790 R Handguards info
Discussion in 'Parallel World (790/890)' started by Piersonjc, Mar 19, 2020.
  1. jmarleau
    jmarleau Been here awhile
    Dec 5, 2013
    568
    Since the 790 uses standard risers and standard style bars with no pre-mounted bar end inserts, the BHG-152 fits perfect. The additional spacer used on the right side is to prevent contact with the inner-most part of the lever that extends outward as the front brake is heavily engaged. Barkbuster are taking no chances here as contact with the hand guard would prevent fully engaging the front brake. Since I prefer a slight downward position of both my levers this clears the hand guard.
    https://barkbusters.net/what-fits-my/ktm/790-adventure-r-2019-on/vps/two-point-mount/
    @8:40 of this video
    #61
  2. Migolito
    Migolito Prognosticator and MotoYogi
    Nov 6, 2011
    3,153
    S-Cal
    Hum, I hate it when an supplier has an online presence then ignores thier email. No excuse.
    #62
    BobcatSig likes this.
  3. Migolito
    Nov 6, 2011
    3,153
    S-Cal
    Also, re Barkbusters. I just watched the video above. The guy needed to add a spacer(!!) in order to allow the BB to fit(?). Really looks hincky as hell. Who else has fit the BB on a 790? Did you need to 'fit' the spacer to make these fit?
    #63
  4. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,266
    Upstate NY
    I'm using the Raximo shortys and did not find there to be any interference with the brake lever and the BB's - BFG-152 no spacer needed. I never fitted them with stock levers.
    #64
  5. pclements
    pclements Adventurer Supporter
    Sep 24, 2007
    41
    Johnstown, CO
    I am trying to decide IF I need to change out my handguards. So has anyone broken the factory handguards? And secondly who is the OEM of the stock handguards?
    #65
  6. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,139
    Star Tannery, VA
    That depends. The stock hand guards usually survive a few drops, unless you're unlucky on the first drop...
    But yes, sooner or later (more likely sooner) if you're dropping the bike or smacking tree's you will bust the stock guards. On the other hand if you're not dropping the bike then they will work fine forever as wind deflectors.
    #66
  7. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,361
    SC
    And the stock one's won't offer much protection to your levers. I bought the KTM one's they are made by Barkbuster and bolt right up.
    #67
    railduke82 likes this.
  8. leaf001
    leaf001 Adventurer
    Sep 15, 2013
    28
    Are those CRG mirrors on the Cycra hand guards? How did you mount them? I was going to order the CRGs with Rottweilers mirror mounts (http://www.rottweilerperformance.com/quick-flip-mirror-mounts-mounts-only/) but am unsure it they will still have room to rotate.
    #68
  9. windblown101
    May 17, 2010
    8,139
    Star Tannery, VA
    #69
  10. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,582
    On the Ground Laughing
    #70
  11. Brilloman
    Brilloman Been here awhile
    Jun 29, 2014
    434
    Georgia
    I thought I saw a spacer somewhere that goes between the front master cylinder perch to space it forward a little to get a better fit and brake lever position with the handguard. Does anyone know what I am talking about?
    #71
  12. leaf001
    leaf001 Adventurer
    Sep 15, 2013
    28
    So you tapped right into the metal handguard to mount the Rottweiler adapter? Could you take another picture from the inside of the bars facing out? Thank you!
    #72
  13. Venturer
    Venturer AKA klakeman Supporter
    Sep 26, 2004
    991
    Dawsonville
    I purchased this spacer in the hardware area of Home Depot. Worked well.
    #73
  14. windblown101
    May 17, 2010
    8,139
    Star Tannery, VA
    I drilled thru the metal handguard and ran the mounting bolts into the threaded holes in the Rottweiller base.
    #74
    leaf001 likes this.
  15. BobcatSig
    BobcatSig Fresh Off The Couch Racing
    Aug 15, 2014
    3,915
    Protestlandia, OR
    I did the same with my Rottweiler mirror mounts and Cycra handguards.
    #75
    Venturer likes this.
  16. railduke82
    railduke82 Adventurer
    Jul 10, 2016
    10
    #76
  17. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,555
    Ontario .. Superior
    For anyone worried their handguards might rotate, resulting in an exposed lever causing a bend or break in a fall try this - use teflon tape between your perch mounts and the bar so if it comes to it the tape will allow the perch to rotate about the bar versus breaking your lever. Also don't go hog wild tightening the perches down.
    #77
    Toddv likes this.
  18. RedRyder1972
    RedRyder1972 n00b Supporter
    Aug 5, 2019
    8
    Oregon
    Do you know if the Rottweiler fold away mirrors can attach to the Pro Bends?
    #78
  19. windblown101
    May 17, 2010
    8,139
    Star Tannery, VA
    If you're talking about CRGs mounted on the Rottweiler mounts yes they do, look up about 5 posts for a photo. ;)
    #79
  20. RedRyder1972
    Aug 5, 2019
    8
    Oregon
    #80
