790 Reported Clutch failures - My 12k mile examination
Discussion in 'Parallel World (790/890)' started by windblown101, Nov 10, 2019.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,935
    Melbourne - AU
    Slurp, number drills!
    Well mine aint going to cut it :photog
    I might have to put in an order after your test results.
    :deal
  2. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,688
    NW Sydney, Australia
  3. braaap!
    Mar 16, 2005
    4,935
    Melbourne - AU
  4. coloktmGS
    coloktmGS Been here awhile
    Jul 11, 2005
    547
    SW MO
    Any chance that opening this hole and increasing flow decreases oil pressure somewhere else in motor and causes a more significant/predictable failure?
  5. 1coolbanana
    Aug 25, 2009
    6,688
    No, not really, the oil pump pumps a large volume while maintaining a regulated pressure.
    As flow increases due to pressure variation, it is regulated, like when it gets hot and the oil pressure would drop from the lower viscosity if not regulated.
    The size of a jet is so miniscule in the overall flow that opening it from 0.07 mm² to 0.2 mm² is meaningless in the overall flow and pressure in the system.
    If you left the jet out altogether thats a different story
    Hope that makes sense
    Camel ADV, Toddv and braaap! like this.
  6. chain
    chain Go Fly Supporter
    Aug 28, 2002
    4,831
    Central IL
    1600 miles of Baja. Clutch is working without issue. Turned north this morning. More news at 11
    braaap!, TrailTrauma, No-Fret and 2 others like this.
  7. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    I pulled my cover yesterday to inspect with 800 miles, Everything looked new. I pulled the oil jet and it was perfectly clean but that's a tiny hole, a grain of sand could plug it. I wouldn't expect it to clog if it hasn't by now as any manufacturing crud/debris should have worked it's way through and barring a failure of some sort everything coming through the oil pump should be first filtered by the pickup screens and oil filter. I think I'll drill it to .4 mm once I find the proper bit just to get a little more oil in there, approximately double as noted.
    Also, I tried my Camel clutch lever in the third position but wasn't comfortable with the amount of freeplay I had to run as to not have it drag while pulled with a little margin for error so I moved it back to the center position. I'm probably just being overly careful here but I'd rather not worry about it. I always check freeplay at the lever on the clutch cover, at the cable can be somewhat misleading.
    1coolbanana and Kinkysmurf like this.
  8. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,159
    FIN
    Oil jet cost around 5€ so I will buy another one to drill before opening the case. Also considering Rekluse discs.
    Toddv likes this.
  9. Kinkysmurf
    Kinkysmurf Adventurer
    Oct 24, 2019
    93
    Deua River
    I am a little surprised with the freeplay set, its giving you drag, but every clutch is a little different.
    I'm in the 3rd hole, ( to early for kinky to go there)
    Checking mine the other day I have about 2-2.5mm play at arm, which is giving 10mm + at the bars.
    I have more freeplay (2x) than what it specifies in Manual. I do get a touch of drag when its stone cold, shifting in 1st, but nothing like drag that will move the bike forward and it feels perfect when warm.
    Setting this clutch is a finer point than any other cable clutch bike Ive owned and can remember.
    IMO the KTM manual should be directing everyone to check that freeplay is evident at clutch arm/case. They assume and rightly so that freeplay of 5mm at the bars is impossible without freeplay at arm/cover end.
    Even the expansive repair manual doesnt give clear instructions, they assume you know what you doing.
  10. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    Yea those aluminum disks feel scary light. Steel won't explode if it gets hot either.
  11. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,308
    SC
    It wasn't giving me drag pulled all the way in but there was very little movement before things start spinning. I guess maybe let out 10% and things start spinning in neutral. I don't want to have to pull my clutch lever all the way to the bar to find neutral and have it fully release. The middle hole is a big enough improvement over the stock friction zone and pull for me anyhow so leaving it there. I don't think it would ever cause an issue, I just don't like it that way.
  12. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,619
    Star Tannery, VA
    I broke down and ordered a TorqDrive. It should arrive in the next few days? I had already replaced my original clutch pack with a fresh OEM clutch pack but I keep seeing stories pop up about every other week it seems like of the aluminum plates grenading inside the motor after someone tried to nurse a bike somewhere after some slipping was noticed. If I were in the middle of no where and for whatever stupid reason my clutch started slipping with the stock clutch pack I'd be terrified to try to limp back to civilization under the bikes power, that doesn't work for me.
    ramirin and Camel ADV like this.
  13. Kinkysmurf
    Oct 24, 2019
    93
    Deua River
    I have been on rides in horrible, sticky mud. Guys that burnt their clutches let them cool a bit. Then pull out the pack and rub the friction plates on a rock, reassembly and go home very gentle.
    chain and windblown101 like this.
  14. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,415
    Calgary
    I haven't noticed much (if any) change in finding neutral.
    1coolbanana likes this.
  15. windblown101
    May 17, 2010
    6,619
    Star Tannery, VA
    Exactly. Limping home with a burnt up clutch should not be a motor ending exercise, and as @gearheadE30 mentioned, the steel plates weighing a bit more may actually be a benefit at low revs. Will be interesting to see how they work out.
    Kinkysmurf likes this.
  16. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    384
    Durban South Africa
    Remember the KTM manual does not cover the longer arm you have installed.
  17. 1coolbanana
    Aug 25, 2009
    6,688
    To be honest, the longer I wait for the one finger clutch to arrive the more Im getting used to the stock setup and finding less need for any change.
    Stock setup seems fine the more I use it.
    chain, MeVoGTC, krussell and 2 others like this.
  18. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,679
    Cremona, Italy
    Thinking out loud here.
    Assuming KTM know what they do (I know, I know...), couldn't it be that the short friction zone is there to have a full pull even with a big free play?
    I mean, maybe the engineer who designed the clutch system knew this type of clucth needed a greater free play and designed the arm accordingly.
    Then that got missed when they printed the manuals.
  19. Kinkysmurf
    Oct 24, 2019
    93
    Deua River
    My memory is fine, except when the girls spike my drink.
    Thumper Dumper and 1coolbanana like this.
  20. ramirin
    Mar 25, 2008
    1,159
    FIN
    Few hours ago ordered oil jet and just before sending added TorqDrive - for the same reasons you mention. And I know I'm active on clutch and slipping a lot when offroad.
    I had rekluse slipping on 690 while we were on swamp. With bike sinking all the time couldn't notice the slipping until came back to road, couldn't even do a wheelie on first gear. Adjusted the screw on autoclutch few notches, removed some fluid from reservoir and enjoyed the rest of summer. Heavy duty stuff.
