1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
990 Adventure TPS problem?
Discussion in 'Dakar champion (950/990)' started by DC1200, Jan 19, 2011.
  1. Adventurer2
    Adventurer2 Adventurer
    Apr 3, 2006
    19
    South Africa JHB
    Is the TPS unit from the later 990 that uses 2 TPS's the same as the one used on my model that only has 1 TPS? I see the TPS alone is not available without buying the whole throttle body....and with the South African exchange rate I'd have to donate a kidney....
    If so, anyone have a KTM part #?
    #41
  2. Gustavo.Ramos
    Gustavo.Ramos Long timer
    May 19, 2008
    1,260
    Accross the pond
    the TB unit is basically the same. bot 990 generations share the same configuration in TB's, both have two TPS for two set of butterflies. the difference is that for pre 2009 the TPS is sold with a set of TB's attached (and proportionally priced) while after 2009 the same part is available separately - can't remember the P#, but is displayed in a few Tunececu/TB's/FI 990 related threads.
    #42
  3. jconly
    jconly Been here awhile
    Aug 18, 2009
    600
    NYC
    Yup, both front and rear TPS are different, and available from the newer fiche.
    #43
  4. Adventurer2
    Apr 3, 2006
    19
    South Africa JHB
    My 990 only has one TPS, on the front TB.
    #44
  5. jconly
    Aug 18, 2009
    600
    NYC
    Really? What year?
    An early EFI here, 2007 (US).
    Let me clarify, two TPS sensors.
    One for primary butterflies, and a 2nd TPS for the secondary flies.
    They just happen to be located on front & rear. Not necessarily one primary for each cylinder.
    #45
    guglemonster likes this.
  6. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,075
    East Med, Greece
    All 990s have 2 TPSs. The one that creates headaches is the one on the, front throttle body. The second one is on the rear. The same as 950s. You need to check microfiche 2010.
    Cheers
    #46
  7. Gustavo.Ramos
    May 19, 2008
    1,260
    Accross the pond
    Really!?
    A picture will help a lot!
    #47
  8. guglemonster
    guglemonster Crivens!!! Supporter
    Aug 28, 2007
    1,861
    Italy
    well why not?? you take ithe secondary BF off and shut it down via tunecu :)
    one left :)
    #48
  9. Gustavo.Ramos
    May 19, 2008
    1,260
    Accross the pond
    Just to save some weight!
    :hide
    damn, my favorite emoticon is gone....
    #49
  10. Adventurer2
    Apr 3, 2006
    19
    South Africa JHB
    I was under the impression that the TPS is the item found on the front TB at the base, linked directly to the bottom TB butterfly, there is a bigger unit at the top of the rear TB which I understand to be a stepper motor, which opens the upper butterflies as the motor demands more, or less air, controlled by the ECU, the lower butterflies are controlled by the throttle cable, and this info is relayed to the ECU by the lower TPS, of which my model, 2007 ADV, only has a TPS fitted on the front TB, the rear TB has nothing fitted at the bottom, it seems to assume the TPS trusts that the TB's are balanced perfectly.
    I understand from a pretty clued up local KTM tech that the front lower TPS is the problem, highly unlikely that the stepper motor will cause an intermittent idle, I'm glad to hear that the lower single TPS is the same as the TPS used on later models with a TPS fitted to each lower butterfly, on the FISH for my model it does not list the TPS as a stand alone unit...
    #50
  11. Adventurer2
    Apr 3, 2006
    19
    South Africa JHB
    Yup, sort of how I understand it, but I'm told the rear unit is a stepper motor, it tells the butterflies what to do, rather than gets told where the butterfly is.
    #51
  12. guglemonster
    Aug 28, 2007
    1,861
    Italy
    nope mate, the rear unit is a stepper motor, because is a stepper, but you also have a TPS on the secondary butterfly, you see the stepper opens while primary is operated by cables, BUT the CPU needs to know what is where, or no stepper operation and or iddle or map loading and on and on :)
    you can simply take away the BF leaving the actuator and deactivating the system and the secondary TPS, simply inverting the cables and mounting it with the proper connector and you will have a perfect spare for the front ones :)
    :D:D:D:D:D:D:D
    I'm done from too many filters today, hope I did the right tagging mate
    people, correct me if I pointed out the wrong onese :)
    #52
  13. jconly
    Aug 18, 2009
    600
    NYC
    I know I'm an outlier, but I also had my rear, 2nd TPS sensor fail.
    Ran a map with the 2nd throttle set to 100% for about 500 miles.
    With about 40k on the TB at the time, I don't think the sensor liked being open all the time, and it bit the dust.
    Just saying, it can happen.
    #53
  14. guglemonster
    Aug 28, 2007
    1,861
    Italy
    I do prefere letting active but removing the discs
    faster, easier cleaner.... strange the sensonr would be damaged.... sorry
    #54
  15. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,075
    East Med, Greece
    Well that is the first one reported.
    guglemonster
    The 2 TPSs are not the same, unfortunately, so they are not interchangeable. No If we could make a metal plate to adjust an aftermarket TPS... the start at $4-$5 in Alibaba. That could save a lot of money, since they seem to fail often at as early as 50k kms...
    :ear
    #55
  16. guglemonster
    Aug 28, 2007
    1,861
    Italy
    Gefr, I am quite sure it works, two SMR in Italy did it and also some one here, wish I had time to go the garage and take apart the SD race group I have as a spare to check the mounting :) statistically in the EU I have seen plenty starting to show early failour close to 60.000 most of them failing abrouptly at 80.000 but I know personally plenty of 950 carbs and 990 EFI with more than 150.000 with no issue, also here among us there are plenty of over 100.000 km, the rekord man has 200.000 plus and no issue. and again I see plenty of later model fail more often than early models .... your idea is really good, and you are the MAN to do it, and you know it mate :)
    #56
  17. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,075
    East Med, Greece
    I believe the sensor is powered by 5Volts and its resistance varies, allowing 0.5Volts idling and 3.5V at full throttle. Now I need to remember school physics.
    Cheers
    #57
  18. Adventurer2
    Apr 3, 2006
    19
    South Africa JHB
    So, I guess the best way forward is to order and fit a TPS from the front TB of the later model....lotsa moolah, but I guess the only way....
    #58
  19. Adventurer2
    Apr 3, 2006
    19
    South Africa JHB
    Strangely my bike came without those TB trumpets.....
    #59
  20. Gustavo.Ramos
    May 19, 2008
    1,260
    Accross the pond
    My opinion is to be sure there is in fact a TPS problem before ordering any parts.
    Either we're not looking at the same parts or your bike has been subject to some hacking... those trumpets (two black pieces on top) are the ones that keep the airfilter in its place. You may have shorter ones as i think i've seen them before in the aftermarket, but definitely you need to have these parts or similar.
    #60
