    Dismiss Notice
950/990 Adv - Alternative rim options (brands)?
Discussion in 'Dakar champion (950/990)' started by Orange Toaster, Jun 10, 2020.
  1. Orange Toaster
    Orange Toaster Been here awhile
    Nov 8, 2008
    124
    Copenhagen, Denmark
    Greetings all.
    I am chasing a new front rim for a 950 Adventure. Apart from the original, I have found that Excel makes one the same size (21x2.15").
    Do anybody know of other alternatives and where to get them (international shipping is fine)?
    /OT
    mrrgoncalves likes this.
  2. zimtim
    zimtim Been here awhile
    Aug 15, 2012
    128
    UK
    Orange Toaster likes this.
  3. LocuL
    LocuL Gnarly Steward
    Dec 5, 2006
    3,109
    Denmark - Jutland
    If you offroad a lot. Go for the 1.85
    Whodatschrome likes this.
  4. geometrician
    geometrician let's keep going...
    May 25, 2008
    1,334
    West-By-God Virginia
    I bought my Takasago EXCEL A60 21 x 1.85 from Summit Racing- they had the best price on the 'net (for USA). Strong as anything! Tires fit better, our stock rims were not only soft but too wide. Just looked and they are out of stock... :-(
    If you take some time soaking the nipple/spoke ends with penetrant, marking spokes (start at valve hole for reference) and taking a few pictures you can take your old one apart & lace your new one up in about an hour- make sure to use clean the threads with a wire brush & solvent, then use nickel anti-seize on the threads (place some in nipple holes as well) so you get a good clean torque/feel from each nipple as you tighten them. Plenty of videos to help lacing & truing on YouTube if you need assistance.
    DesertSurfer likes this.
  5. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,513
    North of North Plains
    And if he goes off-road even more than a lot (like in a lot, a lot), then go for a 1.6.
  6. Hipster
    Hipster Long timer
    Aug 31, 2004
    2,581
    Mpls, Mn.
    If you plan on reusing the stock hub and spokes you should consider the OEM KTM 950 Super Enduro front Dirt Star 21" x 1.85" front rim. That's what I did, the OEM Super Enduro front rim has Euro drilled spoke hole pattern and the rim is much stronger then the 950/990 adventure rim.
    Be aware that many replacement front rims have a Japanese drilled spoke hole pattern and requires custom spoke lengths or modification of the rim drilled spoke holes when reusing the stock hub.
    DesertSurfer, el Pete and roookie1 like this.
  7. LilYoda
    LilYoda Been here awhile
    May 20, 2013
    404
    Don't want to hijack the thread, but I'm also interested. But in Tubeless. Are the rims from a 1190 a good thing, to re-spoke on the 990 hubs?
  8. LocuL
    Dec 5, 2006
    3,109
    Denmark - Jutland
    #8
  9. LilYoda
    May 20, 2013
    404
    Do both rims have the internal ridge that prevents the tire to come out of the rim in case of flat.
    More generally, I was more in search of a natively tubeless rim that could be fitted on the 990 hubs. Was wondering if anyone knew one.
    #9
  10. Orange Toaster
    Nov 8, 2008
    124
    Copenhagen, Denmark
    #10
    zimtim likes this.
  11. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,988
    West of the West, Oregon
    Good idea, but they won't lace up. For some damn reason KTM went to Jap lacing for the 1x90 front wheel. Also, the front rim is even wider than before, now up to 2.5x21.
    Rear wheel/hub is the same lacing.
    If you want to go with a 19/17 wheel size, the new 1290s cast wheels are cheap. But, the front brake mounts are too wide for 950/990 brakes.
    #11
    LilYoda likes this.
  12. LilYoda
    May 20, 2013
    404
    Too bad about the difference in lacing for the front. But at least the rear would be an option, then.
    So that means I'd have to search for a 21 inch euro laced tubeless rim for the 990 front. Not sure that exists...
    #12
  13. Zuber
    Sep 28, 2004
    6,988
    There are NO narrow 21" rims that have the safety beads for tubless. Some run them anyway. I would not.
    I really like the 19" front rim and tire combo for pavement. Not bad for easy two track also. The 2.5x19 Excel rim comes with the safety beads, uses the common 110x19 tire.
    Running a radial on both the front and back really helps the handling. Some have kept the 18 rear, some changed to 4.25x17 rim 150-17 tire rear, both worked. The 150-17 tire is much more common and available.
    #13
    DesertSurfer and Crazygreek like this.
