790 Reported Clutch failures - My 12k mile examination
Discussion in 'Parallel World (790/890)' started by windblown101, Nov 10, 2019.
  1. Dan D.
    Dan D. Been here awhile
    Mar 13, 2020
    707
    Jacksonville, FL
    Lol... Right on.
  2. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    434
    Durban South Africa
    Happy to hear you came right with Rekluse, I've only dealt with them via email regarding set up etc. and always found them very helpful.
    Did you enlarge the oil jet on your bike?
    I've gone 0.5mm on the jet and keep the oil level at the top of the sight glass and I must say it has improved the Rekluse's feel. It's still clunky when cold but smooth's out once at operating temp. Didn't really like the idea of the larger jet and extra oil but thought I may as well try it while the bike is still under warranty.
  3. Quercus petraea
    Quercus petraea Been here awhile
    Jan 11, 2019
    225
    Spain
    Did you find the original jet cloged? If yes, do you think that was just metal residue or may loctite from the thread of the oil jet?
  4. Thumper Dumper
    Apr 13, 2016
    434
    Durban South Africa
    I didn't find any blockage of any kind. Only went bigger to try improve the performance of the Rekluse. Must say though that checking the jet is difficult because if you push something through the jet you will probably clear the blockage and will never know. Removing it is the best option but make sure that the screw driver blade is the correct size because it is very east to strip the head of the jet.
    Quercus petraea likes this.
  5. Quercus petraea
    Jan 11, 2019
    225
    Spain
    I already read the whole thread (yes, 48 pages).
    So, can i asume that people that had problems and then switched to a 0.5mm jet haven't had problems again??
    Another question: Why a 0.5mm jet and not a 0.4mm? Is not more logic to be cautious (even if the oil pressure meassurements says 0.5 is ok)??
  6. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    719
    Dallas, TX.
    Or another theory is, when a individual wrecks the the clutch, they fix or have it fixed then the individual is more aware of the clutch. Now the individual doesn't slip the clutch into oblivion, they realize the clutch is not indestructible so they take care to not wreck it again.
    The reason for the .5mm jet size and not .4mm or .6mm is the
    5mm was used on other KTM bikes as a "fix" for clutch issues, also the .5mm jet is readily available for purchase. However if you want a .4mm you can certainly drill your jet out. Many have done it in .5mm.
    No-Fret and kirill_k like this.
  7. Quercus petraea
    Jan 11, 2019
    225
    Spain
    Yes, I know about .5mm jet in other models, but I don't understand why CJdesigns make a specific KTM790 oil jet in 0.5 and no in 0.4mm.
    Anyway, I'm not in the "it's always rider's fault" theory, when it's obvius that there's a problem here in certain numer of bikes.
    Yes, you can blame always riders again and again, free speech here. But, honestly, beyond than "hey, people, don't abuse the clutch slipping" (wich all of us have read a thousand times here), I don't think reapiting that contributes anything to the research or to the achievement of a solution.
    Sorry if I sound blunt, my English is not native and not good at all!
    BHoward likes this.
  8. BHoward
    May 5, 2014
    719
    Dallas, TX.
    No need to apologize, your English is great, free speech. .
    I don't think CJ drills out the jets, I'm pretty sure they purchase them from the manufacturer.
    The manufacturer makes jets in 2 sizes, .3mm and .5mm.
    And for the clutches, maybe some feel like there is not a defect in the bike. Mabey some feel like it is rider abuse and thats the problem.
    So working towards a solution would be for the riders to stop abusing the clutch.
  9. Quercus petraea
    Jan 11, 2019
    225
    Spain
    Even if that is the case, I think most people think the clutch is a little weak (may be not a engineering defect, but something than could be better).
    A least, it's way weaker than in other bikes people (including me) have own, have riden in same conditions, and have abused to the same extent.
    Then, i'd like to find a way to improve the longevity of the clutch even if I want to abuse a little!
    kirill_k and BHoward like this.
  10. BHoward
    May 5, 2014
    719
    Dallas, TX.
    IMO, I think your right. I think in order to save weight or some other reason KTM engineered the smallest clutch possible believing riders would use the MTC. I think this is the problem, the 790 being a ADV bike, not a motocross bike, some riders still slip the clutch and the engineers did not intend for this.
    Although, I install Rekluse clutches In all my bikes, my Rally was no exception. So I very rarely ever touch my clutch lever. I use the MTC for what is meant for. I set it appropriately and go.
    This last week I went up and down Lippincott pass in Death Valley twice. 1st gear, MTC rally set on 7 and throttle on offroad. No problem.
    I also have the .5mm jet installed.
    So if you want a stronger clutch, maybe Rekluse is the way to go, they make a auto and a non-auto model for the 790.
  11. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    597
    Denmark
    Or try the new clutch pack from the 890 Adv, when available..
    Mud Bucket, No-Fret and BHoward like this.
  12. RB450
    RB450 Been here awhile
    Oct 13, 2008
    558
    Kintnersville, PA
    Picking my machine up this weekend. All new clutch components. Interesting to note...the deep groove bearing part number has been updated, at least in the US.
    I need to have some further conversations with my dealer and service manager on the details, but once again they and KTM took care of me and the bike under warranty, so Kudos to both.
    It was noted that the failure was not caused by operator error or abuse...
    No-Fret likes this.
  13. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    10,553
    The Delta Ghetto, GA (aka PTC)
    It shouldn't have any free play at the lever; that's how the rekluse works on these cable operated clutches. You adjust all the free play out plus actually putting tension on the cable. I left my Camel arm on, but I moved the cable to the middle hole. When I had my brake line recall done, the service tech noticed that my clutch was "misadjusted" and dialed in the OEM freeplay. Of course, When I took off the clutch was slipping anytime I gave it more that grandma levels of throttle. Didn't take me long to figure it out and "misadjust" it back so it was working properly.
  14. Gaulin
    Gaulin Orange (& Blue) Crush
    Nov 20, 2004
    423
    Manitoba, Canuckistan
    Is the new bearing item 10 or 17 in the parts fiche ?
    kirill_k likes this.
  15. Thumper Dumper
    Apr 13, 2016
    434
    Durban South Africa
    Funny enough when I took mine in for the brake line recall the tech was shocked to see that I had no freeplay and thought I about to burn my clutch up until I explained about the Rekluse.
    Anytime I take my bike in I always explain that I have a Rekluse, on my 690 the tech almost put it through the window when he thought it was in neutral and gave it a rev.
    nibby likes this.
  16. SoilSampleDave
    Jan 21, 2005
    10,553
    That would have been fun to see - as long it wasn’t my 690! I did tell the service writer, who put it on the work order, which the tech saw. However, he was used to the typical KTM hydraulic clutch with a Rekluse and hadn’t seen the different instructions for this model.
    Thumper Dumper likes this.
  17. kirill_k
    kirill_k n00b
    Aug 9, 2013
    8
    Moscow
    Have briefly looked over the clutch microfiche at ktm.com and failed to find any difference in partnumbers between 790s of 2019 and 2020, no matter European or American. The only difference in 890's clutch seems to bee position 8, i.e., the disk pack.
  18. RB450
    Oct 13, 2008
    558
    Kintnersville, PA
  19. RB450
    Oct 13, 2008
    558
    Kintnersville, PA
    96E197E2-DB95-43B8-A221-AFED79EDF6FC.png 96E197E2-DB95-43B8-A221-AFED79EDF6FC.png
  20. RB450
    Oct 13, 2008
    558
    Kintnersville, PA
