a long, long XS650 project.
Discussion in 'Some Assembly Required' started by toglhot, Aug 10, 2020.
  1. toglhot
    toglhot Been here awhile
    Aug 10, 2020
    141
    AUSTRALIA
    This will be a very long project: I have psoriatic arthritis which affects my fingers, hands arms and so on, so I can never ride a bike again. My enjoyment comes from building stuff, even though it takes a hundred times longer to do anything, I still manage in my workshop. I can't manage hammers, screwdrivers and those sort of tools very well, and using them causes a lot of pain, so everything takes such a long time to do now. I've since had my index finger and middle finger on my left hand fused, the little and ring fingers have had joint replacements, just last week. Can't do much of anything at the moment with left hand out of action and the right useless hand is even more useless by itself. I'll be getting that one done a little later in the year.
    I bought an XS650 a while back, it was in terrible shape: Every nut and bolt was rusted, aluminium was badly oxidises and the upper engine case had chain damage, tearing the shifter drum bearing housing off.
    I bought new, second hand cases, punched the original number on , bead blasted everything, rebored the barrel, bought new pistons, rings, gudgeons, cam chain, gaskets, seals and quite a few other bits and pieces, had the oil tube, points covers, head nuts re chromed, polished the sidecovers, tappet covers, breather box, dipstick, cam chain adjuster and carb tops and bottoms.
    The cases, barrel, head and rocker cover were painted silver and the motor re assembled. The motor started up with the first push of the button and I synchronised the carbs using my homemade manometer. Unfortunately, I found it rather drab looking, so I tore it down again, blasted the paint off, re painted it black, re assembled it and started it up again, first push of the button and with the short pipes it certainly made a racket. The new timing light I bought has proved troublesome: It doesn't flash and the cuts running for some reason, so I'm stuck with static timing until I can find the problem.
    Whilst waiting for parts, I de spoked the wheels, the spokes were totally stuffed so they went in the bin. I ground the rim edges to smooth off the tyre lever damage, then polished them. The hubs were mounted on my lathe and trued up before polishing. I also polished the lower sliders, brake backing plate, top triple tree and brake hose mount. The switchgear was blasted clean, re wired and polished.
    I also removed frame tabs for sidecovers and seat, welded new sidecover tabs on and beat up some aluminium sidecovers and polished them to see how they look, probably paint them later as it looks a bit much. A new battery carrier, made from 3mm aluminium, was bent up, along with new rubber mounted carriers.
    I've fabricated some nice, chunky, 10 mm thick aluminium engine brackets which I've polished and also bought some new stainless fasteners which I've also polished. Also fabricated a single seat base with rear cowl.
    I do all work myself: Spannering, paint, upholstery, polishing, tin work, etc. The only thing I can't do is chroming and sand blasting the frame. Today I raced around trying to get parts for an electronic ignition build, no go, too expensive. So, I'll have to be content with points. Yes I know I can get a Pamco, or a Hughes, or a Newtronic, but no enjoyment from buying stuff.
    Anyway, here;s some pics of the bike as bought, showing the damage.
      File size:
      209.6 KB
      208
      File size:
      88.1 KB
      205
      File size:
      58.7 KB
      205
      File size:
      331.7 KB
      205
      File size:
      631.3 KB
      204
      File size:
      669.8 KB
      207
      File size:
      61.4 KB
      204
      File size:
      211.7 KB
      203
      File size:
      289.9 KB
      202
      File size:
      247.2 KB
      200
    blacktruck, Scoozi, banjaxxed and 6 others like this.
  2. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    Some more bits that came with the bike, most will be sold off as I'm building a custom.
    mrsdnf likes this.
  3. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    Here's some of the polishing I've done.
      File size:
      266.7 KB
      107
      File size:
      247.3 KB
      106
      File size:
      70 KB
      105
      File size:
      65.4 KB
      105
      File size:
      244.1 KB
      106
      File size:
      352.2 KB
      105
      File size:
      310.6 KB
      105
      File size:
      312.7 KB
      104
      File size:
      49.8 KB
      106
  4. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    this is the first rebuild in a stand I made for the assembly and the first manometer I made up. Engine is in a new wheeled stand I made up so I could move it around my workshop.
    Gupster likes this.
  5. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,251
    Lost between the Dandenongs and Yarra Valley
    Wow. Nice work toglhot. You certainly picked one poorly maintained bike to rejuvinate.
  6. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    This is the second rebuild in the wheeled stand and my second manometer build.
    JagLite, Gupster, AK650 and 5 others like this.
  7. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    Video of manometer in use.
    JagLite, AK650, gmk999 and 2 others like this.
  8. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    First start up.
    #8
    JagLite, MacNoob, AK650 and 2 others like this.
  9. sruss67
    sruss67 Been here awhile Supporter
    Aug 2, 2009
    408
    Devonport, Tasmania, Australia
    WOW Toglhot, your workmanship is amazing, especially considering the limitations you have in your hands you mentioned earlier.
    The polishing and finish on that engine etc is flawless.
    Keep up the great work, looking forward to the progress on your build.
    #9
    AZ Pete, Scoozi and mrsdnf like this.
  10. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    these are a couple of side panels I beat up from 1.5mm ally. difficult to make fit as top and bottom rails are not on the same plain, bends are at different spots and angles are different. After shaping them I bent and twisted them to follow the rails. Once done I inserted grommets in them, spun up some positive stop grommet nuts and added tabs to the frame for mounting. Then, just to see what they would look like polished, I spent a little time on the polisher.
      File size:
      338.1 KB
      103
      File size:
      291 KB
      101
      File size:
      291 KB
      103
      File size:
      285.7 KB
      102
      File size:
      226.9 KB
      103
      File size:
      330.4 KB
      101
      File size:
      180.8 KB
      102
      File size:
      308.4 KB
      101
      File size:
      288.6 KB
      102
    #10
  11. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    And some chunky engine mounts I made from 10mm ally, polished them and bought some stainless fasteners to fit them, then polished them as well.
    #11
    JagLite, AK650, Scoozi and 2 others like this.
  12. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,251
    Love your skills toglhot.
    #12
    AK650 likes this.
  13. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    A new seat base, twice. Built this seatbase with cowl from 1.1mm sheet. After cutting to shape, the sides were beaten down and the rear section rolled up. A cowl was then bent to shape around the upright and welded. Front mount is a rubber covered spigot, welded to a flat plate and bolted to the nose. I then bent up a raised section to cover the tank mount and welded that in Position. The rear mounts are grommets set into the cowl into which are fitted a couple of positive stop nuts I turned up. A couple of threaded tabs were welded on the rear seat loop and the rear of the seat is bolted to them. Rubber mounted seat to guard against vibration.
      File size:
      315.9 KB
      86
      File size:
      75.2 KB
      86
      File size:
      334.9 KB
      84
      File size:
      210.2 KB
      84
      File size:
      231.4 KB
      84
      File size:
      297.8 KB
      84
      File size:
      257.3 KB
      84
      File size:
      369.3 KB
      87
      File size:
      373 KB
      86
      File size:
      631.3 KB
      86
    #13
  14. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    A couple of switchblocks I resurrected. Bead blasted the cases and levers, soldered new wires on the circuit boards and polished the exteriors. Probably won't be using them, but, they were annoying me!
      File size:
      527.3 KB
      76
      File size:
      669.8 KB
      77
      File size:
      477.8 KB
      77
      File size:
      631.3 KB
      77
      File size:
      451.2 KB
      75
      File size:
      401.3 KB
      77
      File size:
      265.6 KB
      75
      File size:
      266.7 KB
      77
    #14
    JagLite, Scoozi, zzzak and 4 others like this.
  15. neppi
    neppi Long timer
    Mar 9, 2017
    1,569
    Tauranga, New Zealand
    Look ad daat, Jimmy, Look ad daat!
    Awesome job, Man! I’m jealous
    #15
  16. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    Little known fact: Those phillips head screws on Jap bikes aren’t phillips heads at all, they are JIS. Although they look the same, JIS heads have a slightly different slot angle, continual use of Philips head drivers results in wrecked screws. Easy to fix: Buy JIS drivers, or replace with allen heads. I chose the latter approach. The clutch pressure plate screws had JIS heads, and of course were all stuffed. To fix, I faced the head of the screws to remove the slots, cut the threads off and bored a 6mm hole through them. An allen head screw was then cut to size and inserted, a worthwhile mod this one. Another problem area on the XS650is the sump filter: On the corner nearest the oil intake, the mesh is flat, rather than folded, so it tends to tear with the excess pressure. To fix, I beat up a small, thin, ally cover, covering the area and drilled a few holes for the oil. This is a very well known mod!
      File size:
      66.7 KB
      82
      File size:
      67.3 KB
      83
      File size:
      66.7 KB
      81
      File size:
      83.7 KB
      82
      File size:
      64.9 KB
      82
      File size:
      230.2 KB
      83
      File size:
      317.5 KB
      83
      File size:
      214.5 KB
      84
    #16
  17. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    Couple of tools made up to help stripping and reassembly. The auto advance is held in place by a thin castellated nut usually undone by a hammer and punch, you can guess the condition of the nut after removal. To lessen the damage I turned up a bit of tube and filed down to leave four teeth. Filing is a little rough, but it works. Second tool I made was a puller to remove the rotor. Thread on the rotor is rough, so I threaded a bit of pipe on the lathe with a very tight thread, takes a bit to get it on the rotor thread, but once on it works fine. I also welded up a rod to hold the clutch centre hub in place when tightening and untightening. It locks into the grooves of the centre hub, independent of the outer basket. Usual tool is a plain and a fibre plate bolted together, thus locking the inner hub and basket together. It's not unknown for these tools to break a tab off the basket, not a chance of that with this tool. I also turned up a Delrin panel hammer using a ball turner attachment I made for the lathe a while back, first time it's been used in anger. Used the hammer to straighten the rear guard. The guard has some rather large dents beaten into it for some reason, also a few dings around the tail light bracket. Couldn't get the dents out of the rolled edge, but nothing a bit of bog can't fix.
    That's about it for now, not much I can do at the moment with just one hand. I have assembled the hubs over the last couple of days, bead blasted the disk carrier and started drilling some holes in the disk with a special grind on the drill bit, these disks are damned hard, wrecked a couple of bits before grinding steeper cutting shoulders and a steeper rake on the drill, did the job, no more wrecked bits.
    #17
    JagLite, Scoozi and mrsdnf like this.
  18. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,251
    Very nice.
    #18
    AK650 and Fast Idle like this.
  19. sruss67
    Aug 2, 2009
    408
    Beautiful work, loving the home made tooling and fabrication, serious skills :beer
    #19
    mrsdnf, AK650 and neppi like this.
  20. toglhot
    Aug 10, 2020
    141
    AUSTRALIA
    A little more work: Just put the front hub together using sealed bearings, bead blasted the disk holder and drilled a few holes in the disk. Also put the rear hub together with sealed bearings. The Teles are also together, I removed all the casting marks from the sliders and polished them again, they look 100% better without the casting marks. Unfortunately I dropped the left side slider and damaged the seal surround, bugger! I'll try the aluminium brazing rods I have and see i f I can repair it. I'm thinking of doing away with the sidecovers and either making a polished aluminium battery carrienr and making a feature of it, or I'll shorten the sidecovers at the front and attach brackets to the battery carrier for the sidecovers, that way I wont have to mak e splayed manifolds.
    All one handed, had the left hand index and second finger fused and the ring and pinky got new PIP joints. Not easy with just one hand all this work, but, this Yamaha is yelling at me!
    #20
    JagLite, AK650, scot_douglas and 2 others like this.
