790 Adventure R - Front Brake Issue
Discussion in 'Parallel World (790/890)' started by tshansen, Oct 5, 2019.
  1. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    558
    Norway
    Hello inmates.
    I have continue my search to find out what is wrong with my front brakes when I wait for answers from my mechanic and from KTM.
    I have double checked that the rotors are Clean and has same amount of play in all directions.
    I had I friend telling me he noticed difference in his breaks in STREET and OFFROAD mode... Like the pulses from the ABS are shorter between on STREET mode.
    For me, I did several test stop's in 40km/h and 60km/h on gravel and tarmac but with the same result. No noticeable difference?
    So, is anybody else here having the same issue? can it be more to the brake issue than just F up rotors?
    ibgary likes this.
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    5,603
    Star Tannery, VA
    When I first had the front brake "Pulse" issue at low speeds my dealer cleaned up the rotor surfaces and also resurfaced the pads and the problem completely disappeared for a short time and then returned. Nothing in my case has indicated this is an ABS issue. It seems more like an uneven material build up on the rotors. I've got new pads sitting on the shelf and will probably give them a shot after going over the rotors with a scotchbrite pad and see if the pulse goes away again. If it does and then returns I'll probably look for a single after market rotor and go ahead and use that as an excuse to convert to a single front caliper set-up.
    tshansen likes this.
  3. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    29,953
    Nippon
    Well if its just a pulse that isn't affecting lever travel its likely just bedding. You can fix this by going over the rotor with a scotchbrite and brake cleaner. Then properly bedding the brakes.
    The other thing to check is run out, on the 1290s there were manufacturing issues that the surfaces that the rotors mounted to weren't totally parallel to the axis of rotation, this would cause hot spots at a couple of places and a pulse much like you are describing.
  4. tshansen
    Feb 9, 2015
    558
    Norway
    Anyone know what rotors i should go for and which one fit's the 790?
  5. Tripped1
    Aug 6, 2009
    29,953
    Nippon
  6. dtaski
    dtaski Been here awhile
    Sep 17, 2009
    125
    Harrisburg , PA , Long Neck DE
    I have 2300 miles on my R and the pulsing is driving me nuts. Dealer said the rotor is warped , KTM will not replace under warranty. I cleaned the bobbins thoroughly. Pulsing was fixed for about 5 miles of stop / go then came back. I might remove the pads and clean then. Any other suggestions ? ( besides replacing the rotors)
  7. ndavis
    ndavis Been here awhile
    Jan 22, 2013
    580
    Putnam Ct.
    Mine are warped bad, dealer can not get replacements so I will keep riding it until they can get replacements.
    Also fuel gauge reads empty all the time now.
  8. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,679
    Colorado
    I read that greasing the pins the brake pads are mounted on will help. I notice it on mine mostly at low speed. Low teens. If I release the front brake (around 15 mph) and stop with the rear I don't notice it.
    It's not bothering me enough to change the pads yet, but when I pull the wheel for a new tire I'll put in New pads with harder material and lub the pins at the same time.
    #8
  9. tshansen
    Feb 9, 2015
    558
    Norway
    Mine is getting picked up on Monday. Going to the local shop to get new disc's, pads and break fluid on warranty! Great to have a local shop that support you.
    #9
    ibgary likes this.
  10. kubcat
    kubcat Been here awhile Supporter
    Sep 22, 2016
    714
    Upstate NY
    Yeah. I wish I did. Going to borrow a friend's trailer this morning and take it to the nearest qualified dealer 90 minutes drive away for the fuel tank sensor replacement. Probably also have them look into the repeat start problem while they have it.
    #10
  11. hcd
    hcd Adventurer
    Nov 8, 2019
    15
    30161
    Taking mine next week for the front brake and rally mode stuck 8 slip control, I've got the repeat start too. Service manager sounded disbelieving on the front brake, can't wait to see him come to a slow stop on it.
    #11
    ndavis and tshansen like this.
  12. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,679
    Colorado
    How many miles? I had the false start issue a few times, maybe a dozen or so times. It hasn't happened in about 2 months now. I'm coming up on 9k, my service light came on yesterday, I've started it a few times in the 30s*. The false start just seems to have gone away.
    I'll probably take it in this week for the service and have them check the front brake and mount a new rear tire. I know the service is easy, but over the yrs I've made it a policy to have service done by the dealer while it's under warranty.
    #12
  13. kubcat
    Sep 22, 2016
    714
    Upstate NY
    Mine seems to start on the first try if it's below 50 degrees. I told the dealer to leave it inside overnight before testing.
    #13
    windblown101 likes this.
  14. Roadhawg011
    Roadhawg011 Been here awhile
    May 25, 2015
    457
    South Africa
    Try banging on the Tank where the fuel level sender is. Happened on the 1X90s sometimes as well. The float just gets stuck.
    #14
    ibgary likes this.
  15. ndavis
    Jan 22, 2013
    580
    Putnam Ct.
    Could we spell brake properly in the title of this thread?
    #15
  16. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,423
    Cremona, Italy
    We could.
    Can you spell brake in Norwegian?
    #16
  17. tshansen
    Feb 9, 2015
    558
    Norway
    I dont have admin rights. Sorry, my english grammar is poor
    #17
    Pipeman, Toddv and ibgary like this.
  18. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,506
    Here and There
    @tshansen .... I reckon your english is excellent, have enjoyed your vids and lanscapes :thumbup
    Hope you can get your brakes sorted quickly!
    #18
  19. tshansen
    Feb 9, 2015
    558
    Norway
    Thank you :-D English is my second language so there is some grammar and spelling fault, but i think that is part of the charm :p My bike should be back today. I need to get it transported because of the snow and ice here. Will make a quick update video about the changes etc :-) Thank you for the support
    #19
    Beeners and Beshar like this.
  20. braaap!
    Mar 16, 2005
    4,506
    Here and There
    Cool, look forward to your update.
    English is my first language and I can’t even spell ‘landscapes’ ;)
    #20
    Sfcootz, CaseyB and ibgary like this.
