790 Reported Clutch failures - My 12k mile examination
Discussion in 'Parallel World (790/890)' started by windblown101, Nov 10, 2019.
  1. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    455
    Denmark
    If the jet was a problem i think it had occurred already with the 790 Duke...It was not a problem on the old 950/990 either..
    1coolbanana and No-Fret like this.
  2. Velociraptor
    Velociraptor TrackBum Super Supporter
    Apr 17, 2005
    2,048
    Pacific Northwest
    I am running the TorqDrive clutch pack and it is a quality product. Only downside is now it is harder to find neutral. I emailed them and got a quick response that their clutch pack has a bit more drag and also might need to wear in more. Simple install. My stock clutch looked fine, but this one will probably last way longer and endure a lot more abuse.
  3. nibby
    nibby Been here awhile
    Feb 22, 2009
    415
    U.K. - Liverpool
    Has anyone put in heavier springs on the stock yet?
  4. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,753
    Ontario .. Superior
    I suspect @Camel ADV has, and perhaps @AdvRonski . I'll be ordering mine well before this season begins. Still working on losing a few lbs.
    nibby likes this.
  5. ramirin
    ramirin Ready to push
    Mar 25, 2008
    640
    FIN
    Do we already have a part number for heavier springs?
  6. Kinkysmurf
    Kinkysmurf Adventurer
    Oct 24, 2019
    93
    Deua River
    No, not that Im aware of, and maybe TT is talking Rear Shock springs since he is talking about losing weight.
    If the snippets of rumor about Birch using heavier clutch springs is right, " he got them from his toolbox" Id start looking at 1090 springs or others in the KTM line up that match O/D and free length if you feel the need for them.
    Im ok with stock unless I feel it slip. The Old Husky in my Avatar needed Heavy springs 6x, Husky made them available since to stockers would sag out fast.
    TrailTrauma likes this.
  7. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,306
    Finally made it to Fruita!
    I looked at 1290 clutch springs, as they are basically the same length as the 790 springs, but they are also 2mm larger in diameter, and do not fit in the 790 clutch. Maybe someone from a dealership can measure the 1090 springs. They are several mm longer than the 790, but if the diameter is right, that would provide a little more clamping pressure.
    kzeb, nibby, ramirin and 1 other person like this.
  8. TrailTrauma
    Jan 17, 2012
    4,753
    Ontario .. Superior
    Opps, my bad. I was speaking of rear coils. :fpalm
  9. AdvRonski
    Feb 4, 2007
    1,306
    Well, now I'm confused. But, I went with a stiffer progressive spring at the rear.
  10. TrailTrauma
    Jan 17, 2012
    4,753
    Ontario .. Superior
    Last time the heavier clutch springs came up I considered emailed Birch. I'll do that tonight, and report back .. hopefully he recalls something specific about the springs 'he had in his toolbox'. lol
    Edit: I emailed Monica, his wife, in the hopes she'll pass along the heavier clutch spring query to Chris and get back to me.
    AdvRonski likes this.
  11. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,336
    Cowtown
    I'm running the stock springs but a 0.5mm oil jet.
  12. ramirin
    Mar 25, 2008
    640
    FIN
    Assuming this is about clutch (not shock); what is size of oem jet?
    Just to be sure, do you have auto-clutch (radiusx) or just exchanged clutch pack (torqdrive) ?
    gsuks likes this.
  13. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,445
    wilnis de ronde venen nederland
    part number 5
  14. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,445
    wel it's finally possible to see the 890 duke in the ktm parts finder, I looked to see if there were any different part numbers on the pages for clutch and the transmission I main shaft,
    no difference in part numbers
    kzeb and 1coolbanana like this.
  15. Velociraptor
    Apr 17, 2005
    2,048
    Pacific Northwest
    Just the Torq drive clutch pack. No auto clutch.
    ramirin likes this.
  16. ramirin
    Mar 25, 2008
    640
    FIN
    0,3mm that is one small hole for important feature.
    @Camel ADV did you drill it or do you have part number for 0,5mm jet?
  17. Camel ADV
    Mar 4, 2009
    2,336
    Cowtown
    I drilled it. It was a bitch to find a bit that small and as annoying to find a drill with a chuck/collet small enough to grab the bit. If you do drill it, I'd suggest ordering a spare oil jet from KTM first. With a drill bit that small, snapping it off is quite possible and you'd have a hell of a time getting it out after.
    Benduro and ramirin like this.
  18. ramirin
    Mar 25, 2008
    640
    FIN
    I would probably send to or visit a company that has the tools and expertize - shouldn't cost more than a special drillbit :dunno
  19. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,108
    NW Sydney, Australia
    0.3 to 0.5 is close to 3X the surface area and flow rate.
    0.3 = 0.07 mm² , 0.5mm = 0.2 mm²
    Thats the same size I always used on 9XX's
    This is what I use
    ramirin, Benduro, kzeb and 1 other person like this.
  20. 1coolbanana
    Aug 25, 2009
    6,108
    I drill by hand when enlarging a hole under 1mm.
    Did this make any difference to selecting neutral?
    Any bigger on 9XX could make it a bit hard to find sometimes.
    Havent done the 790 yet but may start with 0.4 (0.14 mm²) which doubles the flow rate.
    Mud Bucket likes this.
