82 it 175 front fork question
Discussion in '2 smokers' started by chevcamaro305, May 27, 2016.
  1. chevcamaro305
    chevcamaro305 Adventurer
    Apr 10, 2016
    26
    Wahnapitae
    Iv never really played with front forks much or any shocks for that matter . Anyone know how much air pressure to put in them ? Do I set it with tire on or off the ground ? And how do I go about changing and refilling the oil in them ?
    Sent from my HTC One M9 using Tapatalk
  2. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,090
    Stuck in 80s
    Wahnapitae as in just east of Sudbury?
    I think the range is like 0-5psi for those forks.
    The forks come apart by removing the retaining bolt from the bottom fork leg. I would try to find a manual if you're attempting to rebuild.
    Sean :bmwrider
  3. chevcamaro305
    Apr 10, 2016
    26
    Wahnapitae
    Yup down Dryden . Where you from ?
  4. GR0NK
    Sep 24, 2006
    10,090
    Stuck in 80s
    Originally from the Valley but now living in Dowling.
    Sean :bmwrider
    chevcamaro305 likes this.
  5. chevcamaro305
    Apr 10, 2016
    26
    Wahnapitae
    Honestly I'd like to just pour out the old oil and put new in and if they slowly leak repeat as necessary . I'm not doing any real trail riding mostly back roads n such . I'd just like to know how to do it . Where would I find a manual ?
  6. GR0NK
    Sep 24, 2006
    10,090
    Stuck in 80s
    You could get lucky and Royal might have one on the rack. I've been lucky in the past searching online for some manuals.
    If you just want to drain I'm pretty sure undoing the bottom bolt will drain the fork leg (careful not to pull apart if you don't want that) and unscrewing the air valve at the top will let you drain the oil above the piston. I did a quick check and the same year DT forks (found an online manual) hold approx. 440cc of oil so the IT ones should be similar.
    Sean :brow
  7. chevcamaro305
    Apr 10, 2016
    26
    Wahnapitae
    the bolt your referring to , is that directly under the forks ? Rather large hex type plug something around 1/2" ? And to fill it does the oil have to go back in threw that same plug ?
  8. GR0NK
    Sep 24, 2006
    10,090
    Stuck in 80s
    Yes. That bolt holds the two parts from coming apart though so be careful. You can refill it through the same hole if you want but I would recommend from the top.
    1. Pull bottom bolt, drain bottom, put bolt back in. Do not cycle the fork.
    2. Pull the air valve at the top and drain that by turning the fork upside down.
    3. Once empty, turn right side up and put in the measured amount of fluid required. (only a manual will tell you this amount for certain)
    4. Screw air valve back in and then cycle the forks. Add a few PSI of air if you need to stiffen them up a bit.
    This worked on my XT350 forks which are of nearly the same vintage.
    Sean :brow
    #8
  9. Mobil1
    Mobil1 Long timer
    Jan 12, 2016
    1,837
    DO NOT remove the bottom bolt unless you're rebuilding the forks. It's NOT a drain bolt. There may be a small bolt or screw on the back of each for a drain. If not out the top is fine. Loosen the caps on the top of the forks , not the air valves , and then loosen the triple clamp bolts to remove the forks. Take the caps off now and remove the springs. Turn the forks upside down to drain. Pump them to get the remains out. When you see what comes out you may want to flush them by partially filling , pumping and draining with mineral spirits. The refill is usually measured by the height of the oil from the top of the fork tube with the springs out and the forks compressed. If you can't find an oil height spec , you should be able to find a capacity. Try 20w fork oil.
    #9
    dancy, spokester and chevcamaro305 like this.
