790 Adventure R rear shock failure
Discussion in 'Parallel World (790/890)' started by [Art], Oct 19, 2019.
  1. Torque
    Torque Been here awhile
    Apr 4, 2006
    582
    San Diego
    When the fluid is lost so is the nitrogen pressure against the seal head as the reservoir piston bottoms out.
    This allows the seal head, one of the two items that keeps the shock shaft centered in the shock body, free to float up and down inside the shock body.
    The seal head can clunk as it tops out. But now that you mention the secondary piston I guess it is possible for the seal head to stay with the secondary piston. This would reduce the centering effect on the shock shaft and may allow the piston to make contact with the bottoming cone. Not sure? But it is common to get the clunk from seal head. Guess you will find out as soon as it comes apart.
    #61
    braaap!, markverCA and EvilSteve like this.
  2. Alpha 1
    Alpha 1 Adventurer
    Aug 31, 2011
    91
    St George, UT.
    just got mine back, WP rebuilt the shock all I could get from the dealer was Rebuilt with up dated parts was hoping they would give me some better info.
    #62
    Colorado Uli, braaap! and markverCA like this.
  3. markverCA
    markverCA n00b
    Nov 6, 2018
    8
    Modesto, CA
    Thanks for the update Alpha 1. How long did WP take to return your shock? Also did they extend a new warranty period? I've heard some of the rebuilds have failed in very few miles.
    #63
  4. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,345
    Melbourne - AU
    Yeah, it would be good to know what ‘updated’ parts are / means... Maybe there will be a recall / tech bulletin issued down the track?
    Will await further developments (my shock is all good for now)
    #64
    TrailTrauma likes this.
  5. Alpha 1
    Alpha 1 Adventurer
    Aug 31, 2011
    91
    St George, UT.
    It took about a week from when i was told it was being shipped out to be rebuilt until the dealer called for me to pick up, my dealer had the bike about 2 weeks with KTM telling them that no rebuild kits or replacement shocks were available, I called KTM customer service and had a call back the same day saying that it was going to ship out for rebuild, got to say I was surprised they actually called with a answer so quick.
    did not ask about a extension on warranty.
    #65
  6. markverCA
    markverCA n00b
    Nov 6, 2018
    8
    Modesto, CA
    Torque, Thanks for your work on this issue! Great tips, following now to find some solutions.
    #66
    braaap! likes this.
  7. trapperj
    trapperj Been here awhile Supporter
    Mar 6, 2011
    775
    Knoxville, TN
    Just went over 600 miles. After 3rd ride I had a small puddle of clear liquid under the rear bash plate. Didn’t think too much of it. Then after yesterday’s longer harder ride (all blacktop) there’s a much bigger puddle underneath. It’s clear. Can’t see exactly where it’s coming from. Is this likely the shock? Damn. Thought perhaps I was a luck one. :(sigh
    #67
  8. markverCA
    markverCA n00b
    Nov 6, 2018
    8
    Modesto, CA
    Mine just dripped onto the catalytic converter and rear fender well, couldn't tell what color it was. However the dust and dirt will collect up by the shock spring and seal areas. If enough oil has been lost the shock will clank when bouncing on the bike in the garage...
    #68
  9. markverCA
    markverCA n00b
    Nov 6, 2018
    8
    Modesto, CA
    I just got my rear shock back, KTM/WP rebuilt the shock under warranty. WP has a 3 day turn time for repairs, plus 3 days shipping and 3 days return shipping, so total time +-10 Days. My Modesto, Cal KTM dealer provided excellent service and all was covered under warranty.
    #69
  10. Knolff
    Knolff Adventurer
    Nov 16, 2016
    30
    Here is a look at my shock, took about 1,000 miles to get to this point. Repaired under warranty, about the same timeline as @markverCA
    #70
  11. markverCA
    markverCA n00b
    Nov 6, 2018
    8
    Modesto, CA
    Are you saying you already had it repaired and it failed again with only 1,000 miles?
    #71
  12. trapperj
    Mar 6, 2011
    775
    Knoxville, TN
    Well I had thought at some point I’d replace the spring for my weight. Nows a good time to do that I reckon. I’m probably 225-230 with full gear. Any idea of a part #? Would it be just
    One size up or more?
    #72
  13. Torque
    Apr 4, 2006
    582
    San Diego
    2 rates minimum.
    #73
    trapperj likes this.
  14. Knolff
    Knolff Adventurer
    Nov 16, 2016
    30
    No, only failed once...I was just indicating that I experienced approx. the same turn time as you for the repair.
    #74
    markverCA likes this.
  15. trapperj
    Mar 6, 2011
    775
    Knoxville, TN
    Turns out, I am wrong. My 790 was leaking coolant. I reckon I assumed that since so many others had the shock failure that it was my problem too. A screwdriver and a few turns on the clamp @ the thermostat & it appears it’s all good.
    As always, this forum rocks. Thanks all.
    I still want/ need a heavier rear spring though!
    #75
  16. Colorado Uli
    Colorado Uli Must I? Supporter
    Feb 6, 2006
    5,038
    Ze Western Slope
    0 miles on my R. Noticed the dripping shock shit when it was on my trailer from a dealer in the Denver area. Never even sat on it. I stopped at a gas station to fill up the car for the five hour haul back home when this nice fellow asked me questions about the bike and I proudly talked about how amazing the suspension is supposed to be. Great shock! “The one that’s dripping oil?”
    Dealer sales guy was surprised as though he never heard of it. Perhaps he didn’t.
    It’s a KTM thing. I should be pissed off, but I’m a loyal customer, used to these episodes of Austro-Engineering-Fallibilities.
    #76
  17. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,720
    Finally made it to Fruita!
    Disappointing, for sure. But, prepare to be underwhelmed by the stock suspension. I honestly don’t know why it gets any accolades at all.
    #77
    Hico, Subaruvich and justinope like this.
  18. OhDuh
    OhDuh Adventurer
    Dec 27, 2019
    57
    Ger
    Could the heat issue be due to people removing their cat thus changing the heat dissipation? It's not allowed in Europe and a lot less people do it because of the fines. Then again we also have a lot less places to go offroad and most likely have a higher percentage of on road drivers
    Edit: What I wanted to say is that we have no reports of failure on the German speaking forum consisting of Austrian Swiss and German people.
    #78
  19. offroadjunky
    offroadjunky Been here awhile
    Oct 7, 2016
    271
    Kelowna,Canada
    You should have added in my opinion.
    #79
  20. Scourge
    Scourge Long timer Supporter
    Mar 25, 2014
    7,252
    Lackawanna County, PA
    Is this still a thing on new 2020 bikes or is it limited to a time frame? As in... while I'm shopping should I be concentrating on new arrivals or is it just a thing to expect to have to have fixed eventually? I have read elsewhere on the interwebz that it is related to a chrome defect on the shaft which seems like it should be isolated to a batch of dampers and eliminated after a certain date when they found it.
    It looks to be a 10 day turn-around if you have a good dealer - do most have loaners? My local dealer says "We don't do that" because (presumably) they are a powersports dealer that dabbles in motorcycles as a hobby or something.
    #80
