790 Adventure Standard surge at low speeds
Discussion in 'Parallel World (790/890)' started by karmicgumbo, Jul 23, 2019.
  1. karmicgumbo
    karmicgumbo n00b
    Sep 3, 2009
    6
    A few days ago, I got stuck in slow moving traffic on a highway where they are widening the road, so there were construction delays and speeds 8-15 mph. I was in 1st gear and the bike couldn't run smoothly at a slow speed/rpm. Anything under 3500 rpm in 1st gear and the bike would lurch or surge. Below 1500 rpm, it felt like it wanted to stall. I only have 640 miles on the bike and it hasn't had its 620 mile service, but just wondering if anyone else has had a similar experience?
    thanks,
    karmicgumbo
    Rudy likes this.
  2. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    10,231
    s.e. mass
    Totally normal at low rpms.
  3. ettienne.scheepe
    ettienne.scheepe Adventurer
    Oct 18, 2016
    35
    Sounds like my 990
    mickd likes this.
  4. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,165
    Indiana
    On an electronic throttle fuel injected bike tuned for emissions with a chain drive, I will also concur that it's probably normal. Putting it in rain mode to deaden the throttle response is probably the best you can do.
    TrailTrauma likes this.
  5. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,241
    日本
    Sounds like it's tuned lean at those RPMs to pass emissions, pretty common these days across many makes. I flashed my S10 to get rid of the same issue. A booster plug can also be a cheap fix, used one of those on my AT. https://www.boosterplug.com/shop/boosterplug-ktm-790-805p.html
