990 Adventure weight loss!
Discussion in 'Dakar champion (950/990)' started by pvmoto, Sep 7, 2012.
  1. pvmoto
    pvmoto Instagram @ pvmoto
    Jan 14, 2012
    330
    North Rocks
    Hi all,
    I need to strip the big girl down for routine maintenance and thought I might do some mods to reduce weight. I've got a two into one Arrow (custom) on it already. Anyone have any tips on shedding weight from the 990's, apart from pipes and single disc conversions?
    Cheers
  2. rburkat
    rburkat Been here awhile
    Feb 5, 2010
    316
    Squamish, BC
    Get a lithium ion battery you save 8 lbs right there.
    Remove your crash guards. I've crashed many times without mine and you just scuff the tank or protector up. If you want performance, you dont need to look pretty. But I try not to crash
    thebarber likes this.
  3. piercalif
    piercalif Biciveloce
    Jul 2, 2008
    414
    San Diego North County Beach Area
    it weights virtually nothing compare to the stock pump
  4. bigkuri
    bigkuri Long timer Supporter
    Oct 31, 2004
    1,126
    New Zealand
    +1
    Exactly right, those tanks are tough, and unlike the crash bars they won't catch on stuff and throw your bike around.
    Also get rid of rear pannier rack, use a giant loop.
    Other than that I'm all ears too.
    Battery swap with Lithium one is a no brained and is now on my list. Front brakes to a single disc not so, as I do too much road riding and track days, heavy on front brakes.
    Plastics don't weigh too much, but I guess is an area?
  5. pvmoto
    Jan 14, 2012
    330
    North Rocks
    Anyone know if Safari tanks add much weight?
  6. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    7,788
    Basalt Colorado
    Not at all. They weigh less than the stock stuff they replace.
  7. Oli990
    Oli990 Been here awhile
    Sep 18, 2009
    109
    Belgium
    you can remove the black plastic in the upper fairing
  8. Terence FFM
    Terence FFM prof. cat-herder
    Apr 12, 2006
    364
    Frankfurt, Germany
    I imagine that a swap to a 2.5" rear ought to shed a few pounds too, not to mention making it a off-road worthier. The switch from a 2.15" to a 1.85" or 1.6" is probably negligible but worth doing nonetheless. Up front a single disc should shed a pound or two as well though. These changes have the added benefit of reducing unsprung and rotating weight which is always better.
    #8
  9. Johnf3
    Johnf3 Long timer
    Apr 10, 2007
    1,280
    West Texas
    Convert to a foam air filter set up and lose the airbox is worth another 4-5 pounds. Battery, 2/1 exhaust with aftermarket muffler, and air box is over 25 pounds less weight. Yes you can feel it, and no it is not the same thing as losing 25 pounds of body weight. The single disk set up is probably worth another 5 pounds but I am waiting on someone to offer a 320 disc kit using the stock caliper, so I have not done that mod yet. Tubeless wheel conversion is a few pounds of unsprung weight especially if you run heavy duty (and they ARE heavy) tubes. I hate those things.
    I also am one of the ones who take a minimalist approach to bolting on a bunch of extra stuff, No need for crash bars. If I damage the tanks bad enough in a crash comprehensive insurance (which is cheap) will replace them.
    #9
  10. Flanny
    Flanny Flanny-it-up!
    Feb 18, 2003
    2,739
    Ottawa, Ontario, Canada, the World, the Universe
    I've go tall of this done on the 950RR and it makes a huge difference (lion battery, single disk, tubeless, air box, exhaust) bike handles amazingly off-road...
    #10
  11. Yascher
    Yascher Been here awhile
    Oct 8, 2009
    394
    Moscow, Russia
    better keep original airbox if you ever come close to river crossing, as it makes the bike almost submarine-able!!!
    #11
    snarley likes this.
  12. bikepsych
    bikepsych Been here awhile
    Feb 2, 2010
    397
    Gold Coast of California
    Don't mean to "high" jack the thread, but what is the water crossing difference between having the airbox and replacing it with a Rottweiler? I haven't been in water over the footpegs yet but am itching to try. ;-) I guess it would weigh less in the water anyway right?:evil
    BG
    #12
  13. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,353
    Reno
    Lower part of airbox is not watertight anyway
    #13
  14. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,228
    Indiana
    yeah, negligible difference. Plus the oil in the filter will repel the first bit of water intrusion as well as the airbox would, and the velocity stack height doesn't change at all. I'd be really surprised if it made a difference.
    I'm still super wary of pulling my crash bars. I had them off for awhile...then put them back on and promptly went down on a muddy hill and they did their job well...and then got caught on stuff another mile or two down the road so I took them off again. Now they're back on. Maybe I'll take them off after reading this, haha.
    #14
  15. renogeorge
    Apr 7, 2007
    6,353
    Reno
    Remove center stand. I carry a small single rod which works in conjunction with sidestand to hold either front or rear off the ground.
    I am making the single disc and abs removal mods. I always forget to weigh parts. But there are several pounds there.
    Use soft bags without racks. I run a 2 into 1 exhaust and only had to make an aluminum pipe guard for the right side.
    An easy one if it works for you--remove passenger pegs.
    Not suggesting that these mods are right for everyone. But if lighter is your thing.....
    #15
  16. FinTec
    FinTec Been here awhile
    Sep 27, 2013
    448
    Colorado
    renogeorge,
    Intrigued by your center stand mod. Do you have a picture you can share?
    #16
  17. Pismo950
    Pismo950 Been here awhile
    Mar 8, 2012
    215
    Pismo Beach
    :lurk
    #17
  18. rattis
    rattis Long timer
    Apr 3, 2010
    4,255
    East of the seas of Kattegat
    How much do you weigh?
    BMI?
    If you're 250 pounds and save 6 or so on a lithium ion battery it's a bit ridiculous.
    Lose some lard, that is if you're on the upper part of the BMI scale.
    It's cheaper and you'll maybe live longer.
    OK no fancy farkels but then life's hard :D
    #18
    Deviant666 and Qwik like this.
  19. maden
    maden Been here awhile
    Apr 12, 2013
    125
    Norway
    You may be right about the health aspect…
    The claim that body weight should somehow have anything to do with how heavy or light a bike handles, is just wrong… Now if you were to become much stronger, that would help in handling the big bike :)
    There is a reason to why people do not use the 990 Adventure for MX racing, and that reason is that the big bike is too heavy.
    The 990 will never be a MX bike, but every Kg you remove will make it better.
    Thats my opinion at least.
    Edit:
    Forgot to add some useful info… I think one of the best ways to shed weight is to pay close attention to what gets bolted on the bike. I try to consider that any farkle i bolt on should replace a part on the bike. That is not always possible like navigation stuff and luggage, but then it is just a matter of not going crazy with that stuff… Use of soft luggage will save plenty of weight.
    T
    #19
  20. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,351
    SWEDEN, Norsjö
    Maybe we can get some real weights in?
    Did weigh mine in:
    235 kg (518 lb), fully fueled, stock toolkit onboard, tire tools and first aid kit.
    List of what has been done that would change the weight:
    Wings exhaust
    CPR Trio
    Touratech Skidplate
    Pyndon monster 320 mm suspension
    Excel rims, 1.6 wide front, 2.5 wide rear, heavy duty inner tubes
    Single caliper
    Air horn
    Extra LED lights
    Oil pressure gauge
    Might have been a few more minor mods that would affect weight that I have missed.
    /Johan
    #20
