Across America on a Janus Motorcycle
Discussion in 'Ride Reports - Day Trippin'' started by TorribleZone, Aug 6, 2018.
  1. REALGRAVEROBBER
    REALGRAVEROBBER LEAVING GRAVES EMPTY
    Nov 1, 2008
    907
    GFY, Montana
    Your initial post, using works such as "portmanteau" on a motorcycle camping forum ... Tl;Dr.
    Looked at your website and entry models are $7,000. Zang that makes me jANUS wince.
    I have far less than that sum into all 3 of my:
    1.) 09 Klx450R
    2.) 06 VStrom 650
    3.) 99 Dr650se.
    I like the basic design. There could be a market for your motorbikes. I wish it well
    #41
  2. TorribleZone
    TorribleZone Integer Surgo Meliore Omine
    Oct 26, 2016
    9
    Goshen, Indiana
    Sorry for the big words. Those are some great bikes @REALGRAVEROBBER.
    #42
    Allucaneat likes this.
  3. The Virginian
    The Virginian YouTube n00b Supporter
    Apr 30, 2008
    4,734
    Spotsylvania, VA
    I'm really enjoying the ride report and hope you finish it. I will be keeping my feelers open in case a demo days pops up in VA.
    Eric
    #43
  4. TorribleZone
    Oct 26, 2016
    9
    Goshen, Indiana
    Thanks for your patience with how long it is taking me to complete this ride report! This is the sixth in a series of posts (that I will be wrapping up soon!) detailing a 6-day trip across the US on a Janus Halcyon 250. The Halcyon is a lightweight, small-displacement motorcycle that we build here in Goshen. It certainly is not designed for transcontinental trips, but we thought it would be a great way to demonstrate the bikes capabilities and I wasn't going to pass up the opportunity to ride from coast to coast! I have written report originally as a blog post to be read by motorcyclists and non-motorcyclists alike, so much of what I cover may already be familiar to many of you. Regardless, I hope you enjoy reading about the trip as much as I enjoyed riding it.
    ACROSS AMERICA ON A JANUS MOTORCYCLES PART 6: THROUGH THE VALLEYS OF THE TWO GREAT RIVERS TO CHICAGO
    At 6:30am on Wednesday May 29th I was back on Interstate 80 heading east out on Council Bluffs, Iowa toward Naperville, Illinois. This would be the shortest leg of the whole trip at just over 430 miles and I had high hopes of actually making the rendezvous point with the rest of the riders as there was word that Mike Kneebone, President of the Iron Butt Association would be in attendance. I was also looking forward to catching up with the rest of there group as I had not seen or spoken to anyone from the Wyman group since my unplanned stop in Rock Springs, Wyoming two days before. While this day's mileage was relatively short, the 750+ miles I had ridden the previous day had taken quite a toll on me. This section proved to be the most challenging day of riding for me of the whole trip. Unlike my trusty Halcyon, which sped along without a care in the world, only requiring a once-every-100-mile fuel up to be perfectly happy, my sore body rebelled every time I remounted the bike. One of the things that I discovered on the trip was that after a certain point, the discomfort of riding reaches a plateau. It doesn’t get better, but then again it actually doesn’t get any worse. I took comfort in knowing that old George Wyman must have had it far worse pushing and bouncing along on his motorbike 115 years before me with barely a road to follow, much less the smooth asphalt of Interstate 80. Another factor that contributed to the difficulty of the day’s ride was the temperature. Up to this point, the temperatures had been almost perfect for riding; a bit on the cool side, but not too cold that I needed to use insulated gloves. Now, as the Midwest sun beat down on the plains I started to really feel the heat.
    Following the advise of Tim Masterson, I had contacted Mario Winkelman of LDComfort in preparation for my ride. LDComfort makes specialty base layers designed specifically for long distance motorcycling. Mario was generous enough to donate a set of his base layers for my ride and walk me through their proper use. Some people might wonder what the big deal could be with base layers—they’re just underwear, right? Well, yes, but these are also a whole lot more and great deal of experience, research, and design went into these specialty garments. The basic idea behind LDComfort gear is that it is made of two separate layers, the inner of which transfers moisture to the outer layer to evaporate and properly regulate body temperature and moisture levels while simultaneously alleviating chafing. You can literally soak a piece of LDComfort 2-layer fabric, ring it out and blot a piece of paper towel to the inner side and it won’t show any moisture. These are two key factors to comfortable long distance riding. For more extreme long distance riders, such as those competing in the Iron Butt Rally (11,000 miles in 11 days), this can go beyond comfort and become a health issue. Contrary to what most riders would assume, the best garment for hot or cold weather riding is the same thing: a close fitting long sleeved shirt and full length tights. In cold weather they obviously keep you warm, but in hot weather, they allow you to function in conditions that would be impossible without them. The secret, once again, is with moisture. The body keeps itself cool with perspiration and evaporation, essentially creating its own air-conditioning. These specialty garments are able to retain the moisture necessary for evaporation and cooling while keeping you dry, also very important to sustained comfort while riding.
    Image courtesy LDComfort
    I was able to experience the surprising ability of LDComfort gear to keep me cool in the 85-degree temperatures and full sun I experienced across Iowa and Illinois. The trick is literally to pour just enough water down your sleeves and back to soak into the material. You then open the zippers on your sleeves and CLOSE the vents on your jacket. While this at first seems counterintuitive, it makes sense once you try it. While riding, air enters your sleeves, travels up and over your moist LDComfort outer layers, and provide cool air over your core. By not opening the vents on your jacket you allow this moist air to stay in your jacket rather than blasting on through and drying out you and your sleeves immediately. By leaving your collar slightly open, exhaust air is allowed to passively escape only after it has lost its cooling effects. I found that stopping around every hour or so was enough to almost feel like I was running my own air-conditioning. Not only does this keep you cool, but it allows you to retain moisture and stay better hydrated. This was probably the hottest day of my ride and I felt very grateful to have the benefit of this technology.
    The only photograph I took on this day of the trip. I was pretty beaten up and was just enjoying lying in the grass on the side of the road.
    Around 2:00pm I fueled up and grabbed a bite to eat in Iowa City, 60 miles short of Davenport and the Illinois state line. Just before Davenport, Interstate 80 heads south through Peru, Illinois, and Joliet, then back up through the south side of Chicago. I decided to take a more northerly route on Interstate 88, following the course of the Rock River. Once into Illinois, I again altered course and left the interstate at Sterling to get back on Route 30. The slightly more direct path across Illinois promised lower miles and the reduced speed limit wouldn’t really hamper the Halcyon. It was wonderful to leave the interstate and get back on a two-lane road again across fields that looked more and more familiar to the farmland of northern Indiana. I was tired and sore, and relished every break I count afford time to take out of the saddle.
    As the afternoon progressed, I knew that making the 7:00pm rendezvous dinner in Naperville would be down to the minute. I had my fuel supply pretty well figured out by this point and decided that with my main and auxiliary fuel I could make it all the way to the rendezvous without purchasing more fuel. On a graceful sweeping curve just short of Shabbona, Illinois my Halcyon coughed, sputtered, and coasted to a stop on the side of the road. I had been watching my odometer for the past few miles and was ready to quickly dismount, spin off the Rotopax auxiliary tank, fill up with my extra gallon of fuel, and get back on my way in under 5 minutes. Speeding into the outskirts of Aurora, Illinois, Route 30 rejoined Interstate 88 and crossed the Fox River at 7:00pm with just 10 miles to the rendezvous point. As I pulled into the parking lot and shut off the engine, I had the surreal experience of still hearing a Janus engine running. Rechecking the bike, I looked up to find another Halcyon pulling in right next to me. It was John Tan on Halcyon #107, a local Aurora Janus owner who had come out to join for dinner and catch up on my journey thus far. Tim Masterson must have been watching my SPOT track because he walked out to meet me and usher me into dinner in my full riding attire. I shed my gear and found a seat right next to what turned out to be the President of the Iron Butt Association, Mr. Mike Kneebone. Also in attendance were several IBA members who had ridden in from as far as 100 miles to join us for dinner. After what turned out to be my first rendezvous meal and some great conversation on the history of the IBA, I turned in for the night at a nearby motel. It had not been the longest day of the trip, but it had certainly proven to be the most difficult stretch of my ride thus far.
    A very tired your’s truly sitting between Tim Masterson and Mike Kneebone, President of the IBA at the Naperville, Illinois rendezvous.
    For George Wyman’s 1903 account of this portion of his journey click here: http://wymanmemorialproject.blogspot.com/p/iv-through-valleys-of-two-great-rivers.html
    Spotwalla track of the day’s 758-mile ride across Wyoming, Nebraska, and into Iowa.
    #44
    zookster, Frey Bentos, MYUMPH and 3 others like this.
  5. JB2
    JB2 Dirt Of The Earth
    Jan 4, 2008
    1,879
    Edge of The Great Plains
    @TorribleZone - Good meeting you, Devin and the rest of your fine crew a couple of weeks ago. I'm thinking of a trip on the TAT with the Halcyon. Not the same path that George Wyman took but more the same conditions. Regardless, I had forgotten how much fun a small caliber bike could be until I test rode two of the Janus models. I believe a lot of riders have forgotten that experience because of the always "bigger, better, faster" mantra we are sold. Your bikes are proof that small and simple are just as much fun if not more.
    #45
    TorribleZone likes this.
  6. ChairmanMaose
    ChairmanMaose OneLessCar
    Feb 23, 2017
    2,025
    Is there room in the Janus for a larger engine? Great looking bike, BTW.
    #46
  7. Frey Bentos
    Frey Bentos Probably doing a drawing. Or scratching my arse.
    Nov 29, 2007
    996
    Fermanagh. Ireland
    Coming from Ireland, it's almost inconceivable to think of weather that's too hot to ride a bike..
    #47
    B10Dave likes this.
  8. Scot
    Scot Been here awhile
    Aug 26, 2003
    760
    Fredericksburg, VA
    I have a Halcyon on order as of last Friday. I'm excited.
    #48
    Huck369, MYUMPH and The Virginian like this.
  9. The Virginian
    Apr 30, 2008
    4,734
    Spotsylvania, VA
    No way! You have let me come over and check it out. ;)
    Eric
    #49
    MYUMPH likes this.
  10. Scot
    Aug 26, 2003
    760
    Fredericksburg, VA
    When I ordered I wondered what you’d think. We both have a penchant for bikes off the beaten trail. When she arrives, I’ll ride it over.
    #50
    The Virginian likes this.
  11. ChiliPepperGarage
    ChiliPepperGarage Spork
    Oct 4, 2014
    312
    Smith Valley, NV
    I'm having a Paul Harvey moment here. Where is the rest of the story?
    #51
  12. brgsprint
    brgsprint Long timer Supporter
    Apr 26, 2012
    1,758
    Endicott, NY
    #52
