950 Super Enduro "Quick Question(s)" Thread...
Discussion in 'Dakar champion (950/990)' started by WARRIORPRINCEJJ, Jun 20, 2010.
  1. SpeedyR
    SpeedyR SE in the SE
    Aug 12, 2005
    1,965
    ATL, GA
    that was probably me with the carb o-ring info.
    I have caps on both of mine and the o-rings are the same size.
    I don't recall off the top of my head what size I got but they did work, however they were not the exact correct size. I may try to go back and get the right sized ones next go around. I'm going to be tearing into it again in the next week and will update what I find with regards to sizing and parts. I ordered a Kawasaki float bowl gasket and will see if its the correct size for the 950 carbs.
    BK.RD.RNR likes this.
  2. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,306
    SouthWest (AZ)
    Carb inlet and vent o-rings
  3. BK.RD.RNR
    BK.RD.RNR Torque Stick
    Dec 8, 2008
    6,866
    Livin' in the 90's
    Can anyone tell me where to find an electrical switched circuit under the seat.
    I'm installing an Eastern Beaver 3CS kit, and would like it switched if possible.
  4. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,393
    Mill Spring, NC
    You could tap into the ACC2 fuse.
  5. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,718
    THE MALLEE OUT BUSH IN Sth Oz
    TrailTech Voyager Pro optional Light DashBoard / Idiot lights ?
    Has anyone gone to there Trail tech voyager pro solely as the main dash ?
    what are the wiring codes on the AU/UK model 950SE for the individual optional warning lights
    first 4 my main ones i'm after
    High Beam -
    Fuel -
    Neutral -
    Oil -
    Indicators -
  6. Chalk
    Chalk Been here awhile
    Feb 14, 2016
    391
    England
    Thinking it’s time to do my water pump seal and bearings. I know Alon is working on a upgrade but does anyone know anything about the kit being offered by team Tsunami racing?
  7. veetwo _tls
    Nov 14, 2005
    2,718
  8. veetwo _tls
    Nov 14, 2005
    2,718
    Who still makes pannier racks for soft luggage & rotopax for the 950SE ?
    Sent message to Boatman waiting on reply just looking for other options sellers
  9. SpeedyR
    Aug 12, 2005
    1,965
    ATL, GA
    I know this is a long shot but does anyone have a photo of the rear hub without bearings installed on the brake side?
    had a bit of an "incident" while riding the KAT (Kentucky Adventure trail) last week with the rear wheel and trying to figure out how much damage I did as well as what I need to remove to get a better idea of if the hub is trashed or just the bearings.
    I'll start by cutting out what I hope is the outer race and then see what's in there.. the spacer and inner "tube" spacer are both shot.
  10. SpeedyR
    Aug 12, 2005
    1,965
    ATL, GA
  11. Maoule
    Maoule Long timer Supporter
    Nov 30, 2012
    1,668
    KCMO
    Kinda hard to tell...did the snap ring come out ok?
  12. Maoule
    Nov 30, 2012
    1,668
    KCMO
    Maybe this will help?
  13. Maoule
    Nov 30, 2012
    1,668
    KCMO
    And this: IMG_6349.jpg
  14. Maoule
    Nov 30, 2012
    1,668
    KCMO
    Ain’t that some shit...looks like they don’t sell the hub separately, which you probably already know. Dont know what your budget is but the complete rear wheel assm is $647 at ktmpartshouse.com
    I take that back...Babbits has the hub complete for $233
  15. SpeedyR
    Aug 12, 2005
    1,965
    ATL, GA
    in two pieces. :(
    I've got parts 5 and 6 out now, but the outer race of #4 is still in there. put some PB Blast on it overnight and will dig into it more tomorrow. so far it's not too bad, but getting the race out will be difficult. there's no real edge any more to grab with anything. I've got slide hammer and a few other bits that usually do the trick on stubborn bearings but usually there's an inner race to grab. :oscar
    might be able to salvage the hub but concerned with the outer bearing surfaces.
  16. Helibee
    Helibee Been here awhile Supporter
    Jan 26, 2014
    491
    If you have a tig machine, run a couple opposing beads on the race and it should fall out. Works great on pressed neck races too.
    SpeedyR and outbacktm like this.
  17. Boianovich
    Boianovich Old and Cautious
    Jan 29, 2013
    2,379
    The 8th Dimension
    I've cut races out with a Dremal and cutoff wheel. They are hard enough that if you get mostly through it, a couple strikes with a small, sharp chisel does the trick.
    Good chance you'll nick or cut a little into the hub, but it it shouldn't compromise holding force on replacement bearing.
    SpeedyR likes this.
  18. Bearded Hooligan
    Bearded Hooligan Moto Addict
    Mar 30, 2004
    1,127
    Flat, Hot & Humid South GA
    The support brace on my Safari tank has bolt that is just spinning the brass insert. What methods would you recommend for removing this bolt and putting in a new brass thread once removed? Obviously without damaging the tank.
  19. godwinmt
    godwinmt They call me Crash
    Jul 26, 2011
    1,857
    Seymour, IN
    can you grind the bolt head off then extract the remaining bit and insert once you have it off with better access? keeping it cool is the hard part...
    Once it's off, McMaster etc. have expanding nutserts you can use.
  20. LocuL
    LocuL Gnarly Steward
    Dec 5, 2006
    3,093
    Denmark - Jutland
    if it fails the tanks are weldable
