990 - Missing 3rd-6th gears
Discussion in 'Dakar champion (950/990)' started by HellSickle, Aug 19, 2019.
  1. HellSickle
    HellSickle Scone Rider
    Sep 19, 2005
    19,723
    Fort Collins
    During a long ride this weekend I noticed my 990 shifting starting to get a little notchy. In town today I suddenly have only 1st and 2nd gear. I suspect the problem will be obvious when I remove the right engine side cover, but I suspect others in here might have already experienced this problem. Spring or shift cam issue is my guess. Thoughts?
  2. Johnf3
    Johnf3 Long timer
    Apr 10, 2007
    1,275
    West Texas
    Just in case you have not checked anything yet, the first thing is to check the shift lever itself. It gets loose and hits the case, which causes issues when you try to shift out of the lower gears.
    Boatman likes this.
  3. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    Thanks. I already checked that.
    I did some more research. I'm suspecting that one of the 6 pins on the shift mechanism may have backed out. I'll pop out the oil filter screen and take a peek with a scope to try and confirm. The symptoms fit. It the pin to shift from 2nd to 3rd backed out it would still allow shifting between 1 and 2, but no higher. Here's some picture from another thread.
    nk14zp, Jeff Sichoe and mountaincadre like this.
  4. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
    You don't even need a scope it can be seen after removing the oil screen.
    /Johan
    roookie1 likes this.
  5. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
  6. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    I pulled the filter screen & took a peek with my scope. One of the steel dowels on the hub has backed out as I suspected. Fortunately it hasn't fallen out and disappeared into the bowels of the beast.
    When I get the new hub I'll probably tack weld the dowels into place to eliminate this problem.
  7. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
    One looked like it was a tiny bit out just got a screwdriver in there and gave it a few hits in that spot. Not looked at it since, many years and kilometers ago.
    Welding sounds overkill.
    /Johan
    Boatman likes this.
  8. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    Overkill? Yes, I'm an anal-retentive mechanical engineer. :deal
    I will at least thoroughly peen the area around each pin. Bike is at 50k miles, so that will probably do for the next 50k.
    #8
  9. Rharr
    Rharr Been here awhile
    Apr 5, 2014
    905
    Tucson Az
    center punch where the pin and hub meet should do nicely in peening it in place.
    #9
  10. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    5,967
    West of the West, Oregon
    Steel pins and aluminum housing means no welding. I'd just replace it, chances are you'd get no more problems.
    #10
  11. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    Didn't realize it was aluminum. I am replacing the entire assembly. It would be silly to go to all that work and not replace it. Steel in aluminum is not a good solution for something that goes thru a lot of temperature cycles. Aluminum expands at 2X the rate of steel. I guess I'll just peen the shit out of the aluminum surrounding the pins.
    #11
  12. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    Got the part installed. I ended up with 7 neutrals, as the clutch was disengaged. Figured out the outer pressure plate wasn't properly aligned with the basket splines. Easy fix.
    However, now my oil pressure light is on. I didn't open up the oil pump or remove it's gear. Any thoughts before I put her down and open the entire side back up? I'm going to try and peek in the filter screen opening to see if the oil pump gear is turning with the engine.
    #12
  13. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    Never mind. Problem found. I must not have aligned the clutch gear with the oil pump gear before I hit it with the impact wrench. At least all of the pieces were right there. My mechanic needs a good ass-kicking. :baldy
    #13
  14. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,303
    Finally made it to Fruita!
    Well, that's what you get for using an impact gun.
    #14
  15. Zuber
    Sep 28, 2004
    5,967
    Plastic gear. Everyone does it once.
    #15
  16. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    No, it's steel.
    #16
    Boatman likes this.
  17. Zuber
    Sep 28, 2004
    5,967
    If you broke a steel one... You need to put down the hammer and air gun.
    #17
  18. HellSickle
    Sep 19, 2005
    19,723
    Fort Collins
    The torque needed to seat the nut is enough to break the gear, impact wrench or not.
    #18
  19. CRW
    CRW I dont want a pickle
    Oct 8, 2005
    893
    Cotati Ca. USA
    I get that. But using a wrench or socket will allow you to feel the something is not seating. The impact just drives it home with out finesse or feel. Thats a lot of force to shear a hardened gear!! Have fun with the repair!
    #19
