950 SE rear shock.
Discussion in 'Dakar champion (950/990)' started by Pitster, Aug 17, 2016.
  1. Gory74
    Gory74 n00b
    May 21, 2009
    5
  2. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    Windsor, United Kingdom
    Don’t forget that the Adv shock doesn’t have the threaded collars for preload and with the 130 spring installed on my Adv shock, it has nearly 9mm of preload when assembles so if I need any more, I just use the preload knob to crank it. I’ve not ridden my SE offroad with a lot of luggage since doing this conversion but I’ll have the chance to ride fully loaded toward the end of this month. In the meantime, I’m going to do my forks this weekend. Going with 5,4 rate springs with the spacers required for a total length of 469mm instead of the stock 5,9 and fresh oil. We’ll see how that goes - I want plush. I’m not fast enough to worry about bottoming out from sky high jumps.
  3. Kiwiktm
    Kiwiktm Adventurer
    Jan 16, 2017
    29
    Yeah plush is good. The 130 spring has proven to be a great swap on my SE.
    It is a much more comfortable machine now for my average Joe riding style.
  4. Gory74
    Gory74 n00b
    May 21, 2009
    5
    Thinking about it the 130 is probably a good place to start. Definitely need to look at the fork springs too but I'll start with the rear and see after that. One change at a time and all that!
  5. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    Yup - one step at a time, just remember that the suspension system works in unison; front and rear. I’ve got the rear sorted for me and now I’m moving to the front. Time to make small sharp curb bumps disappear into plushness...it will feel like I’m riding on a herd of fluffy kittens by the time I’m done :)
    mountaincadre and Gory74 like this.
  6. Kiwiktm
    Kiwiktm Adventurer
    Jan 16, 2017
    29
    And be sure to set up your new spring preload or sag correctly to suit your weight once you have the shock back in the bike. This is often overlooked.
    Gory74 likes this.
  7. godwinmt
    godwinmt They call me Crash
    Jul 26, 2011
    1,857
    Seymour, IN
    That is key...i'm down at an 11.2kg (110N/mm) spring riding pretty harsh, but works super well for my weight.
    Another item people overlook trying to get these bikes to hook up, take your rear axle and slide it as far forward as you can. You should be able to get by with 118 links...shortening the wheel base that little bit really helps to get more weight on the rear.
    Gory74 and alongat like this.
  8. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    But if it’s as far back as possible, the handling is also more stable at high speeds and it won’t wheelie as easily :)
  9. godwinmt
    Jul 26, 2011
    1,857
    Seymour, IN
    Yep, never have had too big of a problem with stability, but getting the front of the pig up is something that used to leave something to be desired :)
    alongat likes this.
  10. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    They are fun when they come right up on their own with nothing more than throttle twisting :)
    godwinmt likes this.
  11. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    Speaking of...need to find time to deal with my forks but now I’m busy installing a completely different rally fairing / tower...[​IMG]
  12. Gory74
    Gory74 n00b
    May 21, 2009
    5
    That looks good Alon. Is that the Raid jobbie?
    alongat likes this.
  13. Gory74
    Gory74 n00b
    May 21, 2009
    5
    So I could possibly use the 255 length spring to reduce the initial preload that Alon has in his as I'm around 20kg lighter? I'm round 78kg these days.
  14. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    Rade Garage (vs raid designs) - did some more work this morning. It’s nearly there...
    Gory74 likes this.
  15. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    Correct or find a progressive rate spring for your weight in either the 255 or 265 length. I’m not sure that WP makes a 130/255 but others will offer it. That will essentially eliminate the 9mm preload my 265 spring has on it when mounted up.
  16. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,951
    [​IMG][​IMG]
    Gory74, godwinmt and SunshineTom like this.
  17. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    6,148
    Narre Warren Victoria
    anydavenow likes this.
  18. GezwindeSpoed
    GezwindeSpoed Long timer
    Jan 15, 2009
    1,049
    The land of the Dutchmen
    What is the definition of a PDS shock?
    What is sure is that the OEM 950SE shock does only have one piston while the ADV shock has a second one which starts doing its job at a higher suspension travel. So the valving on the SE shock must be stiffer to get the same bottoming resistance compared to the ADV shock which has a more advanced mechanism preventing bottoming out.
    I am very happy which my ADV shock extended fully with only a 1mm shim left and about 280mm of travel (130N/mm 265mm spring).
  19. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    243
    Finland
    PDS shock indeed has two pistons. That makes the damping progressive in relation to the depth of the stroke also in compression phase. The SE stock shock is basic one piston shock, also familiar from older LC4 series (the one in the cover of the manual bigborett linked), the LC4 version does not havet High speed external adjustement the SE version has. My wifes Sherco seems to have a 4618 too. Good basic shock but not a PDS.
  20. bigborett
    Nov 29, 2014
    6,148
    Progressive Dampening System.
    I'm no expert, believe me.
    After a bit of a look at a few other "PDS" shocks, some of those only have one piston also. So don't know there.
    But KTM do put a sticker on the shock and list it in the parts list "Wp Caution (PDS Ktm)".
    I'm thinking just a lower end unit.
    I was lead to this by a long time contributor and mod here that had an SE for a number of years and had quite a bit of work done to his shock back in the day.
    I'm sure the ADV shock will be much better than the original, (I hope so as mine is being valved and lengthened at the moment). Just stating that the original is still a PDS unit.
    Certainly don't want to start a war.:defend
