1. eNewsletter Sign Up
950 elec output
Discussion in 'Dakar champion (950/990)' started by rixx, Nov 7, 2019.
  1. rixx
    rixx Adventurer
    Feb 25, 2010
    14
    Macclesfield. England
    Ive a 950 sm and the elec out put isn't enough to power a heated vest and both gloves.
    Is there any upgrade.
  2. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,180
    Mill Spring, NC
    SE is the same as the SM. I have no issue with jacket, gloves and insoles. Do you have a bunch of extra lights too?
  3. Boatman
    Mar 9, 2005
    14,180
    Mill Spring, NC
    Actually just looked up the specs... all 950/990 are 450watts.
    I run the same gear on my 950 Adventure and an auxiliary light... still no problems. Battery is always fully charged.
  4. albani
    albani Been here awhile
    Jan 3, 2017
    201
    SF Bay
    check your charging system.
    zimtim likes this.
  5. zimtim
    zimtim Been here awhile
    Aug 15, 2012
    111
    UK
    As albani says.
    Check your battery and charging system
  6. rixx
    rixx Adventurer
    Feb 25, 2010
    14
    Thanks for the replies... I don't have extra lights and always have the bike hooked up to the optimate. so I imagine I need to check the system..
  7. tinwelp
    tinwelp Professional Idiot
    Dec 5, 2010
    720
    Deepest Southern France
    Probably worth checking the health of your battery too if it's more than a few years old... but the biggest likely culprit is a dodgy regulator/rectifier slowly cooking the battery through over-charging. Pretty common unfortunately. Another point of trouble is corrosion and eventual melt-down of the big brown three-pin alternator connector. Particularly prevalent when the bike is run a lot in the wet, such as may be experienced in a typical Cheshire climate!
    Cheers... Paul
    rixx likes this.
