950 SE Regulator/Rectifier SOLUTION
Discussion in 'Crazy-Awesome almost Dakar racers (950/990cc)' started by Colorado Uli, Apr 2, 2012.
  1. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,550
    THE MALLEE OUT BUSH IN Sth Oz
  2. veetwo _tls
    Nov 14, 2005
    2,550
    Do you know what a RR looks like ?
    not rocket science but follow the wire back from the RR till find the plug.
    #22
    roookie1 likes this.
  3. Boatman
    Boatman Membership has it's privileges ;-)
    Mar 9, 2005
    13,325
    Petersburg, NY and Mill Spring, NC
    Bottom picture... the arrow is pointing to the connector I belive you are looking for.
    #23
  4. Colorado Uli
    Colorado Uli Must I?
    Feb 6, 2006
    4,506
    Ze Western Slope
    I don't have an adventure model, but I think your stator is down low and up front. I am sorry if it's difficult to communicate over the internet like this but didn't you disconnect the old regulator? So wouldn't you just plug the new one into where you disconnected the old one? Yes, it's a brown connector (plug) with three yellow wires coming from the stator housing. If you ordered the correct regulator, it should be a simple switch out for you.
    Pictures?
    #24
  5. KitaSuccess
    KitaSuccess n00b
    Apr 21, 2016
    1
    New Jersey
    I'm looking for my regulator plug too, I have a 2006 950 SM and the wire leads under the tank so i'm just going to assume i have to take my tank off in order to access it! Hope to hear from you soon Colorado Uli.
    #25
  6. kawasnikov
    kawasnikov Tire eater
    May 8, 2006
    39
    French freezing trails
    I have a 950SE that had troubles with it charging capabilities. I replace my rectifier by a Rick's Motorsport and it worked an hour. I then replace my stator and Battery and got a replacement from Rick. Unfortunately the replacement rectifier comes with a crappy wire weld that i need to redo, only half of the red wire was welded. Moreover that rectifier was dead on arrival, we test it on a perfectly good working 950Adv. Not really impress with Rick's products. I have ordered an OEM and expect it to work fine when relocated on airbox.
    #26
  7. veetwo _tls
    Nov 14, 2005
    2,550
    #27
  8. SpongeRob
    SpongeRob Been here awhile
    May 10, 2007
    311
    Corona, CA
    I was happy with this guy and his rectifier. I liked his "how to" videos and he was very helpful over the phone with all my noob electrical questions. The Mosfet didn't fit with the relocation bracket I bought, so I put it in the original place. It ran considerably cooler than the OEM rectifier, so I'm not as worried about the heat near the pipe. Ebay has lots of choices but most are Chinese garbage. Good luck.
    http://roadstercycle.com/
    #28
    MultiDoc likes this.
  9. veetwo _tls
    Nov 14, 2005
    2,550
    "Mosfet" - Contact Jason either on his ebay store as i posted or at Roadstercycle my 950SE had Mosfet now for almost 11 yrs only had it once play up bike was so hot but was a 48c degree day i had wait 15 min before bike start
    #29
    DistortedAxis and outbacktm like this.
  10. MultiDoc
    MultiDoc Been here awhile
    Mar 26, 2016
    282
    Wales, UK
    Sorry for the stupid question, what's the difference between the kit with the fuse and the one with the circuit breaker ? Any pros or cons for either ? Which one is best for the SE ?
    P.S: I'll be relocating my R/R soon and looking into upgrading it at the same time.
    #30
