790 Adventure R Suspension Mods
Discussion in 'Parallel World (790/890)' started by windblown101, Jul 5, 2019.
  1. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    1,948
    Upstate NY
    I assume the gobbler is the bottom valve. Curious how the external adjuster for the design will work on the 790R forks. What more would you have to do to my forks beyond what you did last winter?
  2. Torque
    Torque Been here awhile
    Apr 4, 2006
    560
    San Diego
    Thank you Steve. Just finished drawing up the preliminary design and sent it off to one of the engineers I am working with. It will be a bit, but the 790R Gobblers are going to be a big deal.
    EvilSteve, TrailTrauma and AdvRonski like this.
  3. offworlder
    offworlder Been here awhile
    Sep 6, 2010
    657
    Vancouver, Canada
    Another very happy customer here chiming in re @Torque's work. The 790 R was transformed thanks to his re-design, night and day.
    Whodatschrome, EvilSteve and Dan D. like this.
  4. Dan D.
    Dan D. Been here awhile
    Mar 13, 2020
    656
    Jacksonville, FL
    Cool... Can't wait to see for myself.
  5. Dan D.
    Mar 13, 2020
    656
    Jacksonville, FL
  6. WI-790R
    WI-790R Been here awhile
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    That is very impressive. I bet the stock rear shock on my bike would have thrown the rider over the bars, on that last log hit.
  7. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    11,917
    s.e. mass
    Soften that rebound.
  8. Dan D.
    Mar 13, 2020
    656
    Jacksonville, FL
    That's what she said...
  9. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,780
    North of North Plains
    Not a 790, but this is what the Gobbers look like in both a 640A and a 950A. Both bike’s suspensions have also been reworked by Suspension 101 as well. So for all of you 790 owners out here, it will be worth the wait.
    5080C766-D340-4CE3-BB85-0B5E7527F4B2.jpeg F5989C2A-1E0A-42D1-881A-033A69D9D167.jpeg 18BFB718-0C3D-4089-921F-D1521B8155CA.jpeg 2EB5863E-3031-4DE2-B9FF-CAAB6543F609.jpeg
  10. WI-790R
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    The weather here isn’t being cooperative to allow much testing, but I did get the progressive rate shorter spring installed the other day. This spring, purchased through Torque, is dimensioned to lower the bike by about 1.25”. I made and installed a 0.44”nylon spacer in the shock.
    The spring tool turned out being a bit overkill, but was made mostly of scraps I had laying around. The thrust bearing was an ebay purchase.
    378ECE30-2726-4A1D-A559-ADE1C80C893B.jpeg B645ABA7-E6B1-4AA4-8C5A-37CF96FFEF7F.jpeg 1FC5D89B-60E4-4FC3-8E85-2889F5CFD82A.jpeg
    Whodatschrome, kzeb and braaap! like this.
  11. cbig
    cbig Rift- Raft, SCooter Trash
    Sep 30, 2003
    1,717
    Whittier, CA
    Interesting lowering kit. Let us know how it does? I've thought about lowering the bike an inch or so bit more control in off camber situations, stops.
  12. Torque
    Apr 4, 2006
    560
    San Diego
    Nice job on the shortening spacer. I see you allow for fluid to flow.
  13. WI-790R
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    Thanks! I’m sure a larger bore all the way through would have been just fine too. I rode the bike a little on Wednesday. The temps have been such that frost stays on the county road here, where in the shade. I could feel the bike sliding a bit but rather enjoyed that. Yesterday someone concerned about the slippery road must have complained. Now there’s sand (& salt I fear) all over the place. This seems to happen every year around this time.
  14. WI-790R
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    @Torque
    The new fork springs’ ID is about 0.022” smaller than the OD of the black plastic ring on the fork cap ass’y. Does the plastic ring just pop off the cap assembly? It will spin on there. There must be a small lip it’s stretched over. CBCB3601-E752-443A-9295-769E5E3BC360.jpeg I pried on it a little bit but didn’t get too rough with it yet. I assume I just need to turn the OD of the plastic ring to clear the spring? Maybe a heat gun would help that ring to soften/expand a little, to make removal easier.
  15. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,638
    Finally made it to Fruita!
    I just popped those rings off. No issues that I have found.
  16. WI-790R
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    Thanks. Yes, I warmed it with a heat gun and it came off easily.
  17. Teamrat
    Teamrat Adventurer
    Sep 2, 2009
    21
    Just get a little medieval on them and get them off. Then I rigged up mine with a bolt and washers etc to mount them in a battery drill so they can be spun up against a linisher or belt sander to bring the OD down to get clearance on spring. Another thing I did was put an internal chamfer on the top of spring where it seats up on the preload adjuster as in one position or another it hits the angled portion of it.
  18. Torque
    Apr 4, 2006
    560
    San Diego
    I put the whole cap in the lathe with the plastic secured and put them on a diet.
  19. WI-790R
    Jun 15, 2020
    140
    Cochrane, Wisconsin
    I had a piece of nylon bar stock chucked in the lathe to make spacers from, so turned a dia of .940” on that , pressed the ring on & gave it a trim.
  20. AdvRonski
    Feb 4, 2007
    1,638
    Nice work on the lowering setup. I have gone the other way, going to 270mm travel with the magic supplied by @Torque, although I added my own version of a remote reservoir to keep things cool with the under-sized shock.
