790 Adventure Xplor Pro Suspension Thread
Discussion in 'Parallel World (790/890)' started by coloktmGS, Oct 13, 2019.
  1. coloktmGS
    coloktmGS Been here awhile
    Jul 11, 2005
    459
    SW MO
    Who has it? What’s the biggest improvement, shock or forks?
    did you stretch it to 270?
    who did you order from?
    Anything you’d do different?
  2. koekeroe
    koekeroe Adventurer
    Dec 12, 2015
    89
    onder den haag
  3. Konflict Motorsports
    Konflict Motorsports TUNER Supporter
    Dec 30, 2009
    1,243
    Austin, Texas
    We have supplied a number of clients with the Xplor Pro for the 790 Adventure in both 240mm and 270mm of travel. The Pro Components do offer some advantages above and beyond the OEM components such as billet bits, closed cartridge design, cone valve mid-speed assembly, cartridge pressure spring, higher tolerances, and overall better materials. I'd be happy to answer any specific questions in regards to these items.
    tomdubz likes this.
  4. comac90
    comac90 Where's Charlie?
    Aug 26, 2009
    298
    Asheville, NC
    Any idea if there are differences between the 270mm Xplor Pro on the Rally coming in the spring and the Xplor Pro 270mm one can buy now to retrofit?
    T
  5. Konflict Motorsports
    Dec 30, 2009
    1,243
    Austin, Texas
    They are the same, we have stretched a number of pro components to 270mm.
  6. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,749
    Ontario .. Superior
    Not to pirate the Pro discussion, but a quick Q: Can you stretch the OEM components as well to add travel? (On the R, at least?)
  7. Konflict Motorsports
    Dec 30, 2009
    1,243
    Austin, Texas
    Stretching of the forks is very easy utilizing all WP OEM parts. The rear shock is a bit more complicated and will require some custom specific parts. We have had these in the works but with the failures of the OEM units, we have seen we put effort into nailing that down before anything else was decided.
    ramirin and TrailTrauma like this.
  8. comac90
    Aug 26, 2009
    298
    Asheville, NC
    that’s good to know. I’m on deck for a Rally whenever they hit in March/April. I’ll wait to see the spring rates - particularly rear - but, my guess is at least the rear is going to have to be swapped.
    thanks for all the info you and others have posted up ... been tremendously helpful and looking forward to touching base when the bike lands to start dialing it in.
    T
    #8
