950SE owners in OZ
Discussion in 'Australia' started by MymoJoe, May 25, 2009.
  1. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    Narre Warren Victoria
    The mid pipe was replaced as the original had been altered for a single pipe set-up.
    The subframe has been braced in the usual spot at the rear and powder coated, possibly another repair, hasn't worried me too much.
    I also have the standard airbox with the foam prefilter.
  2. Flexo
    Flexo Been here awhile
    Nov 6, 2007
    102
    Did it have a 2 into 1 when you got it BB?
  3. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    No, it was changed over before I got it.
    The guy had made the crossover pipe out of the original mid, not realising that the midpipe was about $450.
    I prefer to have the dual pipes.
    Not sure if I have the altered mid, I think I have.
  4. pete40
    pete40 Life Behind Bars
    May 1, 2006
    1,434
    Boggo Rd. Jail
    Does that pipe shield stuff deflect much heat?
  5. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    It will do a bit. The radiant heat should be reduced quite a lot.
  6. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    Anyone running a rottwieller intake with filter skins.
    If so, where did you get them?
    The postage is a killer for such a cheap item.
  7. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
  8. troy safari carpente
    troy safari carpente #501 Team f5oolery
    Nov 21, 2005
    30,798
    "Swednavia" - f5ederation of scandwegia
    As the K1W1's would say;
    "Pit sum pitrol innut, end guvvut the berries bro..." :clap:lol3
    nevgriff64 and bigborett like this.
  9. AUSSIEADV
    AUSSIEADV Long timer
    Sep 5, 2006
    7,033
    Ned and Wild's fight site
  10. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    Not all fuel pumps are created equal Al. Looked at those could not find specs on it.
    Not many have a pressure bypass or inbuilt check valves.
    The pressure is quite important on the 950 or a regulator of some description needs to be fitted.
    The check valve will hopefully negate the need to turn the fuel off all the time with some of these vacuum pumps and electrical. They can get siphoning which can lead to hydraulic lock on start up.
    Wasn't looking for the cheapest option.:-)
    AUSSIEADV likes this.
  11. Flexo
    Nov 6, 2007
    102
    Why replace the fuel pump BB? Did you consider the Dr Bean mod? From all accounts the pump itself is quite good, it is just the points that let it down.
  12. richo360
    richo360 Long timer
    Sep 5, 2011
    2,471
    Bottom of the barrel and still digging
    Apparently he did, but didn't have the stock pump to begin with.
    bigborett likes this.
  13. richo360
    richo360 Long timer
    Sep 5, 2011
    2,471
    Well anyway, I've got mine all ready for the upcoming ktm rally other than fitting up the big tank ..
    Thought I'd take it for a 80 k loop early this morning.
    Um... new gt723 and wet roads dont mix well.
    Or do, depending on how you view things.
    Am really looking forward to a full week on this bike.
    Other than spare tubes and a Boltz pack and a spare rec/reg, anything else I should take ?
  14. Young-Gun
    Young-Gun KTM Tragic
    Dec 6, 2005
    1,301
    Brisbane, Australia
    Are any of you blokes considering selling your SE? please PM me if you are? maybe not now, but in the foreseeable future. Seller's remorse :(
    Dukehunt likes this.
  15. richo360
    richo360 Long timer
    Sep 5, 2011
    2,471
    Maybe think about it after the rally. Perhaps.
    Six bikes is just a bit too many.....
    Young-Gun likes this.
  16. Flexo
    Nov 6, 2007
    102
    It's hard to admit that you have too many bikes but the rego does kill you, especially if they are not your main source of transport.
  17. bigborett
    bigborett Hipster
    Nov 29, 2014
    4,306
    Try 9.
  18. Dukehunt
    Dukehunt Lost in Translation Nev 2.0 Super Moderator
    Feb 20, 2007
    2,678
    Melbourne North
    9 is a good number but I am considering reducing that to 7
  19. horizonchasser
    horizonchasser Adventurer
    Jul 15, 2011
    75
    Hunter valley nsw
    Hey Ritcho, I have mounted a spare rec/reg under the seat ,relocated the original to the left side of bike ,still on the original,(have a digital volt meter on dash,to monitor)I carry a spare aftermarket electric fuel pump on a custom mount for the safari tank with a deutsch plug ,replaced the original at 14 k when it died.i carry a spare small Shoria battery,to jump start myself or as a replacement,I put GB racing covers on to stop the brake pedal ,gear lever puncturing the covers .i also put on a Scott's Rear disc guard. A brake snake is handy,radguard do a guard for the SE.spare brake pads can be bolted inside the edges of B and B bash plate,their is room to mount spare gear lever brake pedal under the seat,saddlemen do a great seat.Oxford heated grips are good.a side stand relocation bracket to get it off the engine .a steering dampner is a good investment.
  20. richo360
    richo360 Long timer
    Sep 5, 2011
    2,471
    Thanks mate.
    It's got new pads, uhd tubes and tyres all fitted in last 2 weeks.
    Has the heat shield under rec reg and a spare rec.
    Has carbon case guard over right side crankcase.
    Will look at spare levers to take... and a portable battery jumper pack.
    Fuel pump ( factory ktm) is two rides old, should last this ride. If not there's a ktm parts truck coming along.
    Rad guard will be investigated.
    Hopefully all bases covered otherwise.
    Cheers
