790 Adventure Quickshifter - Yes or No?
Discussion in 'Parallel World (790/890)' started by CalamariKid, Dec 14, 2019.
  1. krussell
    krussell Gravel Warrior
    Nov 19, 2009
    4,451
    Portland, Oregon
    I've described the 790R quickshifter as the best I've had, better than the 1290SAR and GSAs. It was flawless AFAIC. That was until my last ride to the dealer, which is around 30mi one way. It just wasn't as good as it had been. I missed a couple of shifts, either too early or too late, and it didn't seem 'right.' I got home and was thinking about a bit when I reached down to take off my boots. All my rides to date had been with Forma Adventures, my go to boot. But I planned to do quite a bit of walking while waiting on the dealer to replace my TFT on this trip, so I wore my Bates boots. They aren't motorcycle boots, have less sole, and are much thinner on top. Enough that they end up being quite a bit lower in relation to the shifter. Yesterday I put my Forma's back on, took a ride and the QS was back to its best I ever had status. So, more of the long story is if it isn't like butter for you, maybe try adjusting your shifter height. ymmv.
    undingen and SCPancho like this.
  2. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    702
    Hood River, OR
    The QS does take some time to get used to. For quite a while I couldn't get it to downshift smoothly. What I discovered was that I was booting the shifter a little too hard. I've found if I just put light pressure on it, it blips the throttle and downshifts very smoothly. I love it off-road hauling into a corner as it's very easy to bang down a couple gears very smoothly.
    Up shifting is generally pretty good, though the lower gears aren't as smooth unless I'm on the gas.
    I have ridden a 790R without the QS and it didn't have the "secret QS" apparently. While it would upshift ok without the clutch, like most any motorcycle, it definitely didn't like going down. If you push down lightly on the shifter and you don't notice a throttle blip, you don't have the QS.
    brunosac likes this.
  3. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,362
    SC
    The QS may need calibration in the ECM if it's not working propery. Mine does, the downshift blip happens on a hair trigger but the ignition doesn't cut until I have a fair amount of pressure. I can see that the magnet is off center on mine but there's no way to adjust it. I haven't payed for the QS so I doubt they'll calibrate it for me, they may not even be able to. Lol
    JP4 likes this.
  4. Hedonist222
    Hedonist222 Been here awhile
    Jul 25, 2014
    915
    Dubai,Abu Dhabi, United Arab Emirates
    I just checked with a KTM manager
    He said up and down shifting is stock = KTM QS
    QS+ is the ability to turn off of QS
    it makes no sense in any world to put a feature on for free then ask a hefty sum to turn it off
    I think what windblown says is correct
    quick shift up was free in stock form = QS
    QS+ = was supposed to be a paid feature (to have quick shift down and ability to turn off)
    now the dealer says QS+ is a paid feature to turn it off
  5. BobcatSig
    BobcatSig Fresh Off The Couch Racing
    Aug 15, 2014
    4,239
    Protestlandia, OR
    Nope. QS+ is clutchless up and down shifts. With it comes the ability to turn it off.
    If you did not opt for QS+, you would get only clutchless upshifts. No clutchless downshifts.
  6. el Pete
    el Pete toda su base
    Mar 3, 2009
    1,805
    colinas del norte, california sur
    I did not purchase the QS just based on the price. Seems neat, but not $300 neat.
  7. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    16,579
    SF Bay Area
    I did not opt for QS+. I got both UP and DOWN quick shifting. I did not get the option to turn it off. I must admit I initially thought it was UP only. Then I accidentally downshifted without the clutch. Hmmm, no grinding. Further experiments proved that the bike has both UP and DOWN enabled. 2019 standard model.
  8. sluagh
    sluagh not fade away
    Dec 7, 2019
    448
    USA
    Yep. It's definitely both ways on mine and I didn't pay for it. If I push down on the shifter very carefully I can make the rpms drop without downshifting.
  9. MondayDad
    MondayDad Been here awhile
    Jan 22, 2013
    126
    Indiana
    I rode a 2020 model a week ago and going from 3 to 4 was anything but smooth. In higher (4 to 5, 5 to 6) it was smoother, but still didn't feel like something that was designed to work...
  10. braaap!
    braaap! Long timer
    Mar 16, 2005
    5,662
    Melbourne - AU
    Then it's setup incorrectly. Believe it or not, my 2019 QS, shifts up cleanly at low revs from 1st to 2nd and up through the box... Specially glorious when accelerating, hard on the gas :)
    brunosac and 1coolbanana like this.
  11. BobcatSig
    Aug 15, 2014
    4,239
    Protestlandia, OR
    The more revs, the better. On downshifts, you need to be below a certain rev limit as to not grenade the engine.
  12. ZIEN BARON VON SUPERDUKEN
    ZIEN BARON VON SUPERDUKEN Been here awhile
    Aug 27, 2016
    393
    Who da ho? IDAHO...!
    I used a QS on sport bikes during track days primarily. Not sure how much I'll use it on this one.
  13. Hornblower
    Hornblower Been here awhile
    Nov 7, 2019
    162
    Clemmons, NC
    Maybe mine is still not working 100% but more revs definitely doesn't make it shift better. When QS was first enabled by my dealer, this is what he told me as well but it was more like speed shifting which doesn't even require electronic QS. After that, I went to another dealer to get it working better and with KTM's technical help, they got it working satisfactorily. Still, shifting in the lower gears isn't completely smooth but downshifting is great and, of course, using QS off road is fantastic.
    braaap! likes this.
  14. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,844
    NW Sydney, Australia
    The tech told me when I bought the bike that if not setup properly (by them) it was crap, he spent a bit of time and mine was great......until it was serviced and dash replaced and now its not so great.
    Will get them to sort out next visit.
  15. braaap!
    braaap! Long timer
    Mar 16, 2005
    5,662
    Melbourne - AU
    Yeah I've clumsily banged down 2 gears and had the rear lock up and step out big time, just caught it with the clutch. Gearbox still works though :)
    As Clarkson has said, 'a little bit of poo came out'.
    BobcatSig likes this.
  16. Some_Dude
    Some_Dude Been here awhile
    Jun 23, 2019
    858
    Thunder Bay
    I like the QS. Between it and the slipper clutch I can get pretty aggressive and still keep the bike rubber side down.
    At the end of the day it’s just another tool in my toolbox.
    JP4, TrailTrauma and BobcatSig like this.
  17. Mud Bucket
    Mud Bucket 60% of the time I'm right every time
    Aug 9, 2007
    359
    North Vancouver,B.C, Can
    I just had my 1000km service a month ago and bought the QS. Was a little skeptical at first but powering up and shifting changed my mind pretty quick. For me its smooth and going up or down is easy.
    I give it a thumbs up.
    TrailTrauma, JP4 and BobcatSig like this.
  18. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    702
    Hood River, OR
    Exactly. For me it's not an either or thing. While I use it intermittently on the road, off road I use the QS almost exclusively. I ride off road standing up most of the time, and it's nice to be able to just click through the gears, especially when I inevitably find myself coming into a slippery corner too hot.
  19. railduke82
    railduke82 Adventurer
    Jul 10, 2016
    10
    The quick-shift doesn't show on my dashboard menu. Supposedly the dealer downloaded the software. I've shifted it up and down without the clutch and it's clunky at times. I had a Tuono with a quick-shifter that was smooth as butter. I'm wondering if it's even installed and I'm just banging the gears like a dirt bike?
    JETalmage likes this.
  20. marchyman
    Jun 30, 2005
    16,579
    SF Bay Area
    Clunky in what gears and at what RPM? I find 1 -> 2 clunky mostly due to the RPM difference between the two gears. From 3rd and up is fine, especially when shifting under load at higher RPMs (4K or higher). Downshifting seems to be smoother at lower RPMs. I use it for upshifting much more than I do for downshifting, but that's probably just the way I ride. I haven't ridden another 790 so can't say if my bike is typical or different.
