery, VA
  9. David_Moen
    Apr 23, 2006
    2,172
    Ha! Awsome, think of all the new stickers you get to collect!
    Dan D. likes this.
  10. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,810
    Jacksonville, FL
    Lol...
    I wouldn't buy another one of these pieces of shit. :p
  11. Some_Dude
    Some_Dude Been here awhile
    Jun 23, 2019
    858
    Thunder Bay
    One of those moments where the camera fails to capture the sheer scale of things.
    STLR, SPop75, alonad and 6 others like this.
  12. kaptinkaos
    Mar 9, 2008
    1,209
    Red Deer, AB
    Looks familiar... Rocky area? Or further south?
  13. Some_Dude
    Jun 23, 2019
    858
    Thunder Bay
    Some cut line I found just north of Thunder Bay.
    It’s one of the cool things about this area. I can ride 10 minutes and find shit that would take me 4 hours to find outside Edmonton.
    Kthursto and kaptinkaos like this.
  14. kaptinkaos
    Mar 9, 2008
    1,209
    Red Deer, AB
    HA! I thought that was an AB plate... That's a pretty awesome area there and I agree... Deadmonton is brutal for scenic riding stuff. Should try heading south though, anything west of Hwy40 pretty much the length of AB is amazing.
  15. Mudguts
    Mudguts when in doubt GAS IT
    Jan 16, 2006
    2,738
    Some were in , lostralia
    A quick ride before I go into a 2 week quarantine interstate , haven't been on the bike in weeks , been cold wet and devastating storm damage in my old neighbourhood
    alonad, OneAUout, kaptinkaos and 4 others like this.
  16. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,803
    On the Ground Laughing
    Shit year for you bud... better days ahead
    TrailTrauma likes this.
  17. Mudguts
    Jan 16, 2006
    2,738
    Getting paid to sit in a room and scroll through ADVride all day order stuff from Rottweiler performance and game on the playstaion, ain't too bad !!
    comradecasey, TrailTrauma and Nowwhat like this.
  18. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,614
    Melbourne - AU
    Plus order in more sticker kits!.. Bike looks fit Mudders!,
  19. djauofd
    djauofd Aged Wine
    Sep 10, 2014
    107
    Annapolis sailing capital of the world
    I had Warp9 make 17” wheels for my 790 Adv R . Just ordered a 1290 Carbon front fender for my 790 . It will take making some custom bracket to make it fit. But taking off the high fender makes it into a different looking beast. IMG_2627.jpg
    bikemoto and kaptinkaos like this.
  20. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    994
    Dallas, TX.
    Yep, its a different looking beast.
    CB734 likes this.
