950SE: 2->2 change to 2->1 Jetting Question
Discussion in 'Dakar champion (950/990)' started by HiOctaneOverland, Nov 10, 2019.
  1. HiOctaneOverland
    HiOctaneOverland Been here awhile
    Dec 3, 2013
    106
    Lost, On A Compass Heading of 365
    Currently I have the standard 2->2 pipes on my 950SE with Akra cans. The carb set up and jetting is pretty perfect, running with the dB killer inserts fitted.
    I’m considering a change to 2->1. What changes (if any) do I need to make to the carb set up? Or can I just fit a 2->1 pipe and run with a single can? Or single can with dB killer removed for better flow?
    Thoughts, observations and advice please.
  2. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    7,788
    Basalt Colorado
    I did it with no changes. Jetting was okay. It tends to be a little lean from the factory for emissions but shouldn’t be an issue
  3. Dusty
    Dusty Long timer
    Jun 15, 2007
    1,536
    Bismarck
    Pull the inserts and give it a rip.
    On my 990 when i had the 2-1 to me the butt dyno liked it with inserts out, throttle just felt better... Just kinda makes sense pushing 2 lumps into 1... i think.
    I know not a carbed bike but i didnt have the 02s in the loop.
  4. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    3,880
    Gardnerville NV
    What collector 2 into 1 are you using?
  5. Qwik
    Apr 27, 2008
    7,788
    Basalt Colorado
    I used a modified stock exhaust on my 950Adv. My Brother Had a welding shop cut the pipe. Rotate it and weld it. Works great.
    Bonnie & Clyde likes this.
  6. HiOctaneOverland
    Dec 3, 2013
    106
    I simply bought another pipe from KTM and got it modified at the local welding shop. That way I can run my normal 2->2 set-up or a 2->1 with just a few minutes work to change them over.
    The real reason I’m looking at a single-side can is so I am able to fit a Rottweiler Endurocell supplementary fuel tank on the left side. The 950SE ideally needs longer legs if you want to take it places.
    Qwik and Bonnie & Clyde like this.
  7. Chalk
    Chalk Been here awhile
    Feb 14, 2016
    345
    England
    It will run richer in the mid and top end. I have the Rotti set up with Yoshi pipe.
    Just bought Alon’s air filter kit so will sort the jetting after install
    Qwik likes this.
