80 Sportster Enduro Build
Discussion in 'Some Assembly Required' started by JonnyH913, Nov 9, 2018.
  1. JonnyH913
    JonnyH913 Been here awhile Supporter
    Apr 18, 2016
    305
    Southern IL
    Hello all!
    I had a friend of mine reach out to me that is huge in the build projects. He currently has a 1980 Sportster and is wanting to swap that over to an enduro build. He discovered that the 39mm fork tubes on a 1983-1987 Honda XL600R are a direct fit. He only needs the front end. Tubes, rotor, caliper, master cylinder, etc. Basically the whole front end.
    Any one offer any assistance on where on God's green earth he could find these parts?
  2. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    12,986
    Orange County, CA
    Likely the big auction site that starts with an e
  3. JonnyH913
    Apr 18, 2016
    305
    Southern IL
    I figured as much. Just trying to exhaust all options for him
  4. nervous
    nervous 2009 R1200GS
    May 6, 2017
    175
    Beautiful Central NY State
    For the same reason you're here I'd start frequenting any XR sites youi can find and asking the same questions. These are a few I found in a couple minutes of looking and I am sure there are many more. There's also a lot of used bike parts yards and sellers out there you just have to do some digging. They may even be networked like auto pats yards are. National Craigslist searches?
    https://www.facebook.com/Xl600NO
    https://thumpertalk.com/forums/topic/1008607-honda-xl600r-problems/
    https://bikez.com/msgboard/msg.php?id=12767&type=bike
    E-mail to them?
    https://www.xrsonly.com/
  5. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,332
    That fork is woefully inadequate on an xl600 what's it going to do under a Harley? Flop around?
    baldman1 likes this.
  6. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,033
    Reading,Pa
    There are oe hd fork choices up to 49mm ,you could then use resprung Drz forks .
    victor441 likes this.
  7. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    748
    behind the cheddar curtain
    KTM forks are pretty much a bolt-in. Im using 98 WP 5060 50mm conventionals. Easy peasy. Heck, no need to change the bearings. JTH used KTM on his
    greasyfatman likes this.
  8. Pezz_gs
    Pezz_gs Cant ride for crap
    Nov 13, 2004
    5,280
    Sydney Skunkworks
    DR600 Suzuki forks are 39mm as well
    #8
  9. plugeye
    plugeye MC rescue
    May 11, 2007
    6,796
    Garland, Texas USA
    39mm triple trees on sportsters werent until 1987
    #9
    Ginger Beard likes this.
  10. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    5,594
    Mid Wet Or A Gun
    I'd be looking for an over sized rotor...maybe even two rotors to slow that HD down.
    Honda going to weigh ....swag here....320 lbs ??
    HD....lot's more..... 529.1 pounds.......just sayin.
    Had to go an over size rotor on my Honda XR650R for riding Dual sport street rides.
    #10
  11. JonnyH913
    Apr 18, 2016
    305
    Southern IL
    I couldn't agree more. It's going to be a heavy sucker. Definitely wouldn't be an enduro build that I personally would pursue, but hes excited about it and loves making custom rides.
    #11
  12. mach1mustang351
    mach1mustang351 Long timer Supporter
    May 12, 2014
    3,037
    Alaska
    The newer sportster 48 models use a 49mm fork tube.
    If You got a set of those triples, you could use many many different inverted style front ends. Not sure if the steering stem and all that are the same size, but it would be something to look at.
    Back in the day, we used this triple to put a set of Buell Ulysses forks on a sportster.
    Just ideas
    #12
    smolt likes this.
  13. Mc crackers
    Mc crackers Adventurer
    May 7, 2019
    40
    Arkansas
    eBay..I’ve done it with that same front end. Works great be sure and tighten the triple tree clamps very good if he’s gonna be ramping and he will need to re work the kick stand. I had like 9 inches of travel or more
    #13
