950 Adventure S and 990 Adventure suspension swap question
Discussion in 'Dakar champion (950/990)' started by JXA, Nov 25, 2017.
  1. Torque
    Torque Been here awhile
    Apr 4, 2006
    452
    San Diego
    Possible, but why blue. Progressive springs are not a good fit on that fork anyhow.
    #21
  2. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    2,908
    North of North Plains
    I didn't see in his posting that he mentioned blue springs. That's why I brought up progressive springs.
    #22
  3. Torque
    Apr 4, 2006
    452
    San Diego
    He did not say they were blue so you may be correct. I should qualify the progressive spring statement. If you are running the forks without any valving mods then I guess you could realize some improvement in bottoming resistance by installing a quality variable rate spring set. This is what they call riding the spring. In other words less control with damping but more bottoming resistance with spring only. For that bike I would for say a 180lb rider if they were going variable maybe .60kg/.72kg might be a good starting point for the aggressive guy. If the spring does not have specific rates stay away. One size certainly does not fit all and many variable fork spring sets I see are low quality.
    You will get a better ride, better performance all around with straight rate and real valving both mid and base but some do not need it.
    #23
    Mr Head likes this.
  4. FakeName
    FakeName Wile E Coyote SuperGenius
    Jan 1, 2007
    2,152
    San Diego
    Just FYI:
    Torque is being humble here in his anonymity.
    He's the finest suspension builder I've met and has done a lot of work on all my bikes as well as my entire riding posse.
    Good dude. I don't ask questions, I just take him my stuff and he makes it work.
    #24
    Camel ADV likes this.
  5. Maoule
    Maoule Long timer Supporter
    Nov 30, 2012
    1,664
    KCMO
    ^^^Hear, hear.
    #25
  6. Vytautas
    Vytautas n00b
    Apr 27, 2019
    4
    Lithuania
    So, i did change tthe springs and the old ones where 60mm shorter. Now i have progressive springs in front and rear shocks. Deal is solved! The ride now is great! I was going 100km/h on the forest road and did't felt any hits on the bars. Thanks for the help guys!
    #26
  7. Vytautas
    Vytautas n00b
    Apr 27, 2019
    4
    Lithuania
    P.S. Taking out the front fork i broke the bolt and had to change the bearings too :)
    #27
  8. Whodatschrome
    May 4, 2015
    2,908
    Could the new springs that are 60mm longer than the existing ones cause some coil bind?
    #28
  9. Vytautas
    Vytautas n00b
    Apr 27, 2019
    4
    Lithuania
    Well a guy who reasembled the forks told me this lenght. But from the old springs one end was cut off.
    #29
  10. Igoron
    Igoron n00b
    May 2, 2019
    2
    Russia
    Guys, hello to you from Russia. Please tell me. Now I have 990, 09 years old. fork stroke 210mm. I want to make 265. What spare parts do I need to buy? Studying, I understood like this.
    1) 48600 240 Inner tube D = 48 L = 595 2003
    2) 48600241S HYDR.STOP L = 200mm D = 31.9 CPL
    3) 48600225 Adjustment tube 6x482
    4) 48600253 PISTONROD 14x11x1 L = 516
    Did I write everything right? or something to add? Or maybe I wrote too much?
    #30
  11. Igoron
    Igoron n00b
    May 2, 2019
    2
    Russia
    does no one have an answer?
    #31
  12. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,851
    NW Sydney, Australia
    All I had to do to make my 2009 Adv with 210 travel into 265 travel was use the the damper rod and rebound adjuster rod from a 2003 S.
    Only 2 parts required for my conversion.
    All other parts were identical.
    EDIT: And spring spacers
    #32
