790 Adventure Decat/Tune Results
Discussion in 'Parallel World (790/890)' started by turbofan790, Nov 5, 2019.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,503
    Here and There
    @turbofan790
    Can you post a pic of your bunghole?
  2. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,048
    SC
    It's probably got a bungplug in it...
  3. braaap!
    Mar 16, 2005
    4,503
    Here and There
    Interested to see where Rottweiler positioned it ;)
  4. turbofan790
    turbofan790 Been here awhile
    Jul 16, 2019
    186
    Southern California
    Photo of bungplug plugging bunghole:
    ramirin, Toddv, CaseyB and 2 others like this.
  5. braaap!
    Mar 16, 2005
    4,503
    Here and There
  6. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,753
    Ontario .. Superior
    Well, that all worked out better than I had imagined :photog
  7. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,048
    SC
    Lol. Almost like we're all grownups!
  8. turbofan790
    Jul 16, 2019
    186
    Southern California
    Don't call me that
    ramirin and CaseyB like this.
  9. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    9,194
    The Delta Ghetto, GA (aka PTC)
    braaap! likes this.
  10. turbofan790
    Jul 16, 2019
    186
    Southern California
    CaseyB, Becko, braaap! and 1 other person like this.
  11. kubcat
    kubcat Been here awhile Supporter
    Sep 22, 2016
    691
    Upstate NY
    :kat
    You were saying...?
    braaap! likes this.
  12. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    550
    Norway
    Whats going into that bunghole? (i had to)
  13. braaap!
    Mar 16, 2005
    4,503
    Here and There
    An AFR sensor... gently... but firmly...
    tshansen likes this.
  14. TrailTrauma
    Jan 17, 2012
    4,753
    Ontario .. Superior
    Brass, minus the ballz..
  15. ramirin
    ramirin Ready to push
    Mar 25, 2008
    640
    FIN
    I think I have seen an install video on the web where they mounted a plug into bunghole as well as another similar into air intake. The system self-adjusted to use spare air intake on top of the main one and there was third plug going into intake manifold. But in the end it all 'exploded' so something must have gone wrong. No motorcycles were hurt in this video :lol3
  16. ramirin
    Mar 25, 2008
    640
    FIN
    I was thinking about autotune too but talked with a dyno guy who asked what I was after, I told I wan't to tune a reliable setup and then just ride ever after. He suggested only mapping for me and autotune only if I wan't to constantly try different setups and/or otherwise tune all the time.
    Ordered pcv and going to dyno later when bike is otherwise good to run.
    TrailTrauma likes this.
  17. turbofan790
    Jul 16, 2019
    186
    Southern California
    That was my thought as well. In reality, as I think about it more, autotune really shouldn't increase fuel efficiency much over this race tune, just make the tune a little more optimal in all conditions/all elevations and give you the AFR display so you can see where it's running at all times.
    The fuel efficiency comes from it running extremely lean on the stock tune. The PCV tune fixes this extreme lean condition, also reducing fuel economy.
    I expect a more efficiency-minded decat tune could be produced by allowing the tune to remain lean at smaller throttle openings, tapering to richer under greater load. I assume the PCV has this capability, but haven't reached out to Rottweiler about it yet.
    Another full tank gone, another 39 mpg tank. Hurts a bit.
    ramirin and braaap! like this.
  18. TrailTrauma
    Jan 17, 2012
    4,753
    Ontario .. Superior
    The auto tuner I have on my HOG constantly modifies 2 separate maps. One is performance, and the other eco. The tuner watches how I ride and knows if I am on it, or just cruising. Then after I cycle off the key and back on it tweaks about 5% of those 2 maps, slowly over time, optimizing each. Different perhaps than the PCV, as my tuner completely replaces the OEM ECU. I also had to install O2 sensors. But if PCV could switch between 2 maps which it has optimized for the specific rider, that would be mint.
    ramirin likes this.
  19. jtriver
    jtriver n00b
    Jul 22, 2009
    5
    hi nowwhat, just wondering what stock header oxy sensor (bung) you threaded the Dynojet autotuner wide band sensor into? does it matter?
  20. turbofan790
    Jul 16, 2019
    186
    Southern California
    He didn't. It's an additional bung, pictured above on my bike.
