790 Adventure S (Standard) Suspension Mods
Discussion in 'Parallel World (790/890)' started by No-Fret, Dec 5, 2019.
  1. EvilTwin86
    EvilTwin86 Lone Ranger
    Jun 17, 2014
    93
    Orange, Ca
    slacker83 likes this.
  2. Ten Speed
    Ten Speed Adventurer Supporter
    Mar 1, 2008
    47
    Livermore,Ca
    It was 1600. Several hundred more than Hyperpro with hydraulic preload, which is a great shock I'm sure. The Tractive is an all in one unit and is very well built. Look at the dimensions of all of their components and compare them to others. For me it was worth the extra expense. They build the shocks Touratech sells. The shock I bought from Ted is 200 bucks more from Touratech.
  3. gilligandavis
    gilligandavis Gilligan on the Road Supporter
    May 29, 2019
    30
    Portand, OR
    Tractive is what Touratech slaps their name on (and several extra $$$)!
    Talked with Ted and will likely go with the same shock but thinking on the -30mm version. Not sure I want to pay for the Tractive forks right off so will go with Hyper Pro -30mm fork kit (again, what Touratech again sells overpriced with their branding)
  4. MeVoGTC
    MeVoGTC Been here awhile
    Nov 18, 2019
    307
    Maryland
    Anymore updates on anyone who’s running the Andreani Fork cartridges?
  5. No-Fret
    No-Fret Tanker
    Jun 1, 2015
    1,003
    Peoples Republik of Washington
    I've been running them since May. Makes a huge difference on and off road.
    brunosac likes this.
  6. brunosac
    brunosac Adventurer
    Jul 26, 2019
    32
    Italy
    How much travel did you measure on the fork?
  7. No-Fret
    No-Fret Tanker
    Jun 1, 2015
    1,003
    It's the around the same as stock 'S'...between 7.7 to 7.8 static sag with me not sitting in the bike.
  8. sudevva
    sudevva n00b
    Dec 24, 2018
    6
    Ukraine
    what changes do you feel compared to the stock suspension?
    In scenarios such as pits, sharp edges, etc. Overall harshness.
    I am thinking of switch from my 790R to 890S and install Andreani Fork cartridges and Andreani Ohlins shock. They should be interchangeable 790/890.
    Anyone running the Andreani Ohlins shock?)
  9. No-Fret
    No-Fret Tanker
    Jun 1, 2015
    1,003
    Harshness on sharp edged bumps greatly reduced. Well pleased with them as I can set my suspension up now for touring or off-road. Stock suspension is just not very good IMHO. I am running the HyperPro rear shock. Very good as well.
  10. they
    they bewilderness
    Feb 15, 2010
    2,487
    norcal
    Anybody got a set of stock 790s forks they want to sell?
  11. No-Fret
    No-Fret Tanker
    Jun 1, 2015
    1,003
  12. Renotrailrunner
    Renotrailrunner Adventurer
    Jun 28, 2020
    40
    Reno, NV
    I’ll have a set for sale soon.
  13. they
    they bewilderness
    Feb 15, 2010
    2,487
    norcal
    How soon? How much? Also looking for Wheel/axle/brakes/sensor,etc..
  14. TimTyler
    TimTyler Makes MOTOTREK
    Oct 8, 2011
    86
    Olympia, WA - US
    I bought a custom sprung Tractive shock from Ted @ BeemerShop and so far it's been well worth the cost. Probably won't get the chance to really beat it up until the spring (pun not intended).
    gilligandavis and No-Fret like this.
  15. No-Fret
    No-Fret Tanker
    Jun 1, 2015
    1,003
    How do you access the HS/LS clickers with the shock mounted? Looks like they are unreachable.
  16. TimTyler
    Oct 8, 2011
    86
    Olympia, WA - US
    It's a tight fit for sure, but no problem with the proper hex wrench (provided in the box)
  17. stou
    stou Been here awhile
    Jun 16, 2006
    493
    Quebec, Canada
    Just received directly from Italia today!
  18. brunosac
    brunosac Adventurer
    Jul 26, 2019
    32
    Italy
    Hi, please can you read the spring's K value? It should be engraved on the head of the springs...
  19. stou
    Jun 16, 2006
    493
    Quebec, Canada
    I don't see nothing writen on the spring. But on the spring box, the code is 105/KT9E. I bought from Omnia Racing, Italia. I told them my weight whitout gear, 150 lbs.
  20. brunosac
    brunosac Adventurer
    Jul 26, 2019
    32
    Italy
    Ok... Thanks! :beer
