Adding a Watsonian Grand Prix Classic to a 2007 Triumph Bonneville
Discussion in 'Hacks' started by propforward, Mar 29, 2020.
  1. TripleDaddy
    TripleDaddy Hoping my skills exceed my horsepower
    Aug 31, 2010
    1,936
    Westfield, IN by US 32 and Shady Nook
    This isn't my bike, but see if any of these photos help you:
    5d8bace9ef5d520b783dd419.jpg 5d8bace5474fa7319f067c78.jpg 5d8baceca0b4ed139b23d6e3.jpg 5d8bace77db164555867fa03.jpg
    #21
    fireflyr, davide, Bobmws and 2 others like this.
  2. propforward
    propforward PIE!romaniac
    Jun 11, 2009
    14,376
    Central Minnesota
    They do. Thanks - more confirmation of approach. It's all good input. That's a lovely outfit.
    #22
    Flyin' Monkeys likes this.
  3. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    10,533
    The Bluegrass
    The shape compliments classically styled bikes of any brand.
    #23
  4. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    It really does. Gorgeous outfit!
    #24
    FLYING EYEBALL likes this.
  5. Vato Jinete
    Vato Jinete Feo del Norte Supporter
    Dec 31, 2010
    845
    Excelsior, MN via San Antonio, TX
    Looking very nice Prop.
    We'll have to meet up when you are done and this corona thing is done.
    #25
    propforward likes this.
  6. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    I like that idea a lot!
    #26
    Vato Jinete likes this.
  7. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    Progress made today!
    Started off by taking the tub off, which Watsonian advised from the get go. This really does make setting up a hell of lot easier. Levelled the chassis first:
    It's not entirely obvious what is going on here, but I decided to use a laser level and square, along with some aluminium bar as straight edges, to mark out the position of the center of the sidecar wheel, 55" away from the wheel centerline.
    I used the straight edges to actually mark the desired centerline of the bike, along with width marks for each tire, and used that to position the bike relative to the side car chassis.
    Then I moved the bike into position, and started attaching the linkages.
    Once I had the lean out set, I marked the linkages and removed them one at a time, and trimmed the length back.
    So there it is, the chassis is attached to the bike and free standing. I feel pretty good about it. Tomorrow I'll go around and tighten everything again, and then see about putting the tub back on.
    EDIT: I forgot to add that 55” was too much track width, and I actually reduced it to 49” after the first attempt, which is a very nice set up.
    #27
    pops, BJMoose, Jimr80gs and 6 others like this.
  8. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    Right so, a little bit of bother today. Went to install the fender, and found that the two mounting bolts were nowhere to be found, and I didn't have any in my various buckets o' bits either. So, figured out what I needed and ordered those, and then temporarily installed the fender (i.e. it's just kind of hanging in place) so that I could run the wiring, which I simply tied to the middle cross member before putting the tub back on.
    It runs up the other side and to the bike via the rear top linkage.
    The blue tape is simply my marker meaning "this one is all tightened up".
    Was happy that my side bag on the right side still fits nicely.
    #28
    pops and BJMoose like this.
  9. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    Anyhoo, net result of this weekends work:
    Mostly assembled:
    And further along.
    Really happy with the overall quality. Good, sturdy construction. The windshield fits really well, and is also sturdy.
    Still a few things to do - connect the wiring, put some rubber trim on the linkage ends where I trimmed them down, trim the sidecover to fit on the right side of the bike, tighten a few attachment points, but then it will be ready for a test.
    #29
  10. GR8ADV
    GR8ADV Safety Second!
    Mar 7, 2007
    1,789
    Bellevue
    Perfect time for a project.
    Stunning. My Bonneville now seems incomplete.
    #30
  11. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    Thank you! I'm really glad I have this to work on at times like this - and a place to do it in. A lot of people aren't so lucky, alas.
    Anyway, I'm going for a toe in of 1/2", and wheel lead of somewhere between 9 and 10". Was trying for 9", but ended up a bit past it. My lean out was at 1/2", but during the faffing about has ended up greatly reduced.
    I don't think it will be hard to tweak the lean out back, but for now I'm going with it as is, and when I get to testing it I'll just see how it feels. Got to start somewhere.
    Today I ordered replacement bolts for the fender, and also some connectors to make splicing in to the lighting harness neat and clean, so it may be a couple of weeks before an update, with shipping being a little delayed.
    #31
    pops likes this.
  12. Vato Jinete
    Dec 31, 2010
    845
    Looks fantastic! Nice job (as usual).
    #32
  13. fireflyr
    fireflyr Dumpster Diver
    Mar 16, 2008
    1,160
    Keene, California
    Nice job and that rug really does tie the room together.
    #33
    BJMoose, propforward and brstar like this.
  14. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    With the way I marked it out, the rug really tied the rig together. :D
    #34
    Jimr80gs, Bobmws, fireflyr and 2 others like this.
  15. propforward
    Jun 11, 2009
    14,376
    Central Minnesota
    I'm claiming today as a success. I finished up installing the fender, and tightened up all the bolts again just to check, then took the rig around the garden a few times. It actually rides pretty well. Since it didn't just flip up and kill me, I decided I wasn't too far off on geometry, and took it down our road. Not very fast, maybe 25 mph, just enough to get a feel for how it pulls. Overall, I have to say for a first effort I'm pleased. It pulls a little to the left if I start to release the bars. The bars do get a wobble, but doesn't feel terrible. Also, this was a gravel road so I'm not going to stress about that yet, plus I need to check tire pressures. When braking hard, the rig did pull left very hard. My thinking is that the toe in is a little too much, so I may adjust that. However, the chair does not lift excessively, and I don't feel it is pulling badly when attempting to just ride in a straight line. I think I'm close. But I need to check tire pressures, and also take this to a local parking lot and do the test ride there. Today's ride was only round the yard and on a gravel road, with ruts etc, so I want to get a better feel on smooth pavement. Not a bad first go though.
    So here are a few piccies.
    I did need to trim the side cover a bit to get it to fit over the attachment point.
    And as well as tweaking the alignment, I still have to connect the lights. I have ordered connectors from Eastern Beaver so that I can make a custom wiring adapter to just plug in to the main harness, rather than cut wires or try and force posi taps in place. Should have those connectors next week.
    This connector
    Is under the seat, and connects the rear lights and indicators in to the main harness. So I am going to make a junction to go in the middle of the connector, which will then also supply the sidecar lights.
    #35
  16. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    Well it certainly LOOKS great, but you knew how great it was gonna look before you even ordered the car!
    As for the riding impressions, I wouldn't give a 2nd thought to feedback on gravel. Wait for the pavement test.
    #36
  17. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,424
    north of seattle
    #37
  18. cycleman2
    cycleman2 Long timer
    Jan 18, 2010
    1,544
    Alberta, Canada
    Good looking rig. Well done.
    #38
  19. TripleDaddy
    Aug 31, 2010
    1,936
    Looks great! Do you have much experience with sidecars? If no, do you have a local buddy that can ride it, or that can let you ride his? I've found nothing as helpful as riding someone else's well sorted rig.
    #39
  20. raysrig
    raysrig Adventurer
    May 4, 2018
    63
    San Bernardino, Ca
    Pretty classic lines. When done drooling I would split my time riding around everywhere showing that thing off and the other half snapping pics. The only thing I would add is a doggie copilot. I definitely want one when I grow up.
    #40
