950 SE rear shock.
Discussion in 'Dakar champion (950/990)' started by Pitster, Aug 17, 2016.
  1. charlie264
    charlie264 Long timer
    Oct 27, 2007
    11,794
    Blighty
    My returning insult has to be via PM.
  2. Maoule
    Maoule Long timer Supporter
    Nov 30, 2012
    1,667
    KCMO
    Oh c’mon...I was hoping to add to my proper English vocabulary
  3. LocuL
    LocuL Gnarly Infantry
    Dec 5, 2006
    3,051
    Denmark - Jutland
    SOOOOO....
    What do we need to bring the rear boinger to 300mm.
    Who got the solution. We ALL still need the complete 300mm racing package. I´m aware of the PowerCell option, but we need more options.
  4. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    Windsor, United Kingdom
    Powercell doesn’t have a 300mm offering - he’s got the Ohlins at 277mm
    LocuL likes this.
  5. charlie264
    Oct 27, 2007
    11,794
    Blighty
    Part Number for 140Nm x 265mm Adv R Spring: 91210086S
    alongat likes this.
  6. charlie264
    Oct 27, 2007
    11,794
    Blighty
    How double dare you....He's Canadian.
  7. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    Lol
  8. Boianovich
    Boianovich Old and Cautious
    Jan 29, 2013
    2,300
    The 8th Dimension
    Has anyone done any shock re-valving?
    A lot of info out there for Adventure bikes, but haven't found anything specific the stock SE shock.
  9. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    If I can figure out a 300mm setup then the plan is a restack as well...
  10. Boianovich
    Jan 29, 2013
    2,300
    The 8th Dimension
    Let the Voodoo magic begin.
    Now that I have the off kilter bars straightened out, thanks to Emig Racing Triples, and the fork rebound back, the bike is an unchained beast.
    Time to start experimenting and see what valving improvements can be made. Performed admirably last weekend pre-riding our clubs Big Bike Enduro, but why leave well enough alone?
  11. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    I think the valving setup in my Adv shock is spot-on for my riding but all that can change if I can manage finding a way to 300mm
  12. Boianovich
    Jan 29, 2013
    2,300
    The 8th Dimension
    Stock or did you or someone else re-valve it? Mine was changed, made the mistake of not taking it apart and recording the stack a couple weeks ago when I serviced it.
  13. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    202
    Finland
    I stretched mine from 230 to 255, that needed 5,5mm more lenght to the shock, 265 would have needed 7,5. The latter is with the 6mm KTM part spacer under the stack. With a careless extrapolation, 275 can propably be made by making a thinner spacer. If I recall right the mounting area of the spacer was 3,5mm thick.
    Maybe another 3-5mm could be found with a custom seal head. 290mm I could imagine with the stock shaft. Maybe.
  14. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    I’ve done the calculations - max is 278mm with the current shock shaft. That’s the constraint...I’m going to look at leveraging an EXC PDS shaft but it joins differently at the swingarm.
  15. skuikka
    Jun 23, 2009
    202
    Finland
    Hmmm. Now that I think of this, a longer shaft might have some violent effects in the deeper end of the stroke.
  16. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,936
    This is being done by the likes of Konflict, etc...I just don’t know the magic voodoo involved in the mix of parts and work to get it there (not yet). @LocuL and I are working on something to see what we can do.
    LocuL likes this.
  17. skuikka
    Jun 23, 2009
    202
    Finland
    The shock tube is a changeable part too. Might they use a longer one?
  18. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    5,870
    Narre Warren Victoria
    Might be worth looking at SKF seal heads. By using one of these you were able to take the 690 shock out to 293mm.
    LocuL likes this.
  19. timolgra1
    timolgra1 Been here awhile
    Mar 8, 2009
    639
    No fixed abode
    I had my SE shock revalved and resprung, it was still useless :D
    Find a 990R adv shock and transform your bike
    alongat likes this.
  20. LocuL
    Dec 5, 2006
    3,051
    Denmark - Jutland
    It will happen sooner or later. We need winter to move in and shock goes out.
