AdamChandler's "Rosie Red" 2018 GS Adventure Build Thread
Discussion in 'GS Boxers' started by AdamChandler, Oct 4, 2018.
  1. Fosters
    Fosters Loner Supporter
    Nov 6, 2010
    501
    florida
    Pb blaster and a cordless impact with the correct torx bit.
  2. JimVonBaden
    Feb 11, 2005
    94,930
    Alexandria, VA
    Good tools don't help if you don't use them correctly. Looks like you were not all the way seated when you torqued on it. Tap in the Torx fully after you heat the bolt head toll it sizzles. There should be enough meat on it still.
    Dackrover likes this.
  3. JimVonBaden
    Feb 11, 2005
    94,930
    Alexandria, VA
    Also worth a try. Lots of loctite on these bolts.
  4. Fosters
    Nov 6, 2010
    501
    florida
    Worse case is to drill the sucker out with a bit just narrower than the threaded part of the bolt...then pick out the remains for the threads and chase with a tap
  5. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    9,505
    Hanover, NH USA
    This was torqued down by my old Torx set and I definitely wasn't seated fully. No Loc-Tite from me but factory definitely has some on there.
    PB Blaster, I spray it underneath? Is it safe to heat gun the head(will be careful not to melt the plastic)? That won't melt the bolt?
    I'll certainly take up the hammer trick to get it fully seated. I definitely was using the right torx (T40) but this was screwed up already and I basically made it worse.
    Thanks guys!
    Fosters likes this.
  6. Fosters
    Nov 6, 2010
    501
    florida
    Yes spray from beneath..it will also wick around the head if you spray from top down...
    I’d advise against heat for fear of damaging the plastic and thus creating more work and expense
  7. AdamChandler
    Feb 29, 2016
    9,505
    Hanover, NH USA
    Thanks. Yeah, the OEM Plastic pan for the subframe I believe is a $250 part.
  8. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,451
    Portland, Oregon
    $441 !
    AdamChandler likes this.
  9. AdamChandler
    Feb 29, 2016
    9,505
    Hanover, NH USA
    Off to get some PB Blaster and some courage.
  10. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    10,339
    Ft Likkertail , USA
    If PB Blaster doesn’t work than a 50/50 ATF and acetone mix might...
    JUST DONT HAVE AN OPEN FLAME ANYWHERE....:kboom
    :lol3
  11. The Cone of Silence
    The Cone of Silence Been here awhile
    Jan 16, 2006
    412
    Kurrajong, New South Wales, Australia
    I had the exact same problem Adam and couldn't apply heat due to the plastic. I tried cutting a slot into the top of it with a Dremel so I could attack it with a screwdriver but that didn't work as it became too weak to handle the required torque and threatened to tear itself, so I then tried a bit with an anti-clockwise thread and still couldn't get the right amount of purchase on it.
    A friend of mine suggested dousing it from the top with WD40 and leaving it for 2 hours so I did just that, then got the mole grips on it and gently rocked it back and forth until it came free.
    tonyubsdell, Fosters and AdamChandler like this.
  12. AdamChandler
    Feb 29, 2016
    9,505
    Hanover, NH USA
    thinking a bit more about this, what if I were to put something around the bolt to allow a heat gun to do its job without melting the plastic. I think that could be beneficial in getting things to loosen up a bit.
  13. Dackrover
    Dackrover Been here awhile
    May 17, 2018
    383
    New York
    Take a breath...or a "breather"...maybe loosen the OCD grip the bike and this whole project has on you for a bit. You have plenty of courage already, a willingness to jump in with both feet, imo.
    I know that anyone who has such a carefully laid out sequence of installs and videos to make, etc., has such an excess of mental energy tied up in the effort, that he might not end up doing his best and most careful/patient work, as a consequence. Take things a bit easier on yourself, no pressure...the project and the winter have months ahead yet to go!
    Ignore my parental (and likely received as thoroughly annoying) tone if possible -- just genuinely trying to look out for you as a friend, thinking back on how you had wanted to distinguish this bike's modification adventure from your last! Don't want to see you spoil the zen-like meditation of the mod experience, chewing yourself up over avoidable mistakes.
  14. Beairmo
    Beairmo Keeping it real Supporter
    Jul 14, 2012
    433
    Indianapolis, IN
    Correct bit and electric impact should pop it out, as previously mentioned.
    But if it strips then I would Dremel cut a groove and use hammer type impact with flat bit. That will get it it.
    Norsman and AdamChandler like this.
  15. AdamChandler
    Feb 29, 2016
    9,505
    Hanover, NH USA
    The good thing about this GS build, I pretty much know what to do so each mod is taking almost no time at all. This translates to when I hit a snag like this, I can just stop for the night and chill because I'm really not in a time crunch. I have until April of 2019.
    Today's Progress:
    Couldn't get CanOpener wired up given the fact I couldn't remove the top luggage rack. I did get the front shock installed and progressive steering damper on.
    Fosters and Dackrover like this.
  16. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    12,572
    NH
    Forget PB, get Kroil.
  17. JimVonBaden
    Feb 11, 2005
    94,930
    Alexandria, VA
    Do not use acetone with plastic, especially ABS. It will melt it.
    tonyubsdell and rider1150gsadv like this.
  18. jaystonewee
    jaystonewee Been here awhile
    Feb 26, 2013
    485
    CO
    I've used a rubber glove and the correct bit to remove stubborn allen/hex key hardware before.
    Kinda like this
    tonyubsdell and AdamChandler like this.
  19. AdamChandler
    Feb 29, 2016
    9,505
    Hanover, NH USA
    might give that a try.
  20. Norsman
    Norsman ...a GSophile
    Dec 5, 2004
    3,376
    Plover, WI
    This. And let the PB blaster sit overnight. Man, I hate it when this happens. Good luck.
