1. eNewsletter Sign Up
990 short levers
Discussion in 'Dakar champion (950/990)' started by Koen, Sep 28, 2019.
  1. Koen
    Koen Adventurer
    Aug 11, 2013
    50
    The Netherlands
    Kinda wondering if you guys are offroading with shorter levers? Find it hard to get used to the 2/1 finger clutch control, i really need to focus on it else im 4 fingering ( :p ) the lever and was thinking that a shorter lever might make it a little easier.
  2. zimtim
    zimtim Been here awhile
    Aug 15, 2012
    111
    UK
    My clutch lever bent and snapped at the break point.
    Up to that point I had to 4finger , if I used two fingers I found the lever would stop on the two fingers and clutch wouldn't fully engage.
    Unstable riding with four fingers on clutch lever and not gripping the bar properly
    I don't have an issue with the front brake lever mind you.
    But definitely recommend short lever for the clutch if you have a similar issue to me
    Ferd likes this.
  3. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,533
    Here and There
    @Koen MidWest Mountain Engineering shorty clutch lever highly recommended!
    Not cheap but they transform clutch feel and operation...
    mutt550 and HighRiver like this.
  4. FakeName
    FakeName Wile E Coyote SuperGenius
    Jan 1, 2007
    2,154
    San Diego
    Yup. A Midwest Mountain Engineering lever was my first mod.
    HighRiver likes this.
  5. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,063
    SouthWest (AZ)
    funny... just put a set of MME shorties on my 350 a few minutes ago..... was thinking these would be great on the 990. Definitely easier clutch pull....
    HighRiver and braaap! like this.
  6. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Likewise @oldfuddy , the MME levers are the best thing for pairing with hydro clutches... have same on both the 640 and 950, joy!
    oldfuddy likes this.
  7. Koen
    Koen Adventurer
    Aug 11, 2013
    50
    The Netherlands
    They look nice indeed, but before i have it here in Europe the price will almost be twice as high. Shipping, import tax etc etc.
  8. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Like many have done before... stick the knob end in a vice and break it off at the indent. If you have TIG welding gear you can then blitz a blob end and file / shape to suit :)
    Cheap and it works.
    #8
    Ferd and mountaincadre like this.
  9. anydavenow
    anydavenow Long timer
    Nov 30, 2011
    1,121
    Sydney, Australia
    I run a short clutch lever from one of the MX models, but I now can't remember whether this will fit the stock master cylinder or only the newer ones (which I've retrofitted). That said, there might be an equivalent older short one from an MX bike that'll work.
    #9
  10. Tobey
    Tobey Adventurer
    Jan 10, 2010
    19
    MME say they are no longer available for the 990's :(
    #10
  11. braaap!
    Mar 16, 2005
    4,533
    Here and There
    @Tobey That's a bugger!
    Maybe MME might do another run if the numbers are there in a 'group buy'. ..
    #11
  12. Tobey
    Tobey Adventurer
    Jan 10, 2010
    19
    I did a little more digging, I was actually looking at Slavens that says they aren't available. The MME website doesn't say they are out, however it also doesn't say much about shipping to Aus.
    #12
  13. braaap!
    Mar 16, 2005
    4,533
    Here and There
    aus as in Austria or Australia?
    MME levers are the bestest!!
    Money is only money and easily forgotten (lost from partners eyes...) MME 1st class... The vice method, 3rd Class!
    Choose Grasshoppper.
    #13
    Tobey likes this.
  14. braaap!
    Mar 16, 2005
    4,533
    Here and There
    @Tobey Back in 2017, shipping was $34USD. Our peso is .68 now, was .73 then... They are worth it though :)
    #14
  15. Tobey
    Tobey Adventurer
    Jan 10, 2010
    19
    Well the vice trick worked well for me last night and did well on the ride to work. MME's are on the to-do list for sure.
    #15
  16. Koen
    Koen Adventurer
    Aug 11, 2013
    50
    The Netherlands
    Hmm thats not a bad idea. Guess ill have to ask the dealer and see if they know which one will fit :)
    #16
    anydavenow likes this.
  17. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,471
    Cremona, Italy
    There's only two types of Magura clutch pumps: series 163 and series 167. For both standard or short levers are available.
    The mighty 990/950 use a 163 series and levers look like the ones in the above picture with the red knob.
    If you look closely you can see there's a gibbosity that is needed to engage the clutch switch (under the zip tie in the upper lever). Some levers come without it.
    #17
    anydavenow and Koen like this.
  18. Koen
    Koen Adventurer
    Aug 11, 2013
    50
    The Netherlands
    That was super helpful! Found the small lever. only 27 euro :) Ofc its not super engineered etc, but it will do the trick :) I'll check the micro switch thing tomorrow :)
    #18
  19. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,601
    Payson AZ
    guess i'm in the minority, i tried the MM lever and didnt like the extra long throw it had.
    #19
  20. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,063
    SouthWest (AZ)
    The throw can be adjusted to less than stock through two separate adjusters if preferred.
    #20
