AdamChandler's "Felicity" 1995 K75RT Build Thread
Discussion in 'Some Assembly Required' started by AdamChandler, Mar 7, 2019.
  1. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    5,800
    Zer0-Zer0-Zer0-Zer0
    What are you trying to do, have some spare paint for touch-ups or paint some of the panels?? If needing touch-up only, you should be able to get touch-up paint markers in that code from the dealer...
    If you're trying to paint panels and/or match paint to some of them, the painter of your choice should be able to get the ingredients and their weights to make up that color code...
    #21
  2. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    7,187
    Hanover, NH USA
    just touch ups. BMW doesn't have this paint anymore supposedly.
    #22
  3. Lead Wrist
    May 26, 2007
    5,800
    Zer0-Zer0-Zer0-Zer0
    A-ha... You could still ask local paint shop if they'd mix you small container of that paint code...
    Or, alternatively, do you have touch-up markers for either Aspen Blue or Raising Blue for current/past Rolf? It may not be perfect match but it could help as "close enough" interim? :D
    #23
    AdamChandler likes this.
  4. mr_10brook
    mr_10brook Been here awhile
    Apr 17, 2008
    236
    Central Indiana
    At one time Holt was a distributor for Glasurit paint. Maybe he still is. http://www.holtdesignorganisation.com/
    #24
  5. Johann
    Johann Commuterous Tankslapperous
    Feb 11, 2006
    6,211
    Europe
    Used injector cleaner on a K100RS and three K75s with no problems but obviously add to the recommended dilution. If that doesn´t work then taking the injectors to somewhere that works on industrial plant, lorries/tractors etc to be tested and cleaned would be a lot cheaper than buying new injectors or paying a specialist injector shop to do the work.
    #25
  6. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    Opened her up last night.
    Gasket Replaced
    Spark Plugs Changed
    Replaced ignition coil wires...I have a question on these though.
    The OEM ones were wrapped with a metal base. These NGK replacements are just rubber. Do I need to purchase the metal surrounds? See OEM here:
    The replacements are just rubber: https://www.beemerboneyard.com/12121459876csn.html
    They snapped on like they should. I'll try and fire the bike up tonight but wanted to post here first and check.
    A few more photos:
    Will do valve checks tonight as well.
    #26
  7. Johann
    Feb 11, 2006
    6,211
    Europe
    I always thought those OEM metal covers were designed to make it easier to to remove the caps by using a set of pliers to pull on the tabs rather than serving as RF suppression, but could be wrong.
    #27
    TownPump and AdamChandler like this.
  8. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    I guess we'll find out when I start her up. the silicone plugs appear to have snapped in, just not as hard as the OEM ones did. I didn't detect any spark issues but these coils were 25+ years old. $50 to replace them seemed like cheap insurance.
    #28
  9. bungees
    bungees epsilon semi-n00b
    Mar 22, 2014
    1,130
    the great southern abyss - Brandon, MS
    Might want to add a pint or two (up to 25%) Marvel Mystery Oil with the oil change and change it early the first time.
    #29
  10. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    #30
  11. mr_10brook
    Apr 17, 2008
    236
    Central Indiana
    You do not need to buy the metal shroud and I don't even think that they would fit. Your plug wires are good to go.
    #31
  12. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    #32
  13. bungees
    Mar 22, 2014
    1,130
    Not familiar with that particular product, but Motul makes "good stuff" - was just thinking some kind of flush / cleaning given your comments on the oil condition, sounds like you're on it.
    While on the subject of "snake oils" :-), regarding injector cleaners - I have used both Techron and Lucas Deep Clean, found the Lucas to be superior in the RT, though that issue was related more to carbon deposits.
    #33
  14. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    Great tip on Techron, I go between that and Royal purple. IDK if it's working or not. I feel stupid buying it once a year for my motors but I keep doing it.
    #34
  15. bungees
    Mar 22, 2014
    1,130
    #35
  16. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    will grab this. Thanks everyone.
    #36
  17. bungees
    Mar 22, 2014
    1,130
    Here are a couple more Permatex products you could take a look at. They are heat and oil/fuel resistant - also recommended by Permatex for valve cover gaskets:
    Permatex PermaShield Fuel Resistant Gasket Dressing & Flange Sealant - this is equivalent to the "Hylomar Blue" BMW spec's for some applications.
    Permatex Ultra Blue Multipurpose RTV Silicone Gasket Maker.
    #37
  18. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    I get CRC products for free. Will try and find a comparable product from them.
    #38
    bungees likes this.
  19. mr_10brook
    Apr 17, 2008
    236
    Central Indiana
    Did you not get the BMW valve cover gaskets? I don't know if you need sealant if you use the gaskets.
    #39
  20. AdamChandler
    Feb 29, 2016
    7,187
    Hanover, NH USA
    Acquired from BeemerBoneyard but it keeps failing out of the groove when I go to put the head on the motor.
    #40
