adapt the GSXR600, GSXR750 or GSXR1000 pipe to the DR650
Discussion in 'Thumpers' started by B1, Jun 13, 2011.
  1. B1
    B1 Carbon-based bipedal
    Jun 7, 2009
    4,971
    Arse-trailer
    This GSXR mod works incredibly with the 'BST magic' mods - cheap do-it-yourself mods to the stock DR650. Read about it all in this BST magic thread. This info applies to 1996+ models only.
    WHY ADAPT THE GXR600/750/1000 & HAYABUSA EXHAUSTS?
    Most are half the weight of the stock pipe, and similar to aftermarket pipes.
    Dyno charts indicate similar performance increase as aftermarket pipes.
    It's far quieter than aftermarket pipes, but still sounds great.
    It's good for the environment - you are recycling.
    It never needs repacking.
    It looks legal - if aftermarket pipes can get you booked in your country, then this comes stamped Suzuki and your average cop wouldn't have a clue.
    The GSXR exhaust works brilliantly with the carbie mods in this video.
    IS IT CHEAPER THAN JUST BUYING A POWER PIPE?
    It can be an incredibly cheap mod if you get the pipe cheaply from the wreckers, and make your own mid pipe. It will still be pretty cheap if you buy an aftermarket mid-pipe and get the can cheaply (say under $50). But the current mid pipes are quite expensive, so make sure you don't pay too much for the GSXR exhaust.
    HOW MUCH EXTRA POWER WILL I GET? AND WHAT DOES IT SOUND LIKE?
    Here's a dyno chart that shows the GSXR1000 pipe matching or slightly outperforming the FMF pipe over most of the rev range. Please note I don't know what jetting was involved, the results came from this site here.
    WHY IS A MID PIPE REQUIRED?
    You can use your existing header pipe, but will need a midpipe with a flange to connect to the four bolts on the GSXR muffler. You can buy an aftermarket one or make your own if you can access some pipe bending and welding equipment. Alternatively, try an exhaust specialist - in Australia most motorbike exhaust specialists will only charge around AUD$200 to make the mid pipe (US$150).
    One problem with the available mid pipes is they tend to push some of the longer GSXR exhausts out past the rear fender... ugly and exposed.
    WHICH GSXR PIPES WILL WORK ON THE DR650?
    You've got a fair bit of choice here, depending on how fussy you are about size, weight and performance.
    The lightest can is from the GSXR1000 2001 and 2002 models. This one is shorter and lighter due to a fair bit of titanium. A bit louder than the larger GSXR exhausts. Make sure it is stamped x40F0x. Weighs 4.5 pounds or 2 kg. This is the holy grail, most have been snapped up now.
    Second best option is the GSXR1000 can from the 2003 and 2004 models. It will be stamped x18G1x. Slightly heavier, longer and fatter but still fits very well. A bit louder than the larger GSXR exhausts below.
    Third option? GXR600 2001 to 2003 models and GSXR750 2000 to 2003 models. Weighs about 7 pounds or 3 kg. This version has steel internals so a bit of extra weight (but still far lighter than the stock can!) and a smaller outlet pipe so it's quieter and a bit more restrictive. It is stamped "35F01".
    Fourth option? Old Suzuki Hayabusa cans, stamped 24f0. Weighs about 7 pounds or 3 kg. Plenty of these around and each Busa had two! These have a high volume and good sized outlet designed to let a lot of exhaust through, so very good performance but also a quiet exhaust note but much deeper sound than stock.
    Other options include getting aftermarket GSXR pipes, although the problem here is they are often very loud with no power advantage, and while there are some very cheap ones on Ebay they are usually very poor quality.
    WHAT ABOUT A SPARK ARRESTER?
    Please note, the GSXR pipe doesn't have a spark arrestor. In some countries this can be a big issue. FMF have a screen type SA that pops right into the back of the GSXR muffler. See this link for more info and pics.
    WHAT ABOUT JETTING?
    The stock muffler is so restrictive that you will notice better performance immediately with the GSXR pipe. However, to maximize the benefit you should rejet and open up the airbox too. We cover cheap do-it-yourself mods in this BST magic thread, otherwise just buy an aftermarket jetting kit and open up the airbox.
    This has been collated from various sources, but particular thanks to the guy who did this webpage (check it out, heaps of info and pic there) and guys from the Thumper Talk and DR Riders forums as well, a lot of their info is in here.
  2. SamM
    SamM Jeep Overlander
    Nov 1, 2004
    1,478
    West Virginia
    Very good information johnnok! I'd like to also add that the 2000 and 2001 Suzuki GSXR100 X40FOX Titanium muffler can also be fitted to the KLR650. My muffler was purchased off eBay for $25 and it included the stock GSXR1000 midpipe. I was able to sell the GSXR midpipe for $25 which netted me a free 3.8lb titanium muffler. Still can't believe that deal. I purchased a DR650 flange ($15) from KienTech and a KLR650 stainless steel midpipe ($99.95) from Hindle. What a difference! I highly recommend this muffler. It never needs packing and has a great sound. Worth the effort!
    My muffler sits a little further back on my 2008 KLR than I'd like. There is plenty of room for it and I plan to fix that!
    SamM
    Mauro Lopes and Thumper lover like this.
  3. gplassm
    gplassm Been here awhile
    Apr 9, 2009
    710
    Western Mass
    While some money can be saved going the GSXR can route, the biggest problem is that the mid-pipe is not easily home fabricated. By the time you buy the mid pipe kit, and the can, you can end up very close to the price of a bolt on solution. Somebody here used a Yamaha WR450F can and it worked well, but I do not recall how he solved the mid-pipe issue...
  4. rowie
    rowie Been here awhile
    May 1, 2011
    393
    Proserpine, QLD
    For the people with the RS model (1990 - 1994. Not sold in the USA) the GSXR muffler is too big and won't fit without major surgery to create enough clearance with the tyre and sideplate.
    In this location, a 5.30 tyre will hit and it needs to be moved out at least 3/4"
    The only option for a slip on that I could find is a Marving, which are made in Italy. They are chrome steel and it weighs about 2 pounds heavier than the GSXR, but is still much lighter than the boat anchor twin system that was installed on the RS :D
    Comparison shot:
    They also make mufflers to suit newer model DR's, so they are another option.
    Cheers,
    David.
  5. B1
    Jun 7, 2009
    4,971
    Arse-trailer
    agreed. in my case the exhaust specialist did all the fitting and parts for only $190, and i only paid $50 for a scratched GSXR can which came up nicely with some sanding and polishing.
    i still think some guys might shell out the big bucks though, if they want the same performance increase as an aftermarket pipe but keeping it far quieter and looking stock...
  6. doug s.
    doug s. Long timer
    May 2, 2011
    1,392
    md
    also note that the first post in the above-referenced thread was someone using the HINDLE muffler, not the gsxr mufler, so mfr's response saying it's cuz a gsxr muffler was being used was a bit off the mark... personally, i would go w/one of the other alternative midpipes.
    i went w/the high-flow kientech to use w/a high-flow fmf powerbomb header, and it worked fine. i did have to trim the rubber grommet i the frame where the unit attaches, tho, to pull the pipe away from the shock a bit, and closer to the frame, so it wouldn't rub the shock spring:
    http://www.advrider.com/forums/showthread.php?p=16965800&highlight=doug#post16965800
    regarding other aftermarket choices besides the gsxr can, i sourced a tsukigi can for the '01-'04 gsxr, and it's excellent - open design, not too loud, and does not need repacking. (pics also shown in the post i linked above.)
    doug s.
  7. eakins
    eakins Butler Maps
    May 29, 2002
    38,389
    Fort Collins, Colorado
    at this point I'd would not consider Hindle an option for anyone as that pipe has a very deep bend (too deep and it hits?). i'd go w/ the keintech option as that is a a known good pipe.
  8. Fishnbiker
    Fishnbiker Tire smuddy, hook swet
    Aug 6, 2005
    3,874
    Campbell River, Vancouver Island, BC, Canada
    I'm now looking at taking the 40FO off my Tiger to install on my new '08 DR. Anyone know for sure what metals the GSXR headers & mid-pipe are made of? Is the titanium content restricted to the muffler, with stainless headers, or is the whole system unobtainium? The metal is burnt blue to near the tail where it yellows. Very thin walls, very light.
    I have enough of the GSXR header & mid-pipe to redo a match up, but only if It's not too expensive to weld.
    The 40FO has been on the Tiger for several years with no issues other than a few dents.
    Thanks,
    #8
  9. kezzajohnson
    kezzajohnson kezza
    Apr 17, 2007
    3,968
    Cairns - Queensland Australia
    Great Mod. Great thread.
    I managed to get a X40FIX titanium and here's what I did.
    The mid-pipe issue can be a bit of a drama. I happened upon a local engineering shop that had been making some practice handrails from stainless steel which had 90 degree mandrel bends and I scored a couple of offcuts and took them home to play with some angles etc. After I had worked out the angles and length, I cut them as marked and took them back in to the engineering shop to have them joined (stainless steel weld). I couldn't be bothered trying to sell the stock muffler and wouldn't be needing it anymore, so I cut the front section off that (also Stainless Steel) which contained the mid mount in order to have that joined on to the midpipe.
    A fellow ADVer in Brissy, helped me obtain a laser cut stainless steel flange.
    I made a rear mounting plate myself and used a rubber grommet from the stock muffler to mount between the GSXR muffler mount and the mounting plate.
    After the midpipe was fabbed, I fitted it all up to the bike including the flange bolted to the muffler but not yet welded to the midpipe. I then took the whole bike in and had the flange welded to the midpipe with everything in place and at the right angle.
    I can't say it was necessarily a cheaper option by the time I paid the engineering shop for bits and pieces and welding and then the flange, but it was a challenging project all the same.
    No fitment issues and never any issues with rubbing anywhere or hitting anything, no cracks or breaks after about 4 years.
    Below: initial cut and angles with portion from stock muffler for mid mount
    Below: Home made rear mounting bracket
    Below: Drawing of dimensions for flange: Note: ID will vary depending on midpipe used.
    Below: Finished product (foot not included)
    #9
  10. dogjaw
    dogjaw plays well alone
    Jul 13, 2008
    4,319
    between the Ozarks and the Ouachitas
    Another option is the 24f0 off of the Hayabusa; very plentiful as there were many more years involved, and each bike has two. The DR seems to like it better than the other options, as it seems to have the perfect amount of restriction, especially with stock or minor mods to the jetting.The 40f0 weighs 4.5#, the 35f0 and 24f0 both weigh right around 7#; pretty substantial savings over the 18# stocker. I found the Holy Grail of exhausts some time ago, a whole pile of pristine Suzuki takeoffs; bought every one for 20.00 each, 3 40, 7 35, and 21 24's; I felt like King Midas.
    Jesse at Kientech has recently fitted an 18g1, and says it works great; haven't tried it on mine, but if Jesse says it, you can take it to the bank. I've got some video comparing my son's 24 to my 40, I'll see if I can't dig it up.
    The Ride for Trevor:
    http://advrider.com/forums/showthread.php?t=941454
    #10
  11. dogjaw
    Jul 13, 2008
    4,319
  12. B1
    Jun 7, 2009
    4,971
    Arse-trailer
    nice! seems crazy suzuki doesn't put these on from scratch. surely they can't cast much more than the huge convoluted stocker...:huh
    #12
  13. dentedvw
    dentedvw Where did I put that
    Mar 18, 2008
    2,185
    ☼SLC-ish☼
    Is it possible that there is an aluminum flange on my bike?
    Previous owner put the kit together himself, apparently with Kientech parts. The flange that you bolt to the exhaust can is not welded to the pipe, so the connection between the pipe and the can rattles and exhaust escapes that side.
    I was comparing it to another rider's bike, and his is welded. Mine is not. I scratched the flange on mine, and it gouged like it is made of aluminum.
    I was hoping to have it welded on, but I can't tell if it's stainless or not. If I removed the whole thing, I guess it would become obvious quickly though.
    #13
  14. rosiethestarfish
    rosiethestarfish Adventurer
    Mar 23, 2012
    12
    Wodonga, VIC, Australia
    Found a x40F1x (aussie equivalent to x40F0x) but the wrecker wants $200! $200 for a stock tube, I was pretty upset but unfortunately wreckers don't usually haggle. By the time I buy the mid pipe from Kinetech and get it shipped to Australia the whole system would cost me $550. I think I would be better off with a Barrett slip on...or I will just keep looking
    #14
  15. bankerman
    bankerman n00b
    Nov 29, 2014
    1
    Hi Guys,
    Will an 09 gsxr 600/750 can work also?
    #15
  16. SDIZZY
    SDIZZY Been here awhile
    Jan 22, 2014
    498
    RI
    Right now I have a 2Brothers Racing M7 mounted up to FMF powerbomb.
    I scored a x40F0x and am wondering if the midpipe can be reused from the M7, or I will need to order the oversize one from JNS?
    #16
  17. MrBright$park
    MrBright$park Adventurer
    Sep 26, 2016
    38
    Kyiv, Ukraine
    Can anyone measure the length and the diameter of these cans? x40F0x, x18G1x, 35F01? I think of fitting one to my Aprilia Pegaso and would like to see how it will look like.
    #17
  18. Old Kiwi#99
    Old Kiwi#99 Been here awhile
    Nov 5, 2006
    314
    Middle Earth, New Zealand
    x18G1x is 21' long x 5" diameter. The one on my KLR is shortened to 16" long - stuck out too far.
    #18
    MrBright$park likes this.
  19. MrBright$park
    Sep 26, 2016
    38
    Kyiv, Ukraine
    Thank you very much, Old Kiwi#99! Is 21" is the full length or cylindrical part only?
    #19
  20. Old Kiwi#99
    Nov 5, 2006
    314
    The was just for the can, not counting the mounting boss or the tailpipe extension.
    #20
